Question about Sharp AR-5316 Advanced Digital Imager Copier
Sharp xerox ar5516 is having L3 error - Sharp AR-5316 Advanced Digital Imager Copier
SOURCE: Sharp AL-1641cs error L3
Often just oiling the scanner rail with Triflow or a light 3in1 oil will get the job done. If the scanner drags even a little on the return it
will botch the timing and go into an error code.
Posted on Feb 26, 2008
007tech
  • 95 Answers
SOURCE: I have an error code of L3-00 on my Sharp AR 168D.
L3-00 indicates scan carriage motor trouble. The carriage with all the mirors on it is not moving at all (scanning) or is not moving at the required speed so it does not reach its "home" position. If restarting the copier does resolve the issue....
A few things to check... When you turn copier on does carriage move at all? if not then the motor could be bound up (not turning) - also make sure the cables pulling the carriage are properly wound. remove the main glass and make sure there are no obstructions in the way of the carriage (a loose cable maybe or dirt) can you move the cable by hand freely? if the motor locks up it could be really hard to move the carriage.
The carriage seems to be moving freely (by hand and when you turn the copier on) it could possibly be the "home position" sensor that is faulty and not reading the correct position of the carriage.
You can the copier in test mode to check either the motor or sensor. press the following keys one after the other # * C * then press start/enter , press 1 and start/enter again, sub code 1 will test the motor and sub code 2 will test the sensor.
So it could be a bad motor or sensor or the MCU board that drives the motor (or may just need a good cleaning).
Good Luck.
Posted on Mar 26, 2009
  • 990 Answers
SOURCE: i have a sharp ar-287 error l3 - 00 how to fix?
Hello sir; Try to make a copy without the cover then you may see the mirrow not moving out, you open the glass to serch the factor it cause this problem.
Posted on Jun 04, 2009
xptareq2000
  • 1447 Answers
SOURCE: My sharp xerox machine ar5516 is bleaking a man
Man mean maintenance signal.
Reset : # - Interrupt - C -interrupt press 14 press start key.
If you are not fix try next way.
# - Interrupt - C -interrupt press 16 press start key.
Posted on Jan 27, 2010
rezazadeh
  • 328 Answers
SOURCE: SHARP AR5516 PAPER JAM ERROR MESSAGE
when you open side door in the up you see a black unit check if sesor not broken. also open cassete and see inside no paper jam there
Posted on May 29, 2010
My copier sharp-ar5516 is indicating error code F5 00 what's problem
on your ar5516 f5 error code would be a copy lamp problem, lamp bad or the fuse or a connection.
Apr 11, 2017 | Sharp Office Equipment & Supplies
HOW TO FIX ERROR CODE 444 BLINKING FOR SHARP AR-5516?
http://www.sharpmea.com/cps/rde/xbcr/documents/documents/om/34_ppc/AR5516-D-5520-D_OM_GB.pdf
May 20, 2014 | Sharp AR-5320 Black and White Copier
Sharp ar5516 f2 error
We have bought this machine on Date-28/07/2011 and it is still in warrenty. now already 11,000 copies put it And the now machine shows F2 indication after starting and the company not repairing it. And the after sell service of company is not good.We tell the company to change the the machine or repair and they neither repairing it nor changing the part.
I request you to solve my problem please.
Nov 14, 2011 | Office Equipment & Supplies
Display error code E7
Sharp copier AR5516 not working. Error code E 7 kindly help.
Jul 27, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar5516s printer driver
Drivers for Sharp AR-5516 are available at Sharp Official Support site Click here and make selection as under: -
Select
Photocopiers > AR5516 > Windows (XP, Vista, Windows 7 etc) Depending upon the OS you have.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Apr 07, 2011 | Sharp Computers & Internet
Jan 27, 2010 | Sharp AR-5320 Black and White Copier
SHARP 1631 CODE L3
The error is for the scanner mirror home position sensor. When the scanner mirror comes back to home (start) position if the photocell sensor doesn't see it due to be dirty or faulty the L3 error will be displayed.
Hope that helps you.
Aug 04, 2008 | Sharp Office Equipment & Supplies
Sharp AR-5316 Advanced Digital Imager Copier Logo
88 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
