I just joined this app service, I have asked some help on the Sanyo DP46848.The suggestion on the solution are great. I tried to open the back panel to this TV.I came upon a situation were I cannot re
  • 933 Answers
That is a defective LCD panel, a replacement panel will cost more than a new set.
Posted on Dec 07, 2012
5 Suggested Answers
dave1645
  • 834 Answers
SOURCE: I have a SANYO DP46848, after i turn on the TV
The ic on the T-con board is failing you could confirm this by spraying circuit cooler on the ic . The T-con board is located in the middle top on the unit has a cable from the mainboard to the t-Con
and two other going from it to the panel
You can try either Shopjimmy.com or TopsElectronics in Haverhill Ma
Posted on Dec 07, 2009
SOURCE: My Sanyo DP46848 LCD TV display goes black when turned on.
My mother's was doing the same thing (purchased 2008). Put up with it about 6 months and took it to a repair shop. Bottom line - the display panel has a flaw in and will cost more to replace than the tv cost. See about it now it yours is still under warranty.
Posted on Nov 22, 2010
  • 10 Answers
SOURCE: My DP46848 Sanyo LCD TV when turned on until it
sorry but the lcd panel is probably duff
Posted on Jun 08, 2011
  • 1779 Answers
SOURCE: DO THE SANYO DP42848 AND THE DP46848 LCD TV 2008
No boards in those models interchange with each other. Totally different.
Posted on Jun 16, 2011
Why does my sanyo dp46848 screen go dark but whites are too bright?
First try to gently push the cable between the main board and the LCD controller (T-CON) board and if that doesn't affect the image then replace the T-con board.
Jun 30, 2014 | Sanyo DP46848 LCD TV
No picture there used to be lines at the top
It sounds that there is some loose contacts with any cable connectors, or to any solder terminals at the circuit board. It will be best to contact any service technician, or the authorized service center for Sanyo. Gopakumar Gopalan Google
Feb 24, 2014 | Sanyo DP46848 LCD TV
Sanyo DP46848 im stumped lol... with nothing connected ( aka ) cable and or any other components .. just plug and turn on .. the screen has a solid blue bar from top to bottom with small white lines in...
Although you have not posted a picture, I believe you may have a screen or LCD panel problem, the panels have film connections that go from the t-con module, through the panel control pc boards then through thinn film connectors from the lcd screen. Likely this is the problem.
Oct 29, 2013 | Sanyo DP46848 LCD TV
47in sanyo flat screen gets a black shadow across it got to tap it to make it stop but happens alot . model DP46848
You have a defective LCD panel tab connection. The only permanent fix is to replace the panel. A replacement panel will cost more than a new set. I had the same problem with the exact same set.
Feb 08, 2013 | Sanyo DP46848 LCD TV
DO THE SANYO DP42848 AND THE DP46848 LCD TV 2008 MODEL USE THE SAME CIRCUIT BOARDS
Jun 16, 2011 | Sanyo DP46848 LCD TV
Sanyo DP46848 has sound but no picture.
Tv turn now,have a flashes of picture a few sec.than dies have sound left only?Yes,than ur tv have a 2 long boards are dead that call LCD inverter boards.These 2 long LCD inverter boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long refurbishes LCD inverter boards for the replacement.
Dec 07, 2010 | Sanyo DP46848 LCD TV
I have a SANYO DP46848, after i turn on the TV after a few minutes the picture turns a blue/grey color. There is still a picture and sound, but poor picture quaility. Need some help?
Dec 07, 2009 | Sanyo DP46848 LCD TV
Sanyo 46 IN. tv DP46848. The left 1/3 of screen is dark
It is a common problem for this model of a Sanyo TV, it uses a Samsung or Chime LCD panel.
The problem is the data buffer IC soldered on the flat flex cable between the LCD panel & the buffer board that gets damaged or loose soldering. If you be able to fix yourself, you may find some videos on YouTube, it will show you how to fix the buffer problem.
Jun 01, 2017 | Sanyo Televison & Video
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Electro Med Services...
