Question about Nikon Nuvis S APS Point and Shoot Camera
How to remove film from nikon nuvis s camera
Cannot remove film from camera
How do i remove film from nikon lite zoom ed 130
First rewind film in canster then when you hear the click you are finished rewinding the pull up on left winder knob this will open the door keep holing up and let fil drop out walla you're done.
Oct 01, 2013 | Nikon Lite Touch Zoom 130ed 35mm Film...
Is there supposed to be a memory chip or flip for this camra and if yes where does it go
No. It's a film camera and takes APS film which is no longer made, remaining stocks are getting more awkward to find now, they're all long out of date, and even if you can buy film it's now getting difficult to find companies able to process it.
Sep 23, 2011 | Nikon Nuvis S APS Point and Shoot Camera
I have a NikonN70, how do i unload the film?
Slide the camera back lock release down, open the back, and pull out the film cartridge. Full instructions are in the manual. "LOADING FILM" is on page 16, "REWINDING FILM" is on page 24, and page 25 shows how to remove the film.
If you need a manual, you can download one from
http://butkus.org/chinon/nikon/nikon_n70/nikon_n70.htm
Oct 05, 2010 | Nikon N70 35mm SLR Camera
Film advance lever stuck. Changed batteries but can not move the film advance lever.
Hi fmerlin, If you have film in it you may need to remove the film to free up the advance lever. Go into a closet cover under a blanket etc. Also, Walmart and most drug stores have a big change bag that they could do it for you. With film out it still will not advance it will need to go to Nikon.
Aug 18, 2010 | Nikonos V 35mm Point and Shoot Camera
What does the blinking E in the Nikon n65 mean?
It means "Film remains in the camera after film rewind complete."
If this is happening after shooting, the remedy is simple: open the camera and remove the film. If this is happening right after loading the film, then you've got a more serious problem: the camera is rewinding the film upon loading.
Mar 03, 2010 | Nikon Photography
The film magazine stuck in the Canone EOS 10 camera, never happened that before, i could easily insert and remove the film. it's rewinded, luckily, but I need a new one to put there, + I'm afraid if I...
Nikon N75 or Canon EOS 10????????
How is the film stuck? Is the rear door stuck? Does the film door open?
As long as you do not damage the film canister, the film will be ok. If the door opens and the film is rewound, use something to pry out the top of the canister from the camera. Then you can remove the film.
Even a film roll of 36 should not get stuck. Check the cartridge are for anything sticky. Sometimes these older cameras get some sticky residue from decaying foam in the shutter area. This would be a good time to send it in for CLA - Clean, Lubricate, Adjust.
My own EOS 10 had that problem. If you can't get the film out, the repair shop will do that for you.
Jan 20, 2010 | Nikon N75 35mm SLR Camera
How to change film in Nikon N 2020
Press the R1 and R2 release buttons. Pull up on winder handle until the back of the camera opens. Continue the pressure on winder handle until you have removed the film canister. Insert new film canister. Pull leader across winder assembly. Close camera back. Press exposure button. Press winder handle in towards camera b
Oct 13, 2009 | Nikon Photography
Film rewind crank stuck in up position nikon n2000
Move it a bit (some half circle)back and forth. The slot may be in wrong position related to the roll inside. It should click in when you get the slot in right angle.
Aug 02, 2009 | Nikon EM 35mm SLR Camera
Steel cover Nuvis S
The film slot is opened by twisting the "knob" on the end of the camera in the direction indicated by the arrow.
Oct 25, 2007 | Nikon Nuvis S APS Point and Shoot Camera
Nikon F60 Film rewind uncoded film help
Most manual cameras have a button to release the film on the bottom of the camera, push the button in and turn the rewind crank (left side of the top of the camera) until you feel the crank suddenly turning much easier.
Oct 04, 2007 | Nikon F60 35mm SLR Camera
Nikon Nuvis S APS Point and Shoot Camera Logo
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
