Question about HP Compaq Presario V2000 Notebook
Dvd/cd-rw stopped working after burning dvd...
I was burning a couple of dvds and all was fine until in the middle of my last one I had an error...Put a new blank in and it prompted me to put blank in so I tried 5 others and nodda..It won't recognize even a store bought cd or dvd...Is the unit dead??
  • 1 more comment
  • steve_stack Jan 12, 2009
    when I place a blank in, I can feel a vibrating from the burner and then I get a promt on the screen to place a blank writable disc in..I know the blanks are good because my other laptop accepts the blank...It just stopped mid stream burning several copies...
  • Biju Thomas May 11, 2010
    Did you try to reinstall your burning software?
    incomplete question! can you please elaborate?
If it is a cd-rw, as you've indicated above, it will not burn DVD's. The front of the burner will list what it can burn. For instance, my machine says DVD-+RW, which means that it can burn to both + and - DVD's, but it cannot do Dual-Layer (DL) DVD.
Dec 12, 2012 | Acard Technology (CD1TO7T) CD-RW Burner
My combo DVD drive will burn a CD, but when I put in a blank DVD it just opens the drawer and says to insert a disc. Windows XP.
If it is in fact a Teac CD-Rewritable W58E CD-RW Burner, this will only burn CDs and not DVDs. If you put in a blank DVD you will get this error. You will need a burner that has DVD burning support.
Jan 14, 2010 | Teac CD-Rewritable W58E CD-RW Burner
Dell Inspiron 8600 Cd RW/DVD has stopped working
this problem occurs when the lens of the drive gets weak or broken
you can either buy a new drive or just get the lens of the old drive replaced
yes its possible to replace a cd rw/ dvd drive with a dvd rw drive
Sep 29, 2009 | Dell Inspiron 8600 Notebook
Cdrom doesnt recognise blank dvd. error message
Its only cd writer burner and can only that it can read dvd disc also. That is why its called combo. But burning blank dvd it can't. But if you want buy some dvdburner too.
Apr 19, 2009 | Memorex (32023244) CD-RW/DVD-ROM Combo...
I can burn cd's but not dvd's
Hello Rfd832,
What I see from the description is that the drive is a combo drive. Combo drives are CD-RW and DVD-ROM drives means
CD-RW = Compact Disk-Read Write
DVD-ROM = Digital Versatile Disk - Read Only Memory
so these drives can read and write CDs but can only read DVDs (Cannot write or burn DVDs)
If you want to be able to burn DVDs then you need to have DVD RW drive (either DVD+RW or DVD-RW)
You said that you are able to burn DVDs on other computer so please check the label on the DVD drive.. it should be DVD-RW/DVD+RW drive
Hope that helps.. :)
Thanks and Regards,
Apr 12, 2009 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
I have a Sony CRX320E CD/DVD unable to write a DVD
CD-RW drives can only read all CD-rom and CD-RW formats and read DVD formats but cannot write to a DVD, if you want to write a DVDs you need to buy a DVD-RW burner which can burn all CD-formats
Jan 16, 2009 | Sony (CDR320E) CD-RW/DVD-ROM (Combo)...
Pioneer dvd-rw dvr k15ra
Imy burner will burn if I go into MY COMPUTER than into MY E drive but the auto burn will not work. I do have 1dvd click and ashampoo on the computer as well, but when I put a disc into the computer it will not automtically work. I was wondering if the above programs are stopping the auto play on it or what? The burner works fine if I go to the E drive and install o burn it that way, is there some kind of a setting or something that went out of wack??
Aug 16, 2008 | Pioneer (DVR-K15 BLACK) DVD RW Dual Layer...
Dvd dics
You often get this with no brand or unknow brand dvds, also some DVD writer can develope a probem either with DVD-r or DVD+r, even if it is supposed to be dvd + - rw . Try using good brand DVD -R. when you find a brand that is fine use only that one.
I am sorry about wasting the 100 dvds pack give them away as a present or selll on ebay, after having same problems a couple of times, on my home DVD RW I use only TDK, Philips, Verbatim or Sony DVDs.
Jul 29, 2008 | LG GSA-H42N 18x DVD RW DL IDE Drive...
DVD unit doesn't read CDs but works fine with DVDs
Sir: Did you try another CD or just 1 CD could not read by your DVD RW? Would you please make the DVD poped out and re-set it again. It seems the problem of communication becasue the code rate of DVD and CD is different. Its not related with the lens.
Jul 20, 2007 | Sony VAIO PCG-K35 Notebook
HP Compaq Presario V2000 Notebook Logo
83 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
