Question about IK Multimedia Production IK Multimedia AmpliTube iRig
Problems connecting iRig to guitar amplifier.
I tried connecting my iRig to my Fender hot rod deville as per the instructions but the squealing could be heard while the amp was on standby, suffice to say as soon as I took it off standby it screamed its head off. It actually worked better when I set it up the way the instructions say not to. What am I doing wrong?
Crate three button foot swich how do you connect it to the amp
The Fender Hot Rod Deluxe shows a 2-button footswitch as standard but I'm confused. This link shows it as connected to the amp via a mono cable ... FENDER Hot Rod Deluxe DeVille Footswitch which is impossible using two switches. Normally it's a stereo (tip, ring, sleeve) with tip to sleeve being one connection, and ring to sleeve the other. Good luck with this one.
Apr 22, 2014 | Fender Hot Rod Deluxe Guitar Combo...
Hot rod deluxe squeals terribly with either overdrive box or distortion box. seem fine with tremolo or chorus box.
I have had this problem at least two times and the fault was a bad hi voltage filter capacitor. With the back of the amplifier removed, it's the grey cap near the top right side. Warning: very dangerous voltage there!!
Jul 20, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Fender hot rod deville 212 111. On the 2nd and 3rd distortion chanels the noise coming out of the speaker is very loud. Is this normal? Hard to play through the noise.
Hi. If the volume and drive levels are considerably low but you still hear a noise, you may want to consider trying a different guitar cable. The noise may be coming from a ground loop which is being amplified and overdriven by the amp itseld. I hope this helps. :-)
May 29, 2011 | Fender Musical Instruments Corporation...
Do 4-10 devilles need to have the bias adjusted when replacing tubes?
When replacing the two output tubes you should check the voltage at TP26 or either cathode pin of the power output tubes to ground. Set the bias by adjusting pot R82 to 60mv which is 60 ma across the 1 ohm metering resistor. This coresponds to 30 ma per tube. Changing other tubes requires NO adjustment.
Apr 12, 2011 | Fender Hot Rod Deluxe Guitar Combo...
My reverb on my Fender deluxe Hot rod amp has stopped working. What is wrong?
Your reverb spring is most likely broken. If it has electronic reverb, then the chip has gone out. For both of these problems, a qualified amplifier technician will have to look at it and replace the parts.
Hope that helps!
Feb 13, 2011 | Fender Hot Rod Deluxe Guitar Combo...
How do I replace a fender 2 x 2 deville pilot light? CL
You unscrew the plastic dome over the bulb. The bukb is a bayonet base. Push in and turn... probably counterclockwise and extract the bulb. Replace by reversing the process.
Use T47 or #47 (6 volt) lamp... available at Radio SHack and other places.
Jan 23, 2011 | Fender R) Hot Rod DeVille III 212 Guitar...
Hot Rod Deville, reverb squeal...
Here is an article that might help:http://www.guitarplayer.com/article/reverb-troubleshooting/jun-09/97165 Here is the schematic:http://www.fender.com/support/amp_schematics/pdfs/Hot_Rod_DeVille_Schematic.pdf Check to see if someone hasn't reversed the input and output cables at the reverb tank. Then troubleshoot the reverb section .
Aug 28, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Fender Hot Rod Deville 212 - popped and died
This may sound stupid, but did you check the fuse?
Apr 22, 2009 | Fender Hot Rod Deluxe Guitar Combo...
IK Multimedia Production IK Multimedia AmpliTube iRig Logo
22 people viewed this question
Top IK Multimedia Production Computers & Internet Experts
Dan Shibata
Dan Shibata
JonSnell Electronic
JonSnell Electronic
Are you an IK Multimedia Production Computer and Internet Expert? Answer questions, earn points and help others
