Question about Dryers
White knight 77aw trips out after about 5 mins, smells quite hot
Will run again after waiting for 5 minutes but trips out again after 5 mins.
  • Dryers Master
  • 8,220 Answers
I have never seen one of these dryers but I would imagine the control thermostat is probably not working and the safety limit is tripping OR the vent is blocked causing excessive heat and tripping the safety. The filter might be blocked with lint. It supposed to be cleaned after every load.
Posted on Dec 05, 2012
SOURCE: tumble dryer drum willnot revolve.
i have a white knight dryer drive belt snapped how do i fit new one model cl382wv thanks
Posted on Dec 16, 2008
Buffalo12980
  • 625 Answers
SOURCE: Dryer runs for 5 minutes then stops
look in the vent line for a small disk shaped overload with two wires coming out of it. it may be bad. also check for a lint build-up in the exhaust line out of the blower. check the damper outlet going out of the house for a build-up of lint.
Posted on Aug 21, 2007
  • 12 Answers
SOURCE: Dryer stops after 5 minutes
dryer moter is covered with lint and over heating.if the moter is not completely burned out `you mite clean it with air pressure .if it still does it `replace it.
Posted on Feb 28, 2008
dididsaythat
  • 291 Answers
SOURCE: Dryer will run about 5 mins. then trips the circuit breaker.
I would change the breaker frist and see if that sovles the problem
Posted on Oct 14, 2007
SOURCE: TDC 30 Dryer starts but after 5 mins "clicks and stops"
its probably the relay (brown plastic box at the front under lid)! Symptoms are usually.... the dryer will go for a few minutes then shut down.... then you have to wait for it to start
Posted on Jun 06, 2008
I have a tumble dryer white knight 77aw and it makes a loud noise like a engine could u help
Hard to tell but from what you're describing sounds like bearings for the barrel.
Mar 17, 2015 | Dryers
My white knight condenser tumble dryer keeps
is it just shutting off or is it tripping ur breaker?
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Oct 13, 2014 | Dryers
I need a user manual for my White Knight Washer Drier
Try this PDF this seems to be for the 77AW by White Knight!
Jun 24, 2012 | Washing Machines
Our white knight 77aw tumble dryer is very noisy.....is there anything we can do to reduce it?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 26, 2011 | Dryers
Trips
The switch could be bad. Make sure there are no clogs anywhere that could be causing it to overheat. Try to bypass the switch and run it just long enough to see if you can go longer than the normal 5 min. you're getting. If you can then replace the trip switch. Do not continue to use the machine without the trip switch operating properly or it could catch on fire.
Jul 20, 2010 | Beam Industries 2900 Serenity Plus Central...
Ryobi SS30 starts great, runs fine, quits
the engine is getting to hot & shutting down either not the right fuel mix or not enough oil in engine sometimes the mixture screws need to be adjusted
Jun 14, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Car Runs and Loses Power and Quits Running
Try cleaning the fuel pump filter. Under the seat behind the driver lift the carpet and you will find a round cover with six screws remove the cover. The fuel pump is directly below unscrew the retaining round plate and remove the pump. At the base of the pump is a small filter if it is covered in black muck that's your problem. clean and replace. job takes about 10 mins good luck. please let me know how you got on!
shauunswbc@aol.com
Mar 10, 2009 | 2002 Land Rover Freelander
I'm trying to hook up my 4 prong dryer cord and I think we hooked up right but it was on for maybe 5 min. and it was super hot and I did the red to red black on black green as the ground and the white as...
new unit ?? the burning smell will go away after 5 min of running you connected it up right. Also check the venting to make sure it is clear
May 19, 2008 | GE Dryers
Dryers Logo
116 people viewed this question
Top Dryers Experts
