Question about Toshiba e-Studio 232 Black and White Copier
It shows in the screen place doc.feeder in the down posotion
    New Friend:
  • 16 Answers
90% it is the RADF PCB. Before replacing it check the sensors and switches of the RADF in 03 mode. Refer to page no 2-29 of SERVICE HAND BOOK.
Posted on Dec 06, 2012
SOURCE: The copier keeps saying to put doc. feeder down and i it is. I ha
power supply has the fuse open that feed the voltage for the ardf
Posted on Sep 04, 2009
  • 126 Answers
When you lift/ open the ADF you should see a tab in the back corner (slightly in from the corner) of the ADF. This tab is for the machine to see that the ADF is closed. Make sure tab is there. On its sister model they used a depression switch, check that and make sure it is there and working properly.
Posted on Jan 05, 2009
  • 990 Answers
SOURCE: {place doc .feder in the down postion }
Hello sir; there have a document senser when you feed the document, check the senser may be it come off or broken.
Posted on May 23, 2009
  • 66 Answers
SOURCE: I'm getting a
On the rear left side of the copier there should be a black hinged actuator sticking up out of a hole in the panel, directly opposite of that there should be a white plastic tab that pushes that actuator down. If not try taping the actuator down flat with the cover.
Posted on Aug 17, 2010
SOURCE: giving error place doc.feeder in the down position
The cover on the document feeder may be partially open. Press the top of it while the document feeder is in the closed position. If you hear a click, then the top wasn't closed properly and you should be all set.
Posted on Jun 06, 2011
WONT MAKE A COPY IN TOPFEEDER
Check the connection of the doc feeder to the copier. if you open a cover on the doc feeder does reflect on the copier? Ensure the doc feeder is aligned there is a small magnet right front side of the doc feeder that sits on top of a switch (Can not be seen underneath front plastic the copier when down. Adjustment bolts for the doc feeder is the rear right hinge only.
Mar 21, 2014 | Konica Minolta Bizhub C253 With Document...
Automatic feeder on top is not picking up the paper?
Odds are that a paper sensor flag is knocked out of place and show a constant paper jam. It is a flaw of the feeder. The sensor is inside the door of the doc feeder. You will need a service person to repair it. I have done it many times..... Good Luck
Jul 05, 2012 | Canon IR-1022 Copier
I'm getting a "PLACE DOC. FEEDER IN DOWN POSITION" message when I place a document in Doc Feeder input tray of my Toshiba E-Studio 3511 copier. It is down. I have removed and reinstalled the feeder...
Jul 12, 2010 | Toshiba E-Studio 3511 Color Copier
Place doc , feder in the down postion
Something is blocking the Original Present sensor in the document feeder. The machine thinks you are trying to use the doc. feeder to make a copy. Clear the obstruction and this should remedy situation.
May 23, 2009 | Toshiba E-STUDIO 450 Copier
Mar 20, 2009 | Toshiba E-STUDIO 450 Copier
I have a Copystar CS-2020 and it is showing error code A-O 410 on the screen what does this mean
Document Processor communication problem. This is due to a faulty ground connection.
Open the doc feeder lid, check the left hinge. There are two versions of grounding tab: a small one and a bigger and better one. Both attached by a screw.
Twist the small metallic tab that grounds the hinge with doc feeder metal frame in order to create better contact. Worst scenario, the doc feeder cable has a broken ground wire at the holding strap (inside the back rear cover of the feeder, which is hold in place by plastic clasps. If you are handy you can solder the wire ..
Feb 17, 2009 | Copystar CS-2020 Copier
Jan 05, 2009 | Toshiba 2060 Copier
HP Officejet 6300 All-in-one machine makes black streaks
The problem is that that there a small piece of glass that the doc feeder use's to scan the orginal. You will have to clean the small glass it's about a half of a inch piece and is normally under the doc feeder unit. It will either be to the right side of the main copy board glass or it is under the doc feed unit where the paper goes down through the feeder. It is mostly some white out on the glass, just clean with a dam cloth with water or windex..... Good Luck
Nov 15, 2008 | HP 190 Copier
Document feeder
Does the adf show a paper jam? If so remove it or look for some thing blocking the paper path and remove it. Also try to turn off the copier and disreconnect the doc feeder and turn it back on and see what happens.
Feb 19, 2008 | Minolta Di3510f Bizhub Copier
Toshiba e-Studio 232 Black and White Copier Logo
96 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
