Question about Gateway 2520915 Keyboard
Pull off keys
Buy new keys
    Sergeant:
  • 270 Answers
Buy a new keykeyboard
Posted on Jan 12, 2009
Lost key need help pulling ingnition on 1992 acura legeng
wouldn't buying a new key thru your dealer be easier and possibly cheaper too
Jan 08, 2017 | Acura Cars & Trucks
The key does not stay connected when in use.
Try to buy a new key. may the old once magnetic property may degraded.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 13, 2016 | Triumph 400T Treadmill
How to replace the bad ignition lock cylinder
very simple but first buy the cylinder and have them key alike your original key, that way you do not need to buy new keys, and to many key on hand sucks too, one for the door one for the ignition, they are expensive,
when ready, remove the bottom steering cover , put the key on the ignition and tun it to position 2, look on the lock cylinder lower part and you well see a button there, one hand on the key one hand on a mini scewdive o big nail, push the button in and at the same time ty pulling the key out, the entire assemblies well come out. to install, make sue the key woks fine on the new tumble and then put it back in place, it will lock by it self, if the key is different, you may need new keys and reprogramming. that is why i said to have them make key alike, with the VIN #. good luck.
Jul 10, 2014 | 1999 Lexus RX 300
Altima key stuck ignition
Try pushing your shifter all the way forward while trying to turning the key to the off position and pulling the key out. You will most likely have to buy a new shifter lever or the whole shifter assembly.
Mar 25, 2014 | 1997 Nissan.5 Altima
I got a 1992 Saturn SC2. Someone, unsuccessfully
There is a nice video on this over on youtube. Shows the guy pulling off the plastic covers and removing the lock cylinder. You can buy a new one from a dealer, cost about 65.00 and you have to get it keyed, but I think you can buy a generic GM lock cylinder with a key from autozone or advance.
Note I have had an official saturn lock cylinder sitting at a Chevy dealer for a week now as they can not figure out how to key it. Nice to have your keys match the doors and trunk. If you go with a generic one your new ignition key will not match your doors and trunk.
Jun 28, 2010 | 1992 Saturn SC
Someone broke in my 2002 ford explorer and try to hot wire the car. he fail but left me with a mess. the steering column is broken wire is cut. i want to fix this on my own because anywhere i ask to fix it...
get a doner stearing column from nearest salvage,(thats what i would try). youll prolly have to buy a new key tumbler assembly and program the key to the computer anti theft sytem.
to program the new key, assuming all goes well with the new column and the new key tumbler,put the new key in ignition, turn key on for 15min, time it with a watch. after 15 min turn key off.
wait 15 more minutes. time that,
now after the 15 minutes u should b able to turn key on and start the vehicle.
the key tumbler/key switch kit should come with those instructions.
also if u buy a doner stearing shaft, i like when they let me pull it, lock the stearing wheel w/key so it doesnt turn.
there is a sensor called the "CLOCK SPRING," if u turn the wheel to far around while disconecting the stearing shaft at the bottom of column, u ruin this sensor and end up with a airbag lite on.
so b careful not to rotate the wheel more than two times in one direction the sensor is about 119 bucks u dont have to remove the stearing wheel to swap the column assemblys
Mar 23, 2010 | 2002 Ford Explorer
I need to remove my Pioneer DEH-1100 from my 1996 Honda Civic. All I can figure out is how to remove the front panel, but I need remove the whole thing and put in a new one. Please help. Thank you.
hi afetr you have removed the front panel look on either side of the stereo there will be a slot on either side, you will need to purchase "radio keys" for the type of radio you have from a good auto store you can buy them off the shelf, you insert either key into the slots on the sides and then pulling them in slightly pull the radio at the same time ( if you just pull straight you will only pull the key's out so bend them in slightly as you pull ) it should come straight out of the security cage....hope this helped
Feb 18, 2010 | Pioneer DEH-1100 CD Player
Missing D key
Well if you lost the key and its the snap in type of key and you dont want to buy a new keyboard you will have to carefully pull off one of the other keys you never use and put it where your D used to be.
Aug 04, 2009 | Toshiba Computers & Internet
I have a bmw and the key doesn't come out of the ignition
that means the pins way dropped it lock. buy a new barrow and key. to remove the one you have in now which is stuck.. all the couling off from around steering wheel. look at the barrow on the top you will see i little like pin that you push in when turn key to first knock and pull the key the barrow will pull out complete with key. if the doesnt come out on first knock turn to seconds ,, the new barrow will just push in with key in same place first or second knock..
matdav69
Mar 31, 2009 | 1999 BMW 318 ti
Keyboard repair
sure, usually you just push them back on.
they should click back into place.
If they dont then the carriage holders are damaged.
if not you can buy replacement keys, from the likes of e-bay.
you should be able to get a full keyboard replacement for about £25 Or $50.
Mike @ compurepair.
Jun 11, 2008 | Compaq Keyboard
Gateway 2520915 Keyboard Logo
50 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
