Question about Lakewood Heating & Cooling
I need a challenge oil filled radiator heater rotary switch
  • 4 Answers
SOURCE: honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Posted on Nov 16, 2007
SOURCE: lakewook oil filled radiator heater
Here is your problem and yes it can be fixed.
More than likely your thermal cutoff tripped because your heater got too hot.
Solution:
1. Unplug unit.
2. remove front support feet and screw underneath face plate will slide off.
3. You will see the heating element, a white wire is coming out of it. There is a white sleeve on the wire tucked up into the element. Pull the wire out and slide sleeve off to expose the thermal switch labeled (S.W.C. sw-120t ect.) You can google it to learn more about the cutoff. If you know how you can test the cutoff with a ammeter or voltmeter, If you don't google how to test electrical systems. Remember "first do no harm"
4.
a. If you can replace the cutoff do so (this is the recommended way)
b. If you don't want to replace it cut the cutoff out and solder the wires back together. (be warned that this will bypass the safety system) If you do this be careful to not leave your radiator unattended.
5. After soldering the wire, taping it will electrical tape. Replace face plate from step 1 and 2 and your heater will work.
P.s. If your heater is still under warranty just contact lakewood.
Posted on Feb 20, 2008
  • 11 Answers
SOURCE: Dual rocker switch needed
This might be a re-branded De Longhi heater. Here is De Longhi parts website:
http://www.delonghi-accessories.com/models.asp?cat=143
Parts are also avail. from Fox International, though price is higher.
Posted on Jan 30, 2009
Natemane
SOURCE: ROCKER SWITCH DIAGRAM
On the top of the switch (inside the heater) there is a common connection.....even though it looks as if it is connected (electrically), it isn't electrically affected by the switch; it's just used as a post. It's just the place where the striped wire connects to the "common" point for the heater coils (they are in a parallel). Also, while you're in there you might want to put some electrical grease on the exposed conductors.....mine had quite a bit of corrosion (which was the reason for the failure). I had to replace 3 of the female connectors.
Posted on Jan 01, 2010
  • 3 Answers
SOURCE: Need a thermal cutoff for our Lakewood 5500
We have these heaters and haven't had a fuse fail yet. I think it's because after the first time I got that crackling sound after moving it while it was on, I stopped doing that, and only move it with the power off, and wait two minutes before restarting it, so the oil can resettle.
However, the thermostats are now failing. Anyone know if this part is available?
Posted on May 14, 2010
KSD301
Try Grainger - snap disc controls.
Also, see my post, in response to "The heater does not work when switched on I have", under this same topic, 'Problem with: Lakewood Oil-Filled Electric Radiator Heater'.
Nov 07, 2012 | Lakewood Oil-Filled Electric Radiator...
Lakewood oil filled radiator heater repacement switch
Here is a tip about space heaters that will also help you...
DeLonghi Space Heater does not Heat
heatman101
Jan 26, 2011 | Lakewood Oil-Filled Electric Radiator...
Do i need to add oil
Here is a tip that I wrote that will help you to understand about oil filled radiator heaters....
Oil Filled Radiator Heater Leaking
heatman101
Jan 12, 2011 | DeLonghi EW0507 Oil Filled Radiator Heater
My oil-filled elctric radiator heater doesnt warms up do you know why?
It could be the thermostat switch is bad,or the elements in the oil heater are burned out.
Jul 03, 2010 | Lakewood Oil-Filled Electric Radiator...
I have an oil filled radiator heater. The brand name on the cover is TouchPoint. It looks like the control and form factor of the DeLonghi brand of oil heaters. The unit was made in China. It was tipped...
I am about to replace the switche on my DeLonghi, but have not received it yet. If you can wait a few days I will post the wiring points here. I'm cold too!
Jan 06, 2010 | DeLonghi Heating & Cooling
All of a sudden the heater is not heating up. The
make sure the thermostat dial is not turned all the way down. The red rotary dial, set it to 6.
Dec 15, 2009 | Honeywell HZ-680 Oil Filled Radiator...
NEED NEW POWER ON SWITCH
email me at hokrazees85@tmo.blackberry.net
I have the part you need
Trevor
Jan 13, 2009 | Honeywell HZ-680 Oil Filled Radiator...
Switch
Try this link   http://www.nelsonappliance.com/Space+Heater+Parts.html
Mar 24, 2008 | Lakewood Oil-Filled Electric Radiator...
Heating & Cooling Logo
56 people viewed this question
Top Lakewood Heating & Cooling Experts
Mack Baxter
paulcarew
jdthefixer
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
