No water getting through to m/c
I have water supply to m/c
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 06, 2012
My lg refrigerator lsxs26326 is dispensing water but not filling ice tray up. What could be wrong?
the water solenoid valve for the water dispenser is separate from the icemaker water supply solenoid valve . get to the icemaker water supply solenoid and test it if it works alright . unplug the fridge from wall outlet do not close water supply valve. disconnect water tube connection on the water discharge side of the icemaker water supply solenoid valve . pull - out power supply connection of the solenoid coil . connect solenoid valve directly to wall outlet. a faint click should be audible and water should come out from where the tube was removed -- from the water supply discharge side. if no water is coming out with the solenoid plug in , then the solenoid is faulty. but if water comes while solenoid is powered -on , check the position of the icemaker lever. if it is on off position icemaker timer won't activate icemaker water supply valve..move icemaker lever to on and check for water pouring into the icemaker tray' if no water comes out . change the icemaker timer. thanks.
Mar 04, 2016 | LG Refrigerators
I'm not getting water have changed thefilter
Two things you can check. One, is the water supply turn on? Two, is the supply hose getting a kink in it when the fridge is pushed back against the wall? Open the water supply, and while the fridge is pulled out, look for kinks in the supply line, try the water dispenser.
Dec 03, 2013 | GE Profile PSW26P Stainless Steel Side by...
Electrolux Pure advantage water filter
Open and shut the water valve quickly to verify the water supply, it could be a bad water supply valve. Bench test the filters for flow or obstruction.
Aug 01, 2017 | Electrolux Icon Freezers
WATER KEEP RUNNING OUT OF THE RELEASE VALE
you can go to get another relief valve because if its dripping its probably bad. if you have a clark supply center nearby, you can get one there! or another plumbing place or water heater supply. you may have to drain out some water to bring the level below the valve. Shut off the power to water heater. If electric, turn gas to pilot setting, if a gas water heater. Cut off water supply to water heater as well. It is not necessary to drain the entire tank. Open a hot water faucet, drain water from tank, drain for approximately three to five minutes. Prepare the new relief valve with Teflon tape. Unscrew the relief valve counter-clockwise with a wrench to remove.
Turn the water supply back on to water heater. Make sure water is running from the open faucet before turning the power back on. good-day!
Mar 28, 2012 | Rheem 40 Gallon FVR NATGAS Low WATER...
Is it a cold water or hot water fill
It's your choice.There's only a single supply hose and with most dishwashers that means cold fill only, but as this is a compact basic worktop model the manual supplied suggests that users connect to a hot water supply.
In real-life situations though, the water drawn from the hot supply often isn't instantly hot so all you do is drain cold or tepid water from the supply pipe and let it get replaced with wasted hot water which then cools in the pipe! If the machine features condenser drying like many dishwashers, then cold water is essential for it to work. A final consideration is that unless your hot water is supplied at mains pressure (such as in a combi-boiler or megaflo system) then the water pressure from a hot water storage tank will not often be high enough and you'll have to use the cold supply.
Jul 13, 2011 | Bush DW5F 22 in. Dishwasher
Aqua clear system. no water is coming out of the aqua clear faucet and the water and ice are not working in the refrigerator, the tank is empty
First make sure you are getting water to the unit. There should be an 1/8" line supplying water to the unit on the back side and the line may be bent or kinked. If there is a good water supply then the next thing to check is the inline filter if it has one or it may have an internal filter system, check it. If at this point you are still not getting water then it will be in the electrical system ie: the solenoid switch that opens and closes the water supply for the ice maker.
Now you have said that you are not even getting water to the faucet so I would go with the water supply problems as being the problem.
Mar 06, 2011 | Culligan Home
My fisher and paykel ecosmart gwl15 won't do a hot wash. although the hot wash is selected, the water remains cold. there are no error lights or beeps. Help!
There are several possible causes. To track down the problem, first shut off the water supply valve feeding the washing machine, then remove the hot water hose from the machine and direct it into a bucket. Turn on the water supply valve. Does water come out? Is it hot? If you only get cold water, then you need to insulate the pipe between the water heater and the supply valve so you get hot water faster (assuming the water heater is working!)
If you have a supply of hot water, then check the inlet screen where the hose connects to the washing machine. Perhaps it is clogged with lime or sediment. If it is clear, then you have a fault in the hot water solenoid valve or water temperature selector switch.
Dec 05, 2010 | Fisher Paykel EcoSmart GWL15
Frigidare did get water out or make ice
Since both functions are not performing, check your water supply, a clogged filter, a bent supply line, a supply line that is turned off. Internally it could be that every thing is frozen up or your water valve is bad. Joe
Apr 17, 2010 | Refrigerators
No water supply
There are a few checks. Try the #1 first and then proceed to the next one til you get water. Here are a few checks:
  1. Turn off the supply and disconnect the supply line to the dishwasher, turn the water on to flush the line and to check for flow
  2. If you have water to to the supply line, your problem is the water solenoid. Replace the water solenoid.
  3. Turn off the supply, and disconnect the supply line at the shut off, turn the water on to check for flow.
  4. Shut the water off to the house, disassemblehe shut off, clean debris out of shut off. It may need to be flushed. I recommend using a hose to direct the flow into a 5 gallon bucket while someone cycles the water supply.
  5. Replacement of shut off is next.
Please rate this solution.
Aug 03, 2008 | Kenmore 15129 Built-in Dishwasher
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
