Question about Kenmore 19001
The thread keeps bunching up under the fabric while sewing
The thread bunches up beneath the fabric while sewing and then breaks
Try taking out your bobbin and upper thread and rethread and check tension. Thread may be caught down below or lint.
Posted on Jan 12, 2009
  • Kenmore Master
  • 1,388 Answers
For a comprehensive 5 page illustrated tutorial...Check this solution link, just copy & paste:<P>
http://www.fixya.com/marketplace/servicepage.aspx?srvid=17197&ctgid=164&brdid=1060&prdid=131120&smid=23884&mthid=1&mpsaugid=347d7805-9ce5-42d2-b812-b602b6cf7437
Posted on Oct 18, 2011
Why is sewing machine thread gathering under fabric?
adjust the tension to a appropriate setting,
See the video here.
Sewing Help Sewing Machine Problem Thread Bunching Under Fabric
The knob and its location can differ based on the model of your sewing machine.
Oct 29, 2016 | Sewing Machines
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
Thread on my consew 225 keeps balling the thread on the bottbottom
Sounds like bird nesting. The upper thread accumulates under the fabric creating a series of loops and knots.
First: Install a brand new needle and make sure it is installed facing the correct direction. (A new needle is the least expensive fix for most sewing machine issues.)
Second: Remove the thread. RAISE the presser foot and rethread from the beginning. Make sure it is threaded correctly (consult the owner's manual).
Third: Pull up the bobbin thread through the fabric and gently hold the thread tails in your left hand while slowly taking the first couple of stitches.
How and Why to Bring up the Bobbin Thread
Sewing Machine Thread Bunching Up Here Why
https://answers.yahoo.com/question/index?qid=20100303212248AAnRUQA
Why Do Get Bunched Up Thread Under My Fabric
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
Feb 06, 2016 | Consew Sewing Machines
Thread is getting bunched up in machine
First thing: install a brand new needle.
Second: remove upper thread. RAISE the presser foot and rethread from the beginning. Set upper tension to the midway point between high & low numbers.
These links may be helpful:
5 Common Causes of Birdnests
Feb 04, 2016 | Sewing Machines
Broken and bunched thread on back of fabric
try changing the needle
also try adjusting the top thread tension and see if that helps
make sure the top thread has not come off the thread take up lever
also the machine may need to be checked for a timing problem.
Nov 28, 2012 | Sewing Machines
Bobbin thread is bunching under the fabric what is causing this?
check the needle to see if it's bent
check to make sure the needle & thread are right for the project
some sewing machine bunch under fabric when the top thread come off the thread take up lever
Sep 27, 2010 | Singer Sewing Machines
Top thread bunching under fabric when sewing
tension could be too loose. start with bobbin tension- should allow thread to pass with SLIGHT resistance. then adjust top tension at about 2-3 to start.
Jun 01, 2010 | Singer 8280 Mechanical Sewing Machine
Brother Embroidery machine thread keeps breaking
the needle thread tension is wrong
bunching up under the material indicates that it is too loose
Nov 17, 2017 | Sewing Machines
Sewing Machines Logo
308 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
