Question about Corel Painter Essentials 4 for PC, Mac (PE4ENPCM)
How do you avoid getting paint on the ceilings when painting your walls?
Yeah that is some concern there. You use painters' tape that is used for painted surfaces. You must specify what you need so that you will not buy the wrong item. There are tapes that are designed just for painted surfaces. This type of tape will not peel off the paint on your ceiling when you remove it unlike the ordinary masking tape. You can purchase this tape at our local stores near you or you can order it online. We also have other products such as preparation products, preparation equipment, finishing and cleaning and application accessories to make your work easier and quicker. Purchase all these paint accessories at the right store and with the best price.
Posted on Dec 06, 2012
2 Suggested Answers
SOURCE: UsingCorel Paint shop pro x3. Having problem
since when are u facing this issue
Posted on May 04, 2010
What Is Roof Restoration Coating?
I am currently obtaining information on roof paints and I can share what I have found out
roof restorers use a membrane paint rather than an ordinary acrylic paint or enamel paint as it is the most resilient paint for the application
IT is applied at a pressure of 3000 psi from a special gun and paint pump, cannot be rollered or brushed and goes on to a thickness of 150 microns ( around .120")
the cost is around $400.00 for 10 litres which covers around 10 sq meters ( 3ftx3ft)
acrylic can be sprayed or rollered or brushed on and is good for about 10-15 years depending on the roof to start with (thickness around .030" --same as car paint job)
costs around $180.00 for 15 lts and covers 14-16 sq meters
namel should be avoided as it does not have the capacity to expand or contract with temperature changes
professional roof restorers will repair any problems , clean the roof off and then apply the membrane paint as it gives a good quality result
other than that I would talk with paint suppliers as they have the same membrane paint that the professionals use and get ideas as to the way to go.
Aug 07, 2015 | Air Tools & Compressors
Used filler for filling nail heads rubbed back next day perfect two weeks later painted wattyl undercoat water base and filler went soft
The wood filler, a water based product, pulled the water out of the latex paint and softened. To preclude this in the future, you can cover these repairs with shellac or another sealant to provide a barrier between the filler and the paint. Spray shellac is available in hardware stores, and is used on water stained ceilings before repainting.
May 20, 2015 | Timbermate Wood Filler Water Based 8-oz...
How do I calculate the amount of paint needed for walls in a 12 foot by 16 foot room with 8 foot ceilings?
Ceiling paint estimator
Use the following formula to estimate the amount of ceiling paint you need. Double the result if the ceiling requires two coats.
1. Multiply the length of the ceiling times its width to find its area.
14 × 20 = 280 square feet
2. Divide that number by 350 (the estimated square feet covered per gallon) to figure out how many gallons of paint you need.
280 ÷ 350 = .8
For this example, you want to buy 1 gallon of ceiling paint for a single coat.
Wall paint estimator
Use the following formula to estimate the amount of wall paint you need. Double the result if the walls require two coats.
Feb 18, 2015 | Tools & Hardware - Others
Paint bubbling and peeling soon after painting a newly rendered wall........how do we fix it?
Sorry for the paint peeling and bubbles. It's not the drywall tape that has bubbles... right? Paint can react like this when it is applied over a sanded wall that has not been cleaned and still has a layer of drywall dust on it. When primer is applied to the wall, it is best to use something to push the paint on the surface to combine the dust with the paint. This could be done using a paint pad but should be more than just rolled on. The paint needs to mix with the dust and stir it in with the paint so the paint get under the dust. You might try thinning the paint a little to allow for better attraction to the wall. So now how do you repair this? By scraping the loose paint off and starting with a new coat. You know. it could also just be bad paint.
Aug 02, 2014 | Drywall
What can i do to fix peeling paint on a wall?
scrape, sand, Prime with an acrylic primer ,skim texture and top coat
or call a professional
Jun 25, 2014 | Tools & Hardware - Others
How to paint a wall?
Before I answer, I need more info.
Please be specific. Tell me about the room, (size, windows, doors, trim, panels, color you want, condition of walls and ceiling, be as specific as possible. I have 30 years experience, and can be very clear with enough info!
Good Luck, and look forward to hearing back
Neil
May 12, 2014 | Tools & Hardware - Others
Best way to paint a ceiling
Be sure to lay down tarps on the entire floor and move anything you wouldn't want to get paint on. You need a roller that can extend to the height of the ceiling and then you just roll in a similar fashion as a wall. Just be sure to go in about the same size sections as you would on a wall. http://www.blacksilver.com.au/bs_services.html
Apr 07, 2013 | Titan 310950 - Telescopic Power Roller...
Why is our ETS heater streaking the walls and ceiling black?
Electric heaters should not give off anything to make the paint go black , paint will change colour from the heat over time . I would say make sure there is nothing behind the heaters causing this to go black .
Ask where you buy your paint they can advise on paint that will not change with the heat .
Mar 17, 2012 | Heating & Cooling
Yellow Spots on Bathroom ceiling/walls after showers
You will have to paint over your new paint with a primer called BIN which will dry in about an hour. Then you can put your color coat on that. Problem solved.
Dec 04, 2009 | Home
There is a yellow film on my walls and ceiling around the firepla
Hi some paints or wall coverings will yellow with the heat form the heater repaint is the only way ask at paintshop if they anything to combat this
Oct 07, 2009 | Home Decorators Collection Charmglow...
Corel Painter Essentials 4 for PC, Mac (PE4ENPCM) Logo
62 people viewed this question
Top Corel Computers & Internet Experts
photoshop serial
Dan Shibata
Dan Shibata
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
