I have acer aspire 5733z and sometimes it shutdowns automatically while working, and keeps on repeating the same and then when i try to restart it, it boots a bit and then shutdowns again 2-3 times, what to do :(
  • 32,281 Answers
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Posted on Dec 05, 2012
  • 104 Answers
SOURCE: automatic shutdown without notice
its because CPU get hot. check the cpu fan or
clean that, heatsink of cpu fan must be clean and closed to cpu.
Posted on Aug 01, 2009
Larrysito
  • 73 Answers
SOURCE: laptop fails to boot screen appear then goes black
posible owerheating need proper check
Posted on Aug 30, 2009
  • 17 Answers
SOURCE: keeps restarting
CHECK WHEATHER SYSTEM IS BOOTING OR NOT GO TO BIOS CHECK WHEATHER HARD DISK IS DETECTED OR NOT.
Posted on Sep 09, 2009
miles_fumo
  • 10 Answers
SOURCE: My acer aspire 4315 turns white screen anytime am using it.
The best solution is to Download a program Called ''Screen Mode Switch". It's a program that lets you switch between screen resolutions by pressing keyboard combinations. Instead of having to shut down your PC or put to sleep you can save a lot of time by switching the screen resolution back and forth conveniently. It's the best and only software alternative. You can download the program here ->http://www.download32.com/screen-mode-switch-i60507.html
Posted on Nov 16, 2010
  • 693 Answers
SOURCE: how to connect the wifi to a acer aspire 5733z -
Check the wireless router and high-speed modem. If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
  • 2 Activate the wireless Internet connection on the laptop computer. Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu. Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
  • 3 Select the appropriate network you wish to connect to. Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire. Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
  • 4 Restart the computer. The system may have booted and failed to detect the wireless receiver. Restarting the computer corrects this issue.
  • Posted on Oct 09, 2011
    Starts, 3 secs, turns off, restarts 3 secs repeats
    Try removing the battery and restart. Could be a bad memory module, fan not working, CPU going bad, graphics chip overheated and going bad. I assume it is out of warranty so you might have to take it to a repair shop.
    Feb 13, 2014 | Acer Computers & Internet
    Webcam is not working
    Hey Joseph,
    If you DO HAVE an acer aspire 5733z, then here is a direct link to the web cam drivers from Acer
    Copy from here -- >http://global-download.acer.com/GDFiles/Application/Camera/Camera_Cyberlink_1.0.1523_W7x86W7x64_A.zip?acerid=634406900772581500&Step1=NOTEBOOK&Step2=ASPIRE&Step3=ASPIRE 5733Z&OS=ALL&LC=en&BC=ACER&SC=PA_6<--To here
    Don't click the link as it doesn't appear to have created the complete link when I pasted it in, instead copy and paste it.
    Sep 26, 2013 | Acer 5733z-4851-Aspire 5733z-4851 Intel...
    Acer manual
    http://www.manualslib.com/products/Acer-Aspire-5733z-4851-2334114.html Here you go!
    Aug 28, 2013 | Acer Aspire 5733z-4851
    My web cam and microphone is not working due to the absence of proper driver
    Download the device drivers from the Acer WEB site. Make sure you select the model of your laptop the drivers you that require that matches the Windows version that is installed on your laptop. Use this link to get to the Acer support: -
    http://www.acersupport.com/drivers_download.aspx
    Sep 02, 2012 | Acer 5733z-4851-Aspire 5733z-4851 Intel...
    Acer aspire 5733z not working
    Go to the BIOS configuration screen and tell the computer to boot from the DVD first, and hard drive second. Look for the "Repair Install" option n the install CD startup screen. If that doesn't work, you can at least start over with the installation.
    I hope you backed up all of the work-related material before you started installation; If not, you may have to make a Linux trial/install memory stick and use it to copy your Documents folder to an external hard drive. Post a request for info on this to the comments if you need to do this (for example, if you wind up formatting the hard drive and doing a clean install of Windows 7).
    Jul 14, 2017 | Acer Aspire 5733Z 15.6 Inch Laptop Intel...
    I can't do a video chat because the program that facebook use its not working what I do?
    Download that program again and try to reinstall. After installing you have to restart the system.
    Jun 20, 2012 | Acer Aspire 15.6" 5733Z-4851 Monitor
    The pc keeps switching itself off
    Computer Switching off can be many problem.
    Method 1 : Overheating of the system
    System automatically shutdown or restart by itself when it's overheated due to Dust or dirt contamination in order to prevent hardware burn out.
    Open your Notebook which is little tough to explain as it is different for all models.
    and get it clean with an Air Blower mainly near the Processor area,check the CPU cooling fan is working or not.Get it clean too.
    Check now if the system is working fine.
    Method 2 : Malware, Trojan, Virus infection
    Malware, Trojan, Virus infection can caused a system to repeatedly restart or shutdown as they infect svchost.exe or explorer.exe.
    Scanning the system with a good antivirus like Norton,Kaspersky internet security 2010 or A-squared Anti-Malware or Avast Antivirus with their lastest updates install can solve the problem.
    I perfer you check out the method 1 first.
    Jan 03, 2010 | Acer Aspire 7520-5185 Laptop
    Computers & Internet Logo
    111 people viewed this question
    David Payne
    David Payne
