Dvds are playing in green/blue color only - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
L would try unit first on another set---if same issue then either a setting in the Player menu (read every page of owner manual) or some circuit problem in the player.
Posted on Dec 05, 2012
Whats the primary color of blue?
Please first study on color wheel to get the thorough knowledge. Then furthermore, you can read some books and play some DVDs for art lessons to get some more sound knowledge to be equipped with yourself. Check out: Art instruction books DVDs and everything you need to learn to create any...
Feb 02, 2015 | Crafts & Hobbies
The screen turns green after playing videos for 20 minures
The Video Controller works off of the RGB principal. RED/Green/Blue pixels. The mix color is dependent on the formation and density of the pixel and rates. When one or more colors are absent the only functioning color will dominate, and it is Green in your case. The screen liquid crystals in Red and Blue are failing and only a screen replacement will fix the situation.
Jan 04, 2015 | Toshiba C655D-S5200 Amd Dual-Core C-50 3Gb...
Why is there no color
If using component video out please make sure that all cables are firmly and securely connected to the player and the TV.
-Component = Green/Blue/Red cables or jacks.
If using the video out please make sure that the TV color settings are not set to grey or black and white.
If everything is connected properly I would recommend to connect the player to another TV to see if the same issue will occur. Also check the color settings on the DVD player under picture mode.
Ref: http://www.docs.sony.com/release/DVPSR200P_US_ES.pdf
Dec 18, 2012 | Sony DVP-SR200P DVD Player
Our Bose 321 Entertainment System is only playing DVDs in black and white - no color at all.
Be sure that in the setup menu, you are selected for the correct output format (either component which is BLUE/RED/GREEN + audio or composit which is just YELLOW + audio. If that is correct, I would suggest a call to the BOSE technical support center.
Sep 08, 2009 | Bose 3 2 1 GSX System
Dvd playing blue picture
if it is hooked up with componant, thats the red blue green cables for video, and red white for audio, then you probabily eather dont have the red pluged all the way in, or you have the red audio, and red video---reversed, make sure to check them on the dvd player, and on the tv, if there correct, try using the composit input, that is the yellow red and white
Jan 11, 2009 | Samsung Televison & Video
Screen is green when trying to play a DVD
I think DVD player is hooked with TV via component video input.
Check component video connections and make sure each color wire connect in same correspondence color in both units, TV and DVD Player.
Red to red, green to green and blue to blue.
Dec 18, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Color looks horrible when playing dvds. when watching tv, the color is fine. help!
U have to use a hdmi cable ok or red green blue coumpount cable ok that way get a better picture thx for using fix ya .
Feb 05, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Why do some DVDs play well and others don't?
just check the data transfer wires.may ur probles sloved
Mar 06, 2007 | Power Acoustik PADVD-150 Car DVD Player
DVD player not working right
Check your cables between your DVD player and the TV, this play has component video outputs that could possibly cause this issue.
Dec 25, 2006 | Sony DVP-NC600 Multi-disc DVD Player
On screen color
1.Check your component video connection,and see if you are any cable that is not connected properly(most commonly swamp between Pb-blue, Y-green.)
2. If the connection is correct FOR SURE,check your system menu under video connection or output and see if you have switch it to component video output.
Joe
Dec 11, 2006 | Panasonic REGION FREE SCHT700 5 Disc DVD...
Open Questions:
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
