Question about Maytag Dishwasher Timer Kit - 12001152
Replace timer on Maytag washer
Request instructions to install
  • Anonymous Jan 26, 2009
    the timer on my maytag dishwasher model #mdb7601awb will not count down.dishwasher runs longer than it should. the timer control is the problem right?
I no longer need your service. Thank you.
Posted on Jan 13, 2009
Maytag top load washing machine repair
It sounds like your Maytag (now owned by Whirlpool) Actuator needs to be replaced. Last year our Maytag Centennial top loading washer Model MVWC300XW0 would not drain all the water and cloths would be soaking still. Doing some online research, I came across some very helpful video regarding replacing your Actuator.
The only thing I would recommend to future installers is get your Technician Manual located just inside the case (front panel) first of your Washer. The Technician Manual is taped inside your washer in a plastic bag. Once you replace this Actuator part, I recommend that you run the Calibration cycle on your washer. It is needed anytime you replace a motor, motherboard or pump.
Here are two videos describing how to change/replace the Actuator but these videos are basically for the MVWC300XW0 model. I'm sure if you search for your model, there will be other videos as well.
Two videos on how to replace your Actuator:
1: https://www.youtube.com/watch?v=YVjTY-Hj4jw
2: https://www.youtube.com/watch?v=yTHryoT78pA (This is video that I viewed the most)
Best of Luck!
Jun 05, 2016 | Maytag Washing Machines
Maytag washer MAH4000AWW timer will not advance. Washer will operate if I manually advance timer. Have changed timer, followed Drive System diagnostic test, the wax motor and control board were replaced a...
there is a motor inside the timer that turns the knob. the problem must be the replacement timer. was it a brand new timer from maytag or a 2nd hand? also double check your timer is connected correctly.
Nov 08, 2013 | Maytag Washing Machines
Maytag Stack MLE2000AYW Washer Timer Won't Advance
If manually turning the timer allows it to spin and drain, then I would say the used timer installed was also defective. Try a new timer. You will save money if you get it online or go to an appliance parts store like "Mid-America Appliance" rather than Sears or the likes. Hope this helps.
Jul 06, 2012 | Maytag Neptune MLG2000A Front Load Stacked...
I have the maytag washer mav 7000 aww; The Timer does not work automatically but works when moved by hand to each function. This is a 120 volt 60Hz machine and since i stay in a country, where we...
Open the control console.
Use a voltmeter to test the timer motor.
Set the machine to wash.
Place the meter leads on the 2 timer motor wires.
If you read 120 volts and the timer does not advance,the timer motor is bad.
The complete timer will need replacing.
Sep 22, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Using washer with 50Hz instead of 60Hz electricity--what does it
what you need is a frequency convertor. most modern day electrical equipment is 60 hertz. motors and transformers tend to burn up if the frequency isn't correct. they generate a lot of heat which burns them up.
Oct 23, 2009 | Maytag Washer Timer - 22004015
MY MAYTAG ATLANTIS WASHER KEEPS WASHING RIGHT THROUGH THE RINSE AND SPIN CYCLES. I HAVE TO MANUALLY TURN IT TO GET IT TO START DOING THE RIGHT THING.
Hi, your timer motor not working,(burnt) or could be mechanical fault in timer, but first replace timer motor, check for timer motor, give appliances store model & serial no. for washer, and let me know when you get it, i will guide you, to install it, yes you can, it's not that complicated. don't forget asked for timer motor. good luck.
Aug 08, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer is over filling.
AV,
Yup! I know what's going on (the tip off was when you said, "The water does stop when I push the timer off"). See? the timer, as I'm sure you know, supplies or "directs" power to each component in the washer... kinda like a conductor does an orchestra. When you push the timer knob to "Off", you shut down the symphony thereby removing power from all of the components. Make sense?
When you set the water level and pull the knob, the level switch tells the timer that the tub is empty and request water. The timer complies and sends power to the water valve. When the water level is "satisfied", the level switch tells the timer to remove power from the valve and start the "agitation" cycle.
Here's what's happening, the level switch isn't talking to the timer. I think the part number is 22002705, but I'm not sure because I don't have the full model number. Call you local appliance retailer and provide them with the full model number to be sure, OK? Since you already have the machine apart, it'll be easy to replace...
Oh yeah, here's a picture of it... see if this one matches the one on you machine. This might confirm the part number.
And another thing, now that you've experienced a washer flood (ain't it fun?), you might want to consider getting yourself one of these. They're super easy to install and it'll provide that extra bit of insurance against this happening to you again.
Don't forget to rate this solution. And thanks for using FixYa!
SG
May 30, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Dishwasher Timer Kit - 12001152 Logo
559 people viewed this question
Top Maytag Hardware & Accessories Experts
Hippy_dd
ray gallant
Are you a Maytag Hardware and Accessory Expert? Answer questions, earn points and help others
