Question about Car Audio & Video
I have 3500 watts of subs total of 1100 rms what size amp should
I get i have a quantum audio amp with 2080 watts with 1040rms but it over heat withen 10 to 15 min of playing and shut off only had the amp 4one month brand new my subs are pioneer pro champion 2500 watts with 800 continous rms daul vc 4ohms n 8ohms the other sub is a kenwood 1000 watts with a 300 rms
  • 45 Answers
Make shure your running thick guage wire like 2-0 guage wire to get correct power to it also and check on amp the ohm's it can handle to make shure your not running to makny ohms.
Posted on Jan 12, 2009
I have the MRP-M1000 amp. I want to hook up 2 alpine subs to this amp. Which alpine subs would be the best for this amp? Please be specific with ohms and watts.
Your best bet will be to wire 2 subs in parallel to the amp. Each sub should be rated for at least 300 watts rms at 4 ohms. This will give you a total impedance of 2 ohms, and your amp will put out 600 watts rms at that impedance. That way, each sub will receive 300 wats rms. I would not recommend wiring subs in parallel, as you will need two 1 ohm subs at 300 watts rms, which are harder to find and will be more expensive. A parallel circuit is the most efficient way to do it.
Feb 23, 2011 | Alpine MRP-M1000 Car Audio Amplifier
Which amplifier i should use with JBL CS-1205T
this sub woofer tube has a rms rating of 275 watts... try using a kicker or orion 600 watt mono amp to run this. the brand name is what tell you about how good an amp is for instance the names i just mentioned rate their amp by standard play frenquencies where as other lower brand names rate their amps by the max out put on certain subs at certain frequencies which may lower their impedance and create more power although you will never play your sub at those frequencies. as for the max power of your sub of 1100 watts that is more than like only at a certain frequency so always only double your rms rating of your sub to find max power handling.
Jan 29, 2011 | Sony Xplod Amplifier XM-SD51X - Class D...
What size amp do i need to run 4 1000 watt pyle 10's bridged
well first of all you cant bridge subs... you can bridge an amp... and for 2 they are probablly not 1000 watts, make sure you understand RMS and what the sub can ACTUALLY HANDLE properly... i would get a 1000 to 1500 watt RMS that is RMS RMS RMS RMS amp not one that says 2000 watts MAX POWER cuz thats cheap ****... get a kicker JL hifonic alpine or something in that category that actually tells you the TRUE power output of the amp... then run those 4 subs in a parallel circuit so its like really only having 2 subs. make sure then these subs do not run less then 2 ohms at the terminals while in a parallel, then bridge these subs acting as 2 subs not 4 to your TRUE 1000 watt amp and you should have a good powerful system
Mar 19, 2010 | Pyle 10'' Subwoofer Tube w/Amplifier Car...
I have one 12inch 1000 watt mtx sub what size amp should i buy
Hello taona80,
If the 1,000 watts is RMS, I'd recommend an amp in the 750-1,000 watt RMS range, perhaps like the Alpine MRP-M1000 or Rockford-Fosgate T1000bd. If the 1,000 watts is peak power, the subs continuous (RMS) power handling is much lower, probably 300-400 watts. In that case, I'd recommend the Alpine MRP-M500 or Rockford-Fosgate T500-1bd.
Nov 09, 2009 | Nitro BMW-482 Car Audio Amplifier
Hi i have two 10'' jenson xs sub and they are about 6 years old and i was wondering wut amp size i should buy to run them.
I believe these are 4ohms, if so buy a 2ohm stable monoblock amp, that puts out 250-300 watts RMS, and connect your subs to it in parallel, don't pay attention to peak watts, look at RMS watts, or continuous watts. If they're 2 ohms, buy a 2 ohm stable 2 channel amp that puts out 125-150 watts RMS per channel, and 250-300 watts total or bridged RMS output. And connect them normally, on sub per channel... hope this helps, as far as brand recommendations, MTX, pioneer, Alpine, Kenwood... Good luck
Sep 20, 2009 | Jensen XS-1010 Car Subwoofer
Car Ampli Problem
forget hooking this on a subwoofer. this amp produces only 50 watts per channel at 4ohms or 70 watts per channel at 2 ohms RMS...
If you try bridging the sub, it will only give out maybe 100watts bridged.
So..... if your sub is, lets say 1000watts RMS, youre just going to bust your amplifier to smoke...
Find a more decent and powerful amp. This amp is only intended for separates and lowend subs with an RMS of 80 to 150 watts
Sep 08, 2009 | Eclipse EA3422 Car Audio Amplifier
I have 3 hifonics zeus Size: 12 inch Impedance: Single 4 Ohms Peak Power Handling: 800 watts RMS Power Handling: 400 watts Sensitivity: 89.9 dB Aluminum Cast Basket American Spider For Reliable Performance...
Hello king3132,
Three 4 ohm subs can be wired parallel for a 1.34 ohm final load or series for a 12 ohm load. If you have the channels of the amp bridged, I hope that the subs are connected in series because the Sony XM-2200GTX is NOT rated for or stable at 1.34 ohms. It's only stable down to 4 ohms.
You definitely will not get the maximum potential of the subs from that amp. They can handle 400 watts RMS each (total 1,200 watts) and the amp is only capable of 500 watts RMS into 4 ohms (less at higher impedance), so each sub could only be getting a maximum of 166.6 watts RMS.
Hope this helps.
Jul 20, 2009 | Digital Audio Car Audio & Video
Is amp big enough for speakers
To run 2 subs, the amp would be a little small. The subs will run OK, they just won't be very loud.
It's usually better to compare and match up the RMS power rather than the peak power. The Sony XS-L10P5B sub has a peak power handling figure of 1200 watts, but the RMS is 300 watts. The Sony XM-ZZR3301 monoblock amp puts out 1100 watts peak, but only 330 watts RMS. They would work great together, 1 sub, 1 amp. But if you add another sub, each one would only be getting about 165 watts. They'd work OK, just not as loud as they could be.
Hope this helps!
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
What is best amp to run 2 12 inch cvr's
12In Kicker CVRs
are Dual Voice Coil, and You can run each voice coil around 200 Watts RMS
So each sub will have a 400 Watt RMS and 800 Watts peak.
Now since you have 2, Your total will be 800 Watts RMS and 1600 Watts Peak.
I would get really any amp that sits at around 800-1000 Watts RMS.
These are kicker but they are low end so i wouldnt push them to the extreme.
1000-1200 Watts RMS Max and but keep the Gain down on the amp. They will hit no doubt but i wouldnt push these subs or you will be disapointed in the long run.
I would get a Fosgate or MTX amp.
You can get any amp really but find something right around 1000 Watts RMS and it will push those well.
You can go mono block or a 2 channel, just depends on how you want to wire them.
Be careful though. If your running them bridged right now with your mono block, do not run them parallel bridged on a 1000w RMS Amp, you will blow them so fast lol
(RMS = Root Mean Square. Or in other words is the continuous wattage being sent from the amplifier to the subwoffers)
Feb 15, 2009 | Kicker KX1200.1 Car Audio Amplifier
Support Question about RMS
you are going to need an amp that can supply the right amount of rms power to make it sound good. these sony subs are rated for 380 watts rms. so in order to find an amp that will supply two, you must multiply that figure by two. so you will need an amp that can supply around 500 to 750 watts continuously (or rms). also you are going to want an amp that is either class d or class ab rated. these amps are built to push subwoofers exclusively and will give you the best efficiency and sound out of your subs. you will also want to get an amplifier is a monoblock amp, and not a stereo amplifier. make sure the amp can put out that rms rating at 2 ohms as two 4 ohm speakers equal 2 ohms wired in parallel. i have a kenwood kac9152d that puts out about 2000 watts max at 2 or 1 ohms (900 watts rms) that i used with my two sony xplod 10's for about 2 years. it was kick ***! now i dont know if you need that much power but they will handle it as long as you dont push them too hard for long periods of time, otherwise you might end up blowing them up! (depending on the box size that is, and the quality of it as well...)
i have years of car audio installation experience and can help with setting up and wiring any mobile entertainment system you can imagine. may i ask what kind of music you listen to and what kind of box do you have for these subwoofers?
if you have any questions email me at thadoggma420@hotmail.com
Jan 22, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Car Audio & Video Logo
183 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
