Question about Jenn-Air Attrezzi JSM900 Stand Mixer
I have this Jen-Air 400 watts Attrezi JSM900 stand mixer. While baking last week is seized, I've only used it about 10 times and cat uderstad why this happened. Perhaps it's the fuse. I'
Where is the jenn air mixer thermal cut out
Wonder if you checked the user manual on possible causes for not turning on. see page 10.
Aug 13, 2014 | Jenn-Air Attrezzi JSM900 Stand Mixer
DORMEYER stand mixer maintenance
Sadly, the service directions, while excellent, are for a Sunbeam Mixmaster Model 12...uselful for a Dormeyer only in the most general of terms.
Dec 12, 2011 | Food Mixers
It just stopped during use and seems completely dead!
Replace the fuse located below the plug inlet on the mixer,(it is a 6.3A Fuse, 250V 5x20MM fuse from Radioshack) you have to remove the outer panel to access it. I did the same thing, it stopped working while I was mixing dough for bread, replaced it, good as new.
Aug 11, 2010 | Jenn-Air Attrezzi JSM900 Stand Mixer
Under cabinet halogen lights not working
you over loaded that section power source less expensive to replace with new lights
Feb 05, 2010 | Jenn-Air Attrezzi JSM900 Stand Mixer
Hi i just had my mixer spark and then the motor
Could be carbon brushes, switch it's really hard to call it,
Let us know how we can help you
Nov 25, 2009 | Jenn-Air Attrezzi JSM900 Stand Mixer
Here is a website for your Jenn-Air Mixer User's Guide:
Click on it take you to a User Guide in PDF format.
May 05, 2008 | Jenn-Air Attrezzi JSM900 Stand Mixer
Atttachment cleaning
that dust is from the beater shaft pin that is wearing down the can use mineral oil to clean the attachment.this problem will continue to happen until you replace the pin and attachment.
Aug 14, 2007 | Jenn-Air Attrezzi JSM900 Stand Mixer
Jenn-Air Attrezzi JSM900 Stand Mixer Logo
141 people viewed this question
Top Jenn-Air Food Mixers Experts
Oscar Netto
Oscar Netto
Dennis Boxerman
Gerry Harvey
Gerry Harvey
Are you a Jenn-Air Food Mixer Expert? Answer questions, earn points and help others
