Question about AOC 19" LED Monitor e950Swn Black
Cannot fit to screen size
I've just bought this aoc monitor and attached it to my netbook. It will not fit to the full screen size though? I've got 2 inches of black screen around the edges. I've tried adjusting the monitor settings but am not sure if I'm looking in the right place? thanks Sarah
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 94 Answers
You probably need to install a display driver for this monitor on your netbook. http://us.aoc.com/monitor_displays/e950swn
Posted on Mar 08, 2015
3 Suggested Answers
chalkperson
  • 147 Answers
SOURCE: AOC 1" - Monitor Says "no signal"
Sounds like a connection problem. Make sure BOTH plugs are securely located. Ian.
Posted on Sep 20, 2009
SOURCE: Installed AOC 2436vh, top of screen off of
I have the 2436V (no speakers), but I suspect the solution will be similar. My screen was a bit to the left of the monitor's physical display area, and I was able to solve it using the built in menu (If you take too long deciding what menu button to press next, the menu will time out. Just start over if that happens. You will get faster with practice).
1) Press the menu button on the monitor (the menu appears).
2) Press the up button on the monitor 4 times to highlight the icon that looks like a slightly angled screen with yellow cross-hairs in one corner (the toolbar for positioning the screen appears - all 5 icons on the positioning toolbar are blue).
3) Press the menu button on the monitor to "enter" the selected toolbar (one of the toolbar icons turns green to indicate the selected tool on the toolbar).
4) Select the tool you need using the up/down arrow buttons on the monitor (I needed the one that moves the screen horizontally, you need the one that moves the screen vertically).
5) Press the menu button on the monitor to activate the selected tool (the meter above the toolbar icon turns green to indicate the tool is active).
6) Use the up/down buttons on the monitor to position the screen.
7) Press the menu button to exit back out (or, just let the menu time out).
Note: the disk that came with the monitor doesn't seem to have drivers for Windows 7, but allowing Windows to search online while updating the driver found a compatible driver online.
Posted on Dec 25, 2010
AOC monitor too bright!!!
Sounds like its T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD is given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 12, 2013 | AOC 19" LED Monitor e950Swn Black
AOC i2353 has border around displayed image, not running at full 1920x1080res?
Had the same problem! Solve it: go to the AMD catalist and choose advanced look. then inside the digital display setting you'll see scalling option that will show 10% . Set it to 0%. Done!overscan.png
Oct 15, 2012 | AOC I2353PH New
Display flashes horizontal lines
It's not unusual for a monitor to use different circuit paths based on the the display resolution chosen and so, one could have a resolution that is faulty, while another works just fine. Monitors normally just get dim, or power supplies fail, or other more common failures, blank or white dots... etc.; but, should a monitor live long enough without failing in those areas, usually one or more resolutions will fail. Doesn't leave you much of an option, other than a repair shop, if one could be found; but, as long as it works at that or another resolution, and I'd check the other settings and use it if you have something where it can be used. Sorry for the not so good news.
Jul 02, 2017 | AOC I2353PH New
Change font size in e mail
The printer prints whatever it's told to by the computer. Your printer really doesn't control the fonts.
When you are printing stuff from the internet (web pages, email, etc.) the reason for the small print is that it is related to the size of the monitor and it's viewing setup (the higher the screen resolution, the smaller the print will be when printing it out even though it looks good on the monitor).
One way you can make the print larger when printing internet stuff & emails is by changing the print view size on the screen to a larger size in your web browser (this is separate from your other setting you've already setup). Go to the menu bar at the top (i.e. Internet Explorer), click on "View," then "Text Size" then select a size like "Larger" or "Largest" (something higher than what you're currently set to.)
Another method is to go to your menu bar at the top of your web browser, click on "File" then "Print Preview". At the top of the window there should be a small window with "Shrink To Fit" in it. Click the arrow for a drop down list and choose something probably above 90% or more (maybe 100 or 125%) and see how it changes the print size of what is to be printed out.
The only other method is to copy & paste the text into a text editing software like Word and adjust the text size there. If you're using a text program, then you simply adjust the size of the text to a 12 or 14 point, or larger, font size (adjust depending on the font and size you need) and that should do the trick.
Apr 21, 2012 | Canon PIXMA MP470 All-in-One Printer
I cracked my screen a while back and started using a monitor for my screen, which i had no problems with what so ever. I bought a monitor off someone, as they were seeing which monitor was best they were...
I'd check the ext. monitor port for bent pins, or possibly even a broken pin - if it's bent you can probably straighten it out (very carefully using tweezers),; if it's broken then it's toast - that's pobably why you ain't getting a signal on the external.
The 2nd hand screen is either no good or improperly installed or it might not be compatible (I've seen incompatible screens where the brightness control adjustments are just ... reversed - i.e. dim means brighter, and brighter means dimmer). eBay is a pretty good source for these things (used, original stuff) so I'd check there if I still have access to the original screen (the cracked one). Check under Samsung N130 and you should see plenty of screens that are being parted out...
Sep 05, 2011 | Computers & Internet
I have a AOC L520 MONITOR and the touch screen doesnot work.Were I can found the software?
Here, from the manufacturer's website.
ftp://ftp.aoc-europe.com/Drivers/LCD-monitors/LM520&LM520A.zip
Rulan
Jun 16, 2011 | AOC LM 520 15" LCD Monitor
I have an aoc 2019sw1 monitor. When ever I try turn it on its works perfectly for a few minutes then turns off. I cannot press the power button to turn it back on, have to plug out cable then try. This...
It sounds like you've got a diode overheating in the power supply, triggering a self protect shut down. Given the cost of repairs, unless you're qualified to do the repairs yourself, it'll be less expensive to purchase a new one than to fix that one.
Jun 15, 2011 | AOC 2019SW1 20" Monitor
I just installed hasbro classic game collection on pc i have a 19" widescreen aoc monitor and when i try to play monopoly i can not see the whole picture it is like it is long and narrow and the game will...
before you start your game, you can try to modify your screen resolution and then start the game it will fit to the new screen size.
depending on your OS (winodws)
WIN XP close all windows and place your mouse over your desktop right click and select properties. a windows will pop out with the following tabs THEMES, DESKTOP, SCREEN SAVER SETTINGS.
click on settings and you will see a computer screen(s) and it will be a place to change the SCREEN RESOLUTION (800x600) (1024x768) etc try a diffrent one from the one you are using and click apply and then OK. run the game, if it persist just try a different size.
WIN VISTA click on desktop area and sellect PERSONALIZATION, click on Display settings and change the RESOLUTION.aplly and ok.
if my advice was of any help please rate me :)
thank you
Oct 07, 2009 | AOC 22" Widescreen LCD Monitor
Aoc monitor set up
re install the drivers for garphic card or video card of your computer
thankyou for using fixya and dont forget to rate the solution
have a nice day
Feb 19, 2009 | Computers & Internet
Pincushion and h size problem on aoc 17" 771s
one of the buttons on your monitor is partially shorted. trust me, ive encountered this problem many times.
Jan 03, 2009 | AOC CT720G 17" CRT Monitor
AOC 19" LED Monitor e950Swn Black Logo
138 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
