Question about Sportsart 6300 Treadmill
SportsArt 6300 error display 04 -0015 help...
Helpppppp
    Top Expert:
  • Sportsart Master
  • 12,223 Answers
The power supply is receiving too low or higher currents.You must test this. Or you need to call the service tech. However try to RUN the s. calibration if you can. Otherwise reset the machine. and see the block diagrams attached.
God bless you
SportsArt 6300 error display 04 -0015 help... - 12_5_2012_10_06_30_pm.gif12_5_2012_10_08_03_pm.jpg
Posted on Dec 05, 2012
4 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: My SportsArt 6300 suddenly accelerate from 4
Dear Sir:
Hello, I will try to help you, inmediately.
Please follow the next step:
1) Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be
on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack
bolt models will have flat mounts and may contain up to four bolts.
2) Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel
with the drive and walking belts. If your treadmill is not equipped with this bolt, . If your
treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16"
wrenches, make a few turns to this bolt, tighten the bolts from Steps 1 and 2 and test your treadmill for
slipping. If belt continues to slip, repeat Steps If a second attempt does not repair the problem
3) If you have arrived at this step, let's make sure you have a drive belt tension problem. With the motor cover
removed, walk on the belt normally and try to stall the belt to make it slip. Be careful during this test. If the
problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when
stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem
is with the walking belt slipping on the front roller. If the drive belt continues to turn but the front roller stalls,
you may have a broken front roller pulley. If this is the problem, you will notice it because the plastic will
usually make a loud squealing sound on the metal front roller. The entire front roller assembly repaired or
replaced (see the help topic on replacing a pulley) and the drive belt must be replaced. We suggest
replacing the drive belt as well because it is a low cost item and will most likely, have suffered unusual
wear from the problem. Another possibility is that the drive belt has worn down. In some cases, belt
dressing may help correct the problem. If not, the drive belt must be replaced.
Please check this video:
http://www.youtube.com/watch?v=yX_0vRPdMfU&feature=related
http://www.youtube.com/watch?v=zXeHMWTcLUY&feature=related
E.CUADRA
MANAGUA, NICARAGUA. C.A
Posted on Oct 13, 2011
maxtreadmill
  • 832 Answers
SOURCE: SPORTSART 6300 SHOWING E 1
Error 1 come up when the drive motor is not moving. Unplug unit then remove motor shroud then plug unit back in and you will see a circuit board with multiple lights. On Lower portion of the board you should be able to see a amber LED this is your speed sensor light . To test the speed sensor just manually rotate motor fly wheel ( where Drive Belt is visible) and you should be able to see the amber light flickering that means speed sensor is good. Next thing to do is unplug unit and check the motor they sometime get stuck in their chamber so be gentle pulling them out and blow out the excess carbon material out of motor wear a mask when doing the black dust can be much then re assert motor brushes and it should take care of problem. If they are worn (less than 3/8 in. in length) then call Sports Art @1-866-709-1750 the people their are good to work with and any further question they will be able to answer.
Posted on Feb 28, 2010
maxtreadmill
  • 832 Answers
SOURCE: I have a sportsart 6300 that keeps blowing up Q2
The bridge rectifier is shorted with gives Q1 and Q2 the appearance of being shorted and blowing the 15 amp ceramic fuse
Posted on May 13, 2010
Sportsart 1050l gives error 1
ERR1 Definition: The display board CPU didn't receive the optic sensor signal. • Explanation: After processing by the drive board, the optic sensor signal travels the 16-pin cable to the display board CPU, which determines motor speed. Components involved include the optic sensor, optic sensor wheel, 16-pin cable, drive board, display board, and connections. http://www.sportsmith.net/images/product_support/sportsart/Repair%20Manuals/General%20Treadmill%20Svc%20Manual.pdf
Aug 01, 2014 | Sportsart Exercise & Fitness
What is E-1 error in Sportsart Tradmills
Jun 23, 2014 | Sportsart Treadmill Doctor Walking Belt...
Need an owners manual for A sports art 6300 TR 63
Go to SportsArt America.com click on support drop down and click on manuals click on owner's manuals scroll down treadmills and half way down you will find t6300 owner's manual
Sep 16, 2011 | Sportsart 6300 Treadmill
I need an owner's manual for a Sportsart 6300 commercial exercise treadmill. I purchased a used one and it appears to be a terrific machine. I have mostly figured it out on my own, but a manual would still...
Click on the following link:
http://www.sportsartamerica.com/saf/support/technicalsupport/owners_manuals.asp
Select the 6300 Treadmill under COMMERCIAL PRODUCTS.
Save the file somewhere on your computer.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there.
Otherwise just unzip and open the file.
If this was at all helpful please click on the 4 Thumbs Up helpfulness rating icon you see on this page.
Thank you very much and good luck.
Mar 12, 2011 | Sportsart 6300 Treadmill
Hello. My sportsart give's error 7 ? I don't now what the problem is. Can you discribe the problem en the solution for this? Thanks Gert Jonker
When I turn on the machine it beeps and reads Error 7 on the screen. Do you have a support phone number for Australia
Feb 12, 2011 | Sportsart 6300 Treadmill
E6 error - incline not responding. Replaced 1A fuse but still not working
I'm getting the same E-6 error while running in program mode although the fuse is fine - and when I recycle power, the program starts fine again and then stops in the middle with the E-6 error. Nor sure what's wrong. Just sandpapered the fuse ends and the connector ends to the fuse socket. We'll see how it goes.
Dec 14, 2010 | Sportsart 6300 Treadmill
Sportart 6310 treadmill - check speed sensor
Unplug unit and check the motor brushes they maybe worn and need to be replaced call Sports Art Fitness customer service @ 1-866-709-1750 they will sell you the brushes
Mar 13, 2010 | Sportsart 6300 Treadmill
I have a sportsart 6300 that keeps blowing up Q2 and Q3
Jul 12, 2009 | Sportsart 6300 Treadmill
Sportsart 6300 Treadmill Logo
138 people viewed this question
Top Sportsart Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Steven Brandon
Steven Brandon
Sportsmith LLC
Sportsmith LLC
Are you a Sportsart Exercise and Fitnes Expert? Answer questions, earn points and help others
