Question about Kitchen Appliances - Others
Hi i just got my bread machine yesterday, i tried to bake a french bread put everything in and switch it on, goes for 7 mins then machine switch off why does that happen?
    Genius:
  • 1,280 Answers
It should do nothing for 15-20 minutes maybe a little less to allow the dough to rise. Then it should knead again and go into the second rise before baking
Posted on Dec 08, 2012
SpotBert
  • 231 Answers
SOURCE: Bread Rises Beautifully - then sinks in middle during bake cycle
Sinking in the middle means that there was too much rising for the amount of structure in the bread.
Usual causes:
-too much yeast (reduce 1/2 tsp.)
-too much sugar (reduce 1/2 tsp.)
-not enough salt (increase 1/4 tsp.)
-too much water (reduce 1 tbsp)
Another possible remedy: use "best for bread" flour, it has more gluten, or add gluten separately, 1 tbsp.
Start with reducing amount of water.
Posted on Jan 04, 2009
  • 204 Answers
SOURCE: worn out bread pan
I had great success in finding what I wanted for my breadmaker at http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Posted on Jan 06, 2009
rockitman187
  • 2559 Answers
SOURCE: Bread falls in last 30 min of baking
Have you tested the yeast?
If not here is a way
Place 2-1/4 teaspoons (1/4-oz package) yeast PLUS 1 teaspoon sugar in 1/2 cup of warm water, in a 1 cup measuring cup.
1. The water temperature should be comfortable when placing a few drops on your wrist or test it so its about 110 - 115 degrees F but read the package, as recommended temperatures may vary.
2. Let the yeast mixture sit for 2 to 3 minutes for it to become thoroughly dissolved and for it to begin to grow and show signs of life. Tiny bubbles should begin to appear on the surface or around the edge of the container and it should start to smell yeasty. Some varieties will cause the whole mixture to expand rather dramatically.
If none of this happens, and you're sure that the water you used was not too hot, it may be that you have some "tired" yeast. However, I have made many breads where there were very few bubbles formed on the surface of the yeast, simply because I did not add much sugar -- but, you should at least see some activity and smell a yeast aroma. Present day yeasts are encapsulated with a food source to keep them alive until you add the flour, sugar and other food ources.
If you suspect your yeast might be too old, your best bet is to get a new batch and start again. Test other yeast in the same batch.
3. If active, use immediately in a recipe, adjusting for water, sugar and yeast used. Make sure all liquids are at 110-115 degrees F and add it to the proofed yeast. Remember to stir. Don't add the salt yet because it is too strong and will kill the yeast if added in at this stage. Rather, stir it into with the first cup of flour.
Posted on Jan 19, 2009
SOURCE: Bread pan pops out during kneading, hard to remove after baking
I have Breadman Ultimate for over 12 years now. I make bread 2-3 times a week for the past 10 years. I found that the bread pan popping out only happens when the motor shaft and the kneading paddle are not tightly engaged. I find this problem in the following two scenarios: 1. The bread pan was not pushed down all the way as described by cassie_hobbs and tlcquiltnut. 2. Debris filled up the motor-shaft bowl underneath the bread pan to prevent a tight engagement of the motor shaft and the kneading paddle. These debris are generated during the kneading process; part of the ingredients is pushed out of the shallow horizontal pan and accumulated underneath. To avoid the problem, I have to periodically remove debris from the shaft bowl and make sure the pan pushed all the way down. To reduce the debris, I made a simple cover for the bread pan by cutting an old aluminum baking dish. I always remove the cover after the kneading cycle to prevent the rising dough from reaching the bottom of the cover. Hope this helps. Wendy
Posted on Apr 15, 2009
SOURCE: need recipe book for sanyo SBM-15 bread machine
well i just download the manual for Sanyo SBM-15 Breadmaker so for those who was asking where to get one this is where i got mine from
sanyoservice.com/pdf/images/SBM-15(0M).pdf
Posted on Jul 09, 2010
Trying to make French bread in my toastmaster bread and butter maker. Bread rose, doesn't bake. Machine is flashing 000
If you pushed the button for "French" bread then you do have a problem. If you pushed the "Dough" buttton then the flashing0:00 just means your dough is ready.
Apr 13, 2013 | Toastmaster TBR15 Bread Maker
Breadmaker stopped and bread not baked
It usually isn't worth it to try to repair a bread machine and yours does sound like the eletronics have gone bad. I have several good machines for sale at very reasonable prices. contact me at breadmachineshelp.com if you are interested in replacing your k6725
Sep 30, 2012 | Regal Ware K6745S Kitchen Pro Bread Maker
I added the ingredients as per instructions, switched the machine on. After 5 mins, it stopped and went blank.No power to the machine. What do I do?
Give it back to your son. Just kidding! Try plugging it in somewhere else. And make sure the cord is connected good.
Dec 30, 2011 | Breadman TR875 Bread Maker
My bread falls when baking in the oven. i make the dough in the machine and then put it into a loaf pan
Hi visibility...
Couple of things to try...
1... Do not open the oven when baking your bread, only open when done.
2...You can try adding a bit more baking powder to the bread mix.
Please take time to rate me
Jul 31, 2011 | Sunbeam Vacuums
Bread machine model TR520, mixes the dough, stops for a long time, then starts mixing the dough again continuously without starting the bake cycle. This was on the french program. The machine is new...
By continuously do you mean forever, non-stop kneading? I'm guessing not. French bread is really nothing more than white bread dough kneaded for an extra long time. The extra kneading creates the chewyness common to French breads.
Hope this helps!
Jun 17, 2011 | Breadman TR520 Bread Maker
Dear expert: I bought a bread maker last Christmas season, model is B2300, I didn't open it until yesterday. After I read all instruction and put everything into the container, and trun on the power,...
If the sound you heard was a faint "clicking" sound that just means your machine was starting to warm up. Since you have no experience with bread machines yet you need to build up your confidence. Recommend you go to you tube and type in "how to bake bread in a bread machine" and watch some videos there to see how it is done. Don't give up on your machine! They are a lot of fun!
Mar 21, 2011 | Black & Decker B2300 Bread Machine
The program menu has rubbed off my machine, can
1 Basic
2 Turbo
3 W.Wheat
4 W.Wheat Rapid
5 Sweet
6 French
7 Cake
8 Nil
9 Bake
10 Scone
11 Pasta
12 Dough
Jun 01, 2010 | Kitchen Appliances - Others
I need a manuel for my bread maker chefmate hb-12w
Here's the instructions for Model HB-215. Source =>
http://www.globalgourmet.com/forum/index.php?topic=47.msg222
The post below this post says Chef Mate - Models HB12W, HB215 and CM725 only! So, it might be the same instructions.
Chefmate Bakery Oven Model HB-215
Modes:
  • Standard 1.5 lb normal crust: Bakes a 1.5 lb basic loaf of bread in 2 hrs 30 min.
  • Standard 1.5 lb dark crust: Bakes 5 min longer.
  • Standard 1 lb normal: Bakes a 1 lb basic loaf of bread in 2 hrs 20 min. No “dark” option.
  • French mode: Bakes a French loaf of bread (salty taste) in 3 hrs 40 min.
  • Sweet mode: Bakes a sweet flavor loaf which tastes like a butter roll in 3 hrs 40 min.
  • Doughmode: Use this mode for making dough for rolls, croissants, doughnuts,etc., which you want to bake in your conventional oven. Prepares doughin 1 hr 20 min.
Control Panel: (when pressing a controlbutton, be sure to hold it down until you hear a “Beeping” soundindicating contact has been made.
  • Display: Shows the time remaining until a mode is completed. Can also display timer setting or mode selected.
  • Select button: Push to select mode: Cycles through modes in following order:
    Normal 1.5lb -> Dark 1.5 lb -> 1 lb -> French -> Sweet -> Dough
  • Start button: Push to start processing the mode selected.
  • Stop button: (press for one second to take effect)
    Push to turn off power after baking is completed or to reset the mode or timer.
    If used after a mode is started, it will stop it.
  • Timer set buttons: Up arrow: advances timer setting 10 min each time pressed.
    Down arrow: sets timer setting back 10 min each time pressed.
Ingredient Information
  • Flour– Use flour that is marked “bread flour” or “better for bread”. (Thesewill usually be labeled as having more gluten than regular flour.)
  • Dry Skim Milk – This enhances the flavor and adds to the nutrition of the bread.
  • Butter – Butter adds a rich flavor to the bread and makes it soft.
  • DryYeast – Yeast is necessary for causing the dough to rise. Select readyto use yeast which needs no preliminary fermentation. Use only activedry yeast. Don’t use 50% faster dry yeast.
  • Sugar – Sugar speeds up the dough rising process, adds flavor, and makes the bread soft and the crust brown.
  • Salt – Salt controls the activity of the yeast and makes the dough firm.
  • Water– Gluten is formed when flour is mixed with water. This allows thedough to rise by retaining air. The amount of water and its temperatureare very important. Usually, the water temperature should be between 68F/20 C and 77 F/25 C. When the room temperature is over 82 F/ 26C, usecold water (about 41 F/5 C). When the room temperature is under 50 F/10C, use lukewarm water (about 100 F/38 C).
Operating Instructions
Baking a standard loaf of bread using Standard Mode.
Ingredients for 1 lb loaf for 1.5 lb loaf
Water 7 ½ ounces (210ml) 9 ½ ounces (270ml)
Bread Flour 2 1/3 cups 3 cups
Dry Skim Milk ½ tablespoon 1 tablespoon
Sugar 1 tablespoon 1 ½ tablespoons
Salt 1 teaspoon 1 ½ teaspoons
Butter 1 tablespoon 1 ½ tablespoons
Dry Yeast 1 ½ teaspoon 1 ¾ teaspoons
1. Open the lid and remove the bread case (hold both sides of handle and turn counterclockwise.
2. Position the kneading blade on the drive shaft. (remove any crumbs from drive shaft.)
3. Place ingredients into the bread case. Add ingredients in the following order:
Pour in the proper amount of water.
Add the flour, sugar, salt, butter, and dry skim milk – in that order.
Place the dry yeast on the center of the flour.
Note:When using the timer, make a hollow depression in the ***** of flourand pour the dry yeast into it. Do not let the yeast touch the water orthe dough may not rise properly.
4. Place the bread case into the body of the baker. Turn clockwise to lock
5. Close the lid.
6. Plug in to outlet. (after being plugged in the number “0 00” will flash in the display.
7. Setthe standard mode. Press the select button to set the mode to Normal,Dark, or 1 lb, depending on your preference and the amounts ofingredients used.
8. Start. Press the START button. The timereadout in the display will begin counting down the minutes from theamount of time required for the mode you have selected.
Steam may rise from the vent on the back of the lid during operation.
When baking is finished, the buzzer will sound three times and the display will read “0 00”
9. Removingthe bread case. When the buzzer stops, press the STOP button and openthe lid of the baker. ( The heater in the unit will keep operating tokeep the bread warm for a while after baking is complete. When removingthe bread case, always be sure to press the STOP button to turn off theheater.) Using the handle and oven mitts, remove the bread case. Thehandle and bread case will be very hot. Do not place the heated breadcase on the body of the baker, table cloth, or plastic surfaces.
10. Removing the bread from the bread case.
Usingoven mitts, turn the bread case upside down and gently shake it toremove the bread. The surface of the bread case is slippery, so be sureyou have a firm grip.
If the bread can not be easily removed, turn the drive shaft on the bottom in both directions so loosen the bread.
Place the bread on a wire rack or similar surface to cool.
Note: when baking is completed, remove the bread as soon as possible. If leftin the case for a long period of time, its surface will become stickyand the flavor will be lost. If the kneading blade comes out with thebread, use a plastic or wooden utensil to remove it. CAUTION: it willbe hot.
11. Remove the plug from the outlet.
Baking a French loaf of bread using the French mode
Follow the above instructions, except select French mode in step 7 and use the following ingredients in the order shown:
Water 9 ½ ounces (270ml)
Bread Flour 3 cups
Sugar 1 ½ teaspoons
Salt 1 ½ teaspoons
Butter 1 ½ tablespoons
Dry yeast 1 ¾ teaspoons
Baking a sweet flavor loaf of bread using the Sweet Mode
As above, but select Sweet Mode in step 7 and use the following ingredients in the order shown:
Water 7 ounces (200ml)
Egg (medium size) 1
All Purpose Flour ½ cup
Dry Skim Milk 2 tablespoons
Sugar 2 tablespoons
Salt 1 ½ teaspoons
Butter 3 tablespoons
Dry Yeast 1 ½ teaspoons
How to use the timer. (The timer function cannot be used with Sweet or Dough modes)
The timer extends the time from pressing START until the baking completes.
1. Place all ingredients into the unit and plug it in.
2. Select the desired mode
3. Press up arrow once. The normal time for that mode will be displayed: 2:30 for a standard loaf.
4. Keep pressing up arrow (or down arrow) until the desired time to completion is displayed.
5. Press the START button to start the delayed timing.
Preparing a dough for handmade bread using the Dough mode.
1. Follow steps 1 through 6 for standard loaf. Select Dough mode in step 7.
2. Press START to begin the dough making process. It will take 1 hr 20 min. The display will show the time remaining.
3. Thebuzzer will sound 3 times to let you know the dough is ready. Take itout and shape it as you wish for baking in a conventional oven.
4. Unplug from outlet.
Dec 30, 2008 | Kitchen Appliances - Others
How to select settings
I have posted a link to the manual on Fixya
Also try contacting manufacturers at
http://www.sunbeam.com/
best wishe s
Alleluia
PTL
Dec 04, 2007 | Sunbeam 5833 ExpressBake Bread Maker
Looking for manual of a chefmate bread machine
I have a manual for CM 725 if someone still needs it.
Sep 20, 2007 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
