Question about RCA RC5510P DVD Player
RCA TO VGA
Hey guys ,I was wondering if there were any plugs that would convert an RCA signal into a VGA signal, you guys cann tell me if it is possible and if so could you please tell me where I can find them.
I want my picture of my dvd player shown on a computer monitor
  • 4 Answers
Hey. This is little pricey(around $50) but will do exactly what your looking to do. http://cgi.ebay.com/4-Channel-Composite-Video-to-VGA-Converter-Switcher_W0QQitemZ350169399689QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item350169399689&_trksid=p3286.c0.m14&_trkparms=72%3A1234%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
Posted on Apr 27, 2009
I want to connect my computer to sony wega triniton kvxr29m80 from the hdmi or vga port to the tv's component or 3rc ports. is it possible..i have tried the hdmi to component cable and it does not...
An HDMI to component video cable will not work. These are meant for projectors that work with computers and have only component in jacks.
You will need is a VGA to Composite video converter, VGA to component video converter or HDMI to component video converter. These translate the computer output to the input the TV will understand. Here are some VGA to component video converters: http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215-p1.html . (The exception is if your computer has a TV-out port. In this case, you need an adapter that looks like an S-video plug that will then have composite or component video jacks.) If you want to use the TV speakers, you will also need a 3.5 mm to 2 RCA audio adapter (either M and F/F for an RCA cable to the TV or F to M/M for a 3.5 mm audio patch cable) or cable (3.5 mm M and M/M RCA).
I hope this helps.
(A computer gives RGB output on the VGA cable; the TV reads PbPrY on the component video. Thus you need for the converter rather than a simple adapter. Similar communication differences apply on the HDMI signal.)
May 11, 2012 | Sony Televison & Video
Hi there, i was just wondering that, my hdmi monitor which is goodmans GTVL19W17HD monitor and it has a HDMI slot, but my graphics card doesnt, instead my graphics card has a vga and dvi slot, and if i...
Hi hassy786,
Regarding your question if you will use a converter from VGA to HDMI will it provid High Defenition video?
I believe that it will provdie video converting the signal from VGA to an HDMI connection but I do not think that the video will be High Definition since the VGA is just being converted to HDMI signal and not an actual HDMI but just a converted signal, and it is possible that it may not work properly or the LCD TV may have difficulties recognizing the signal from VGA converted to HDMI.
Thanks for chosing Fixya,
avf110686
Mar 27, 2011 | Goodmans GTVL19W17HDF 19 in. LCD TV
CAN I connect 2 tvs.to one converter box and how.
If you're using a box that has an RF (antenna) output on channel 3 or 4 to the TV, you can insert a splitter and feed two sets. A splitter looks like this:
It takes the signal in on the single connector side, and splits it between the two output jacks on the other side. You can find splitters at TV retailers, Radio Shack, and even at Home Depot or similar stores in the electrical section. Run a cable from each of the output jacks to the antenna connectors on the two TV sets. Each TV will need to be tuned to the converter box output channel, and both sets will get the same program (whatever channel you have selected on the converter).
If the converter box has audio and video output jacks and the nearest set has an AV input, you can connect that set with the same kind of cable you use to hook up a DVD player (RCA plugs on the ends) and select the AV input to see the converter box signal. You would run a cable from the RF output connector of the converter to the second set's antenna jack. Then you wouldn't need the splitter, and the set using the AV inputs would get better quality picture and sound. Again, each set will get the same program as determined by the converter.
Hope this is what you need to get going. Thanks for using Fixya!
Dec 17, 2010 | RCA Analog (RCA) to Digital (VGA)...
I connected my computer to my TV via a VGA to RCA component cable and no image is showing up on the television.
I have two suggestions. First, make sure your TV is set up to receive inputs from the RCA jacks you're plugging the cable into. Second, you may have to change the screen resolution on the computer to something the TV can handle. To do this plug the VGA cable back into your normal monitor. Right click in the field. Left click on properties or personalize, depending on your operating system. Then left click on setting or display settings. There should be a slider bar where you can change the screen resolution. I'm guessing it's probably set too high for your TV. Try reducing it and then plug the VGA cable back into the RCA jack converter. I hope this helps you out.
Sep 29, 2010 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Need to get a torpedo projector to work with laptop
Unfortunately, there is no simple VGA-to-RCA adapter cable if you're connecting to a composite video input (usually colored yellow) or s-video input. VGA output is separate red, green and blue video and synchronizing signals, and they all need to be combined. You need a VGA-to-video converter to do this.
If the projector has component video input jacks, then you can buy a simple adapter cable.
Hope this helps. Thanks for using Fixya!
Feb 19, 2010 | Radio Shack Cinego D-1000 Multimedia...
How can i get video out signal in one rca plug from my card?
radio shack sells a converter box to change vga into rca composite.
Nov 16, 2009 | Sapphire ATI RADEON X1300XT 512MB...
Microwave ovens and digital converter box??
Disconnect the converter box power and all and see if the Microwaves work.
If they do Try to sheld the converter box with a steal box large enough for the unit to sit in and close. see if the ovens work. plce in the the ovens in a different wall socket that is on a different line or circuit breaker
Is it possible that the RCA converter box slid und the FCC regulatory door and the unit has enough of power for cross talk interference
Wow you have an orange tree that grows apples onb a different stem. Rare and unusual save it all for postarity
Jul 27, 2009 | RCA Analog (RCA) to Digital (VGA)...
NO channels now, we had some before!!!!!
Here is how you should have it connected.
1- Antenna (rabbit ears or whatever)
2- Converter box
3- Television
When you turn on the TV and the converter box, go to channel 3 on the TV. You should see the converter box signal there. If you do not see it try channel 4. Bring up the convert box menu and go through the AUTO SEARCH, not manual search. Now your box will search all the frequencies and add any stations that are in your area. Make sure you change channels with the converter box, not the tv. An antenna on the roof will still provide somewhat better range, but even rabbit ears will likely pick up something. If you still get no channels you could be too far away, digital signals have a shorter range than analog signals. You can check your local TV stations website or call to see if they are broadcasting digital yet.
Apr 08, 2009 | RCA Analog (RCA) to Digital (VGA)...
Connect Laptop to TV
It depends on what kind of TV you have. If you have a flat-panel LCD or plasma TV, it may have a VGA connection already installed. If that is the case, all you need is a standard VGA cable to connect from your notebook to your TV.
If you have a TV without a VGA connection you will need a scan converter to convert your signal from VGA to RCA or composite video signal. These can be purchased online or from electronics stores like Radio Shack. You plug your VGA connection from the computer to the scan converter, then RCA or composite video cables from the converter to the TV.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 16, 2009 | HP Compaq 8510p Notebook
Ati mobility radeon 9000 agp
hi camperd55,
I believe you have the right adapter cable. According to my knowledge the Radeon 9000 supports TV output via RCA (check http://ati.amd.com/products/MobilityRadeon9000/index.html:" Mobility™ Radeon™ 9000 provides the highest quality output support for DVI-I, TV and CRTs.")
Firstly, it would be a good idea to make sure your TV has the 3 RCA jacks into which you will insert the adapter cable's 3 RCA connectors according to the colors of the connectors and jacks.
Secondly, if your laptop has a VGA port, you're set to connect your laptop to your TV, no hustles. If your laptop doesn't have a VGA port, your going to have to get a DVI-VGA converter, so you're setup will be something like: [laptop]-[DVI-VGA converter]-[VGA-3RCA adapter cable]-[TV's 3RCA jacks].
When you get your laptop's screen displaying on your TV, its merely a matter of using your recording equipment to record the TV's image as you would any program showing on the TV.
I hope this will help you solve your problem, thank you for using the FixYa service.
Kind regards
Henru : )
kind regards
Feb 10, 2008 | ATI Mobility RADEON Graphic Card
Televison & Video Logo
62 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
