Question about HP Compaq ProLiant ML350 G3 Server
HP Proliant server 350 halts with LED 2 and 3 Orange
The server is unresponsive. Front panel LEDs 2 and 3 is Orange. unable to restart Servere unless disconnecting Powersupply for a couple of seconds. The server runs 1 to 21 days and then it stops again. This has been going on for some time now without investigation. Is it the power supply that is malfunctioning?
  • HP Master
  • 2,878 Answers
Open the case. Power up and look for internal LED that corresponds with warning light number 2 on main board.
Number 3 is power.
Posted on Dec 05, 2012
Testimonial: "Thanks"
  • 48 Answers
SOURCE: when i power up my
Try safe mode boot, hit F8 or F5 fast in beginning of boot process. You may have to try this a few times to get timing just right.
Posted on Mar 20, 2009
pandan22
  • 17 Answers
SOURCE: i can´t use a serial ata disk in a proliant 350
I know ATA disks are cheaper , but they don't last as long or are less reliable.
I do not recommend mixing SCSI and ATA .
Use one or the other , not both.
Do not try , unless your server is non critical.
If it is non critical , why bother with server , a PC will do as well.
Thanks
David
Posted on May 27, 2008
  • 17 Answers
SOURCE: HP Proliant ML370 Server: Led shows red light
Your server definetly has issue booting first of all this is a little old server model so first open and blow air from a blower (&not use vaccum cleaner)
since problem could be anything frm a struck cpu fan or anything
then poer donw theM/c and locate the RAM its a smal hardware in green color vertically fitted to the motherboard it will have locks at the both ends press them downwards the RAM will pop out then clean the side that was inside the motherboard with eraser and nothing else(it might damage the RAM) then fix it as it was aligning the notch it should work
If this does not work out then tell me exct LED and sybol near it
Bye for Now
Posted on Jan 24, 2009
  • 17 Answers
SOURCE: Connect HP Proliant ML350 Server.
Please verify if your server power specs support 110 or 220 V. If you are in the US, eventhough you might have connected a 220V cable the line voltage can be 110.
Check with your power company if they can provide you the necessary wattage of the server.(Specs are printed on the power supply. you can read it from HP web also)
Once you are sure that, connect both power suppllies and try booting.
If the error still occurs, it can be a power supply failure or some other hardware failure.
Regs,
Posted on Jul 10, 2009
kamal1984
  • 1383 Answers
SOURCE: Second Led on HDD is flashing Red
you can run "chkdsk /r" coomand to recover your harddisk.
Also if you can delete partition and then create new partition thehn format it so all errors are fixed .
Posted on Jul 16, 2009
ML350 G4 will not boot. System was running but became unresponsive. Powered down using power button. Now no response to pushing power button. No Leds lit anywhere. Fans running on power supplies.
Try pulling the hot swap Power supplies, push the power button hole the supplies are out to discharge power, then put them back in again and try the power button again.
Oct 28, 2013 | HP ProLiant ML350 G4 Server
Dont boot. orange leds on front icons
You may have a bad disk drive, if you have RAID setup, you may need to recheck the cable connections making sure they are seated properly. After checking connection/disk, recheck BIOS/CMOS setting and reboot your server.
Good Luck
C2Solutions
Jan 03, 2012 | HP ProLiant ML110 Server
Compaq Proliant ml370 g2 does not boot, beeping every 30 seconds, no video output. Internal Health LED is RED, Harddisk Health LEDs all green Component Health LEDs all green (RAM Banks are...
hdd fault caused by surge video card failure ram failure hdd failure depends what the beep codes are they are coded the length and duration tells you what the fault is ie three short beeps or two long ones try bleeping computer.com or check out bleep codes
http://h30499.www3.hp.com/t5/ProLiant-Servers-ML-DL-SL/Proliant-ML370-G2-server-strange-beeping/td-p/3221528#.VJgYMsgDQ
Apr 28, 2011 | HP Compaq ProLiant ML370 G2 Server
Compaq ProLiant DL380 G2 boot error. Front panel led "Internal health" initially green, then goes red with 2 second beep alternating with 2 second off. All ram leds yellow - only two populated. ...
You can get all of the documentation here
Also, Judging that the LEDs are not corresponding with the servers actual status (processor LED), This server may have been taken apart and the wires to the status leds were incorrectly reconnected. I would look at the documentation for the motherboard and compare to the wiring diagram. The RAM May be an issue. Depends on whether the machine makes it past POST (Power On Self Test). If it does, The ram is fine. If not, I would inspect that beep code further. It probably has something to do with the memory. If the memory is malfunctioning, you will get no response from the machine other than beep codes and status leds. According to the documentation, the closest match for your beep code means this:
207-Memory Configuration Warning -
DIMM In Socket X does not have Primary Width of 4 and only supports standard ECC.
Advanced ECC does not function when mixing DIMMs with Primary Widths of x4 and x8.
Audible Beeps: 1 long, 1 short, or none
Possible Cause: Installed DIMMs have a primary width of x8.
Action: Install DIMMs that have a primary width of x4 if Advanced ECC memory support is required.
I hope this helps. Thank you for choosing fixya.com
Dec 03, 2010 | Compaq ProLiant DL380 Server
HP SERVER PROBLEM
You should be using a 110 voltage cable if you are in the USA.
Jun 14, 2009 | HP ProLiant ML350 G5 Server
Regs,
Jun 14, 2009 | HP Compaq ProLiant ML350 G3 Server
Internal led of ML350 server is glowing.......how do i resolve it?
Hi Franceso, plz specify
Is it powering ON ?
Which LED is glowing?
These leds are there on the front panel :
1 Power On/Standby button
2 System power LED
Green = Power on
Amber = System shut down, but power still applied
Off = No power
3 Internal health LED (Wave sign in BOX)
Green = Normal
Amber = System degraded. To identify the component in a degraded state, refer to system board LEDs.
Red = System critical. To identify the component in a critical state, refer to system board LEDs.
Off = Normal (when in standby mode)
4 External health LED (power supply)
Green = Normal
Amber = Power redundancy failure
Red = Critical power supply failure
5 NIC 1 activity LED Green = Network link
Flashing = Network link and activity
Off = No link to network.
6 UID LED Blue = Activated
Flashing = System remotely managed
Off = Deactivated
7 UID button
If it is Internal health led then any internal h/w issue is suspected.
If it is external health led then any power supply or power source related issue is suspected.
Also check the status of the server & its IML (Integrated Management Logs) in ilo (Integrated Lights Out ) if it is configured. (2nd RJ45 port in rear)
Also make sure the cabinet is properly closed.
Nov 18, 2008 | HP Compaq ProLiant ML350 G3 Server
HP Compaq ProLiant ML350 G3 Server Logo
366 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
