Question about Goodmans W280NS Television
Goodmans 27 inch LCD
Hi I have a goodmans GTVL27W23HD LCD TV. Came in and the TV was dead. No hint of power. It tripped the fuses. Everything came back on but no TV. Any Ideas?
  • 1 more comment
  • James ward Jun 09, 2007
    Hi Thanks for the reply Ive tried the fuse and lead but no joy I'm afraid
  • joe456 Nov 16, 2007
    Was watching the tv, but it suddenly went off. no red or green light. the fuse is not blown, as everything else works. it is onnly 4weeks old, so i doubt there is an internal problem
  • Anonymous Feb 13, 2008
    Same problem. Worked fine for twelve months and 9 days then our main circuit breaker tripped and when re-set the TV did not work. No lights red or otherwise. Checked fuses in plug all Ok.
Dry joints ???
Fuse blowing on these is due to a transistor going open circuit, blows/trips main fuse in plug/fuseboard and pcb psu component.
Part number HA160T1A1 is no longer avaliable to replace the board after only 14 months service the lesson is you get what you pay for, go for more reputable manufactuer :(
Bad company with cheap and nasty products.
Posted on Sep 11, 2008
This cost me 90 quid to get fixed. I said to the guy "just dry joints etc. then" to which he replied "yes"
Posted on Sep 05, 2008
  • 203 Answers
Sounds like the power surge may have blown the fuse in the TV. You can replace the fuse and see if that works. If not, more damage to the power supply unit may have occurred.
Posted on Jun 09, 2007
SOURCE:
Goodmans lcd1928w
hi check the fuse inside the tv here 2 types, glass type on a metal fuse holder , or a solder in type called a wickman fuse , you may need a multimeter to test them hope it helps
regards
shaun
May 08, 2014 | Televison & Video
Hi, we have a goodmans GTVL27W23HD that was left on standby for 6 days, now will not show the digi-box channel, just a blue screen, sound only on scart 1 any suggestions anyone? something re-setting...
Try to unplug everything and plug it back in at the correct order(without power). Then plug the power and into the items in the correct order and let them power on for about 5 minutes. With the blue screen that may take about 15-20 minutes.
Apr 19, 2008 | Televison & Video
Fuse keeps blowing on power board. It is the 3.15 amp fuse on the goodmans xpro tv
Most likely you have a short on the front side of your power supply. You will either need to have it repaired or replaced!
Oct 22, 2012 | Goodmans GTVL32W27HDF 32 in. LCD TV
Goodmans HDMI. After power cut (which it is used
I just left the TV off and it must have reset itself. It did it twice. First time it was OK after half an hour. Second time it was nearer an hour.
Thanks
Jan 08, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
Tv did not turn on
Look at the power supply to see if anyhting burnt, fuse, bad capacitors. I doubt that the power cord is bad, the same size fuse should be used as the original one.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 04, 2009 | Goodmans GTVL32W27HDF 32 in. LCD TV
Goodmans crt tv dead
there is another supply missing from your power supply, chec your components on that power supply a ht of 90volts is missing,
check all active components like transistors,diodes and resistors with very small values,
if you go through you are going to win that problem, ok.
Apr 03, 2009 | Goodmans 257NS 20" TV
No sound
Have you checked that the TV isnt Muted/ Volume turned to 0 ? i would check in the menus if that is the case.
If this is not what is happening i suggest you surf over to the Goodmans website at www.goodmans.co.uk/ to see if there is any troubleshooting/FAQs on there. if not, i would call Goodmans customer Support, their number is located on the said website !
Hope This Helps !?
Oct 27, 2008 | Televison & Video
Goodmans gtvl27w23hd
Unfortunately I have several and it's just a case of trial and error. 002 // 004 // 009 // 027 // 028 // 051 // 068 // 093 // 111 // 115 // 127 // 153 // 169 // 171.
Hopefully one of those should work. Sorry I couldn't be more specific.
Feb 19, 2008 | Goodmans W280NS Television
LD3750HD
goodmansld3750hd, last comment as guest is now signed in as baldwin1972 hope i get a response
Dec 06, 2007 | Goodmans 257NS 20" TV
Televison & Video Logo
422 people viewed this question
Top Goodmans Televison & Video Experts
Steven Wander
Steven Wander
Steve Allison
Steve Allison
Colin Stickland
Colin Stickland
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
