Question about JVC HD-52FA97 HDTV
Screen is dark on my 52Fa97
I changed the bulb but picture is still dark. is there a color wheel or something that might be the problem
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: dark screen on my jvc52FA97 DLP i changed the bulb and nothing cleaned the mirror and nothing i was wondering if it might be the color wheel or there was another light that shot up towards the mirror
If not the lamp I would suspect the light engine itself.
Posted on Dec 06, 2012
After about 30-60 minutes TV starts to hum and picture gets distorted, could this be the color wheel...???
Sounds like a sync problem due to color wheel speed. clean and lubricate color wheel motor with tiny amount of Z-Max lubricant (liquid Buckey balls, available at Wal-Mart), on each bearing. make sure wheel is free-wheeling and turns easily. Should cure problem. If the color wheel is in good shape, there is a power supply problem, which may be due to dried out electrolytic capacitors or a regulator that's failing. Troubleshooting or controller board replacement may be needed. Regards.
Dec 07, 2015 | Mitsubishi WD-73840 73" 3D Home Cinema...
Colored spots on Samsung HLP5063W
The color wheel or the DLP chip itself will cause this. Parts can be had here: www.shopjimmy.com
Jun 27, 2017 | Samsung HL-P5063W 50" Rear Projection HDTV
Just replaced burnt out bulb in Infocus 4805 projector. Great picture with new bulb but only black and white. Is this a bulb issue or something else in the projector?
This is most likely the color wheel. When the bulb blows, it can damage the color wheel. The color wheel is a wheel composed of thin layers of colored glass that spins in front of the projected image. It is possible to repair it with super glue, but the best way is to try to find a new one to buy.
Dec 29, 2010 | InFocus ScreenPlay 4805 Multimedia...
I have a 50 in RCA older HDTV that is experiencing a darkness in a V pattern starting in the middle of the bottom of the screen. I am told that it is not the bulb but possibly a circuit board? HELP
i have seen a few of these and not seen that cuased by a curcit failure.(OF coarse nobody has seen it all) I would suspect something in the optical path. what i mean by this.... the bulb shines light through a color wheel into the engine then through a lens bouncing off a mirror then on the screen. now is the picture visable through the dark area? their could be something inside. blocking the lens(dirt,bug,fly) or there might be a broke mirror. also the screen could of got wet and damaged.. dont know exactly but these are my best guess without seeing the picture... let me know how it goes
Oct 22, 2010 | RCA HD50LPW175 50" HDTV
I have a 1994 zenith big screen the picture is showing really dar
It could be that the picture tubes have gone down on emission, there is a prcedure that can be tried to bring up the overall brightness but it is just possible that you will loose some picture quality. If it's a 1994 projo tv i am thinking of the three crt system, a gray scale alignment would probably correct the dark condition in your picture, again depending on how far gone is the emission in your picture tubes, if your projo tv is the dlp system, the bad news is that you could be needing some light engine repair. The color adjustment is possible with the availability of a service manual or in the case of the dlp system, light engine repairs or replacement are available from some on line stores.
Jan 12, 2010 | Zenith E44W46LCD 44" Rear Projection...
Dark Color on TV. Can't adjust the color correctly
Having same problem now for a second time on a 57T500. First time was a bad green bulb that was covered under warranty. Only lasted 2 years....currently debating wether to fix or buy a new set. Bulbs cost about $300. Set is only 5 years old, so very dissapointed with quality.
Feb 01, 2009 | Hitachi 57F500 57" Rear Projection...
Dark picture
you probably have a bad capacitor on the invertor board. try shining a flashlight into it to see if you can see anything. if capacitors are good, you might have some burnt out backlight bulbs. i just had the same problem, replaced the capacitors but messed something else up on the way i guess cause now all i have is a bright white screen with a few colors here and there.
Aug 30, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Dark picture
do you get all three colors? red, blue and green?
Dec 16, 2007 | Panasonic PT-51G44 51" Rear Projection...
JVC HD-52FA97 HDTV Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
