Question about GPX PD808B Portable DVD Player with Screen
Screen does not light
Power is on audio on dvd turns on but screen does not light up
Powers on wont post but dvd rom
Eject any disk from the DVD device.
Turn the computer off.
Disconnect the "data" and/or the "power" connectors from the DVD-ROM.
Turn the computer on, and see if it starts when the DVD-ROM is not part of your system.
If it starts, then your DVD-ROM needs to be replaced.
Dec 08, 2009 | Medion Computers & Internet
LCD TV has power but no picture or audio
one or 2 blown capacitors in the power supply
you will see the dome tops where they vented
Sep 16, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Unable to properly connect sony dvd to tv to play movie
DVD-3 RCA phono outputs(red & white=audio,yellow=video
I have a DVP-NS700,the same happens on mine.Turn it on,goes green to red(standby),then press eject,it will then power up properly.
Jan 03, 2009 | Sony DVP-NS300 DVD Player
No screen saver
depending on your tv there is a function to turn screen off. most tvs come with this feature. on the remote there will be an power key with a red or black button. this is to turn the screen off. if it does not have this function and there is no screen saver setting on the dvd play there is not much you can do for this situation .
Jul 05, 2017 | Panasonic DVD-S97 DVD Player
Vizio p42 type sp42a nov 2004 hd tv
POWER SUPPLY OR LCD PANEL INVERTER BOARDS . AVAILABLE THROUGH VIZIO , PARTSTORE.COM OR EBAY
May 14, 2008 | Vizio L32 32 in. LCD HDTV
Radio works cd/dvd does not.
What do you have your remote wire for your amplifier connected to?
Dec 05, 2007 | Panasonic CQ-VD7001U Car DVD Player
DVD turns off with "Protection" message.
it may be becoz you are using too many things from 1 plug socket / power adapter.
Aug 14, 2007 | Samsung HT-DS1000 System
Tube turns on nothing else does
If the Tv turns on (power supply is ok), screen lights up (inverters are ok) but don't get a blue screen, menu options, source options, or audio, it's most likely the main board (aka Motherboard) is faulty. If a DVD player is hooked upto the TV, check whether you can get audio from that (change the source using remote), in such a case it could be a problem with LCD Interface board. My $3 is on faulty Main board.
Jul 27, 2007 | Sanyo Vizon LCD-15A2 Television
DVD player froze, now only turns off
Sounds like the power supply in the dvd player has failed. It works just well enough to turn on the led infront but as soon as you go to do anything it shuts off. This is common in cheaper dvd players. Unless you can troubleshoot electronics. Or know someone that can. Your best bet is to unplug the unit and disassemly and retrieve your dvd.
Jan 13, 2007 | Philips DVP642 DVD Player
GPX PD808B Portable DVD Player with Screen Logo
26 people viewed this question
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
