Question about Coffee Makers & Espresso Machines
Franke Triflow leaking tap
The pure water tap on my Franke Triflow is constantly dripping. Any ideas on how to remedy?
SOURCE: Franke Little Butler instant hot water dispenser
I have the same unit and had a similar problem. If yours is the same as mine, look at the top of the water heater unit. The center spigot is for the for the how water outflow which is connected to surgical type rubber tubing. The hot water eventually dried out the tubing and it cracks, causing it to leak. I had to cut out the decayed portion and replace it. Franke sent me a replacement kit at no charge but I did replace the fitting on top of the unit. The fitting is a standard nipple that any HW store should carry. Mine is a female-to-female reducer that then mates to a nylon barbed fitting which the tubing goes into. Importantly the Franke supplied kit has nylon ratcheting hose clamps that keep the tubing in place as well as a barbed union with hose clamps to join to the exisiting hose feed (to the faucet).
Hope this helps! I'm now struggling with the hot water tap leaking after using it. It seems to stop after a while but it drips for some time. If you can help me there that would be great!
Posted on Nov 22, 2008
larryyb
  • 291 Answers
SOURCE: drip pan
the drip pan is built into the bottom and dont come out ,,, check the drain pipe to make sure its still sticking in the pan ,,,, also check the bottom inside of your freezer, drain may be stopped up and causing water to come out front edge of door / larry
Posted on Dec 13, 2008
  • 148 Answers
SOURCE: Leaking Kitchen Tap
I am assuming that your kitchen tap is leaking through the spout
if it is single lever you will need to remove the crown and spout by removing a small erasure size cap on the housing right under the spout or up near the back of the ever then use a hex wrench to remove the set screw( plug the drain holes do it does not go down the drain)
turn the water off (hot and cold ) under the sink
remove the set screw and lift off the lever
at his point you can take an adjustible wrench(channel lock and tighten the big ring nut that holds the cartridge in place
temorairly put the handle back on and put the handle in the off position turn the water on under the sink and see if it stopped leaking
if it still leaks you have to turn the water back off and remove the lock nut then the cartridge and go to big box store with old cartridge and name of mfg and get a new one and install
If you have seperate hot and cold valves on top of sink deermne which is leaking by turning one off with oher on undr the sink
once you have determined which it is (hot or cold)
take a phillips head screw driver( remove plastic clear cap on top of faucet handle with sharp crewdriver of knife blade) and remove the screw holdin the handle on to the stem(turn counter clock wise
be sure to turn water of under snk on both faucet risers after removing acrylic handle you then take an adjustible wrench and remove the crown nut turn counter clockwise until it comes off over stem
remove stem( looks like size of a pretzel about six inches long with washers on side and one on end
take the stem to local hardware(ace) or big box store and go to lumbing section ask clerk to inspect and recommend replacement washers or replacement stem (if needed)
go back reinstall and tighten crown nut snug( open (turn counter clockwise) tem valve before you snug it down with crown nut
install acrykic or chrome handle with brass phillips screw then ut cap on and turn on water and check for leaks
good luck
Posted on Dec 30, 2008
  • 198 Answers
SOURCE: Water Dispensor leak on Whirlpool Refridgerator
The solenoid valve needs replacing, located at the back of the refrigerator. If you have well water you will need to install a filter on the supply line.
Posted on Jan 05, 2009
garing
  • 998 Answers
SOURCE: water leaks from the pure source filter
vaseline on filter threads and tighten...thumbs up...
VE6GAR 73 88 99
Posted on Aug 10, 2009
Constant drip of water on my Franke manor house gooseneck bridge faucet. how do I repair the faucet from dripping water?
Check the washers and o rings that are a part of the faucet assembly. If possible tighten fittings.
Aug 23, 2017 | Franke Plumbing
My Franke FF-200 faucet does not swivel -
get the water main turned off , drain faucet then take top of tube off carefully. get a tub of vasoline and grease it put it back together and turn on water
Feb 13, 2015 | Franke Plumbing
Dripping water
pure water is the A/C condensate drain
google that.
its normal
typing...
https://www.google.com/webhp#q=condensate+drain+cars
if not pure water its bad. pure clear water.
for sure.
Jan 11, 2014 | 2002 Toyota RAV4
Constant drip in the Moen Renzo
turn of the water at the mains waer for the house before proceeding
unscrew the nut under the tap handle to remove the tap handle
look inside for a copper or plastic rod lift it out
you could try your fingers or a set of pointy nosed pliers
this will have a leather or plastic washer attached at the base
hope this helps
Nov 27, 2011 | Moen Plumbing
I have a samsung triflow sw80asp. Water flow is down to a trickel with no explanation - no code come up and pressure has not changed. any ideas on what it is
your water inlet pipes usually have some sort of filter in the end that screws onto the tap / faucet. Turn the tap off, turn the machine on to relieve the pressure in the hose then turn it off again. Remove the hose from the tap and the filter and use something small to remove the filter and clean. Put it all back together and it should all work.
Oct 08, 2011 | Samsung Washing Machines
Hi, Franke Saphira. 'Empty Drip Tray' message doesn't shift when in descale mode - not in any other mode though, only when trying to descale. Any ideas? Cheers
If you keep the empty drip tray message, especially after making a drink or cleaning operation this points to a leak internally on to the drip tray contacts. or from the thermoblock leaking onto the wiring loom behind the front door panel. An engineer will be required to fix this as the correct seals will be needed. I have been a Franke Service Engineer for 15 Years.
Sep 29, 2010 | Franke Saphira Espresso & Coffee Maker
Water leaking (dripping) into the drum when machine is off. Drip is coming from where water dispenses into the machine to fill the drum.
Hi just read your posting.The fault with your machine is a faulty water valve.1st turn off the cold tap to the machine and leave for a couple of hrs.If the dripping stops you have a faulty cold valve.If the dripping does not stop then turn off the hot tap and that should stop the leak.Either way to fix this fault a water valve must be replaced.Or you can stop the drip by just turning the taps off after the washing has finished.Hope this helps and please reply for further help if needed.
Jun 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Slow drip near back of lid
Hi there.this may be water dripping from the injector tube where the water actually enters the bowl.It is normal to drip for a short while after the machine has just been used but if it is a constant drip then you probably have a faulty inlet valve.Try this,turn off one of the taps & see if dripping stops.if not,turn off tha other tap & see if it stops.this will tell you which of the valves are leaking.You could just turn the taps off after use,that would save having to replace it.Hope that helped you.if not then give more detail if possible please.cheers!
May 29, 2010 | Fisher and Paykel GWL11 Top Load Washer
Apr 13, 2008 | Franke WD751B GPS Receiver
Coffee Makers & Espresso Machines Logo
85 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
