I want to use my laptop with a broken screen in a other screen from sttionary computer
    President:
  • 623 Answers
Why don't you connect your external monitor to your laptop directly via VGA or DVI cable?
If that's not possible let me know and we take it from there.
Posted on Dec 05, 2012
Broken laptop screen
There is nothing more frustrating than a broken laptop screen. Whether you have dropped your laptop or stepped on it,once the screen is cracked it has to be replaced. Having the screen repaired may cost you almost as much as a new laptop. Purchasing a new screen from the manufacturer can also be expensive. Taking the time to look online at computer message boards or resellers can help you to find a reasonably priced screen. By following a few easy steps, you can replace your cracked screen and have a functioning laptop in an afternoon.
Determine what model laptop screen will fit your laptop. Ordering a screen directly from the manufacturer can be almost as expensive as buying a new laptop. Look at online computer message boards, auction sites and retailers to find less expensive options. Disconnect any power source, including the battery pack, from your laptop before you begin. Locate and remove the four to six screws that hold the bezel, or plastic frame cover, in place. The screws sometimes have small plastic or rubber covers over them. Pull the plastic bezel away from the screen cautiously, working around the edge. Some bezels snap in and out of place. A small flat-head screwdriver may be helpful in prying the edge of the bezel away from the screen. Pull the screen forward gently. You will find two main wires behind it. The ribbon-like wire, or video cable, is usually taped in place. Remove the tape and disconnect the video cable from your broken screen. Remove the broken screen from its metal frame. Connect the new screen to the video cable and pop it into the metal frame. Replace the tape, plastic frame and screws. Power up your computer and test your new screen. Hope this helps.
b>
Dec 10, 2012 | Computers & Internet
HOW TO REMOVE SCREEN FROM DELL VOSTRO 1000 AND CONNECT TO A MONITOR
if laptop is still running with a broken LCD screen , it id possible to use an external monitor, if laptop totally died or broken, not possible to use with external monitor.
Mar 26, 2012 | Dell Computers & Internet
My aus f3 broken lcd how i can turnon laptop
If your LCD is broken (failed LCD driver card or physically damaged screen), then you cannot operate the computer. You will need to take it to be repaired by the supplier or at a local computer shop. If it is under warranty, then you may be able to get it fixed that way.
If you need to access the data on the laptop in a hurry, then the easiest thing to do is get access to another (2nd) computer, take out the hard drive from the broken laptop, put it into a portable drive carrier with USB connection (you can buy this from a computer shop) and access the data on the hard drive that way via the 2nd computer. That can be a real help when your laptop is broken and I have used it on several occasions when I or my customers have had a broken/failed laptop.
Oct 20, 2011 | ASUS F3Jc-AP141C Notebook
Asus screen notting appear when i start my computer
Please try this: Connect your laptop to a working monitor. Then use the monitor as your temporary monitor. If this works, then the screen in your laptop is broken or damaged. If this still doesn't work, your laptop might be broken. In this case, try formatting it.
thanks.
regards,
longgee
Dec 27, 2010 | ASUS G2P Notebook
Computer screen is not broken but no display and looks as though it has shattered
It sounds like the screen is broken, possibly from some kind of shock. Replacement screens are all over ebay and fairly easy to install. You can download the service manuals for any laptop via Google
Dec 05, 2009 | Computers & Internet
Screen isnt booting up, laptop opens all the way- broken?
The computer will not work without a hard drive.
Most laptops screens will go all the way back.
Enjoy.
Jul 08, 2009 | Gateway MT3422 RTL Notebook
Screen went black; power cord is working but won't power computer
the power plug on the laptop may be loose or broken
Mar 03, 2009 | Acer Aspire 3680 Laptop
Hi , i m arhan khan .... plz send me dell service centre contect number & address in Delhi ...... my email ID 's mohdnoumaan2588@yahoo.co.in
Dell Laptop Service Centre in Delhi. Call Laptop
Call Laptop Clinic for genuine repairs of Dell Laptops.Pickup and delivery service at your doorstep.Just call or
Dell Inspiron,Vostro,Lattitude or any other model of Dell ,Laptop Clinic is a division of Beyond Computers, the most trusted name for the last 16 years.
.hidden {display: none;} .invisible { visibility : hidden; }
  • Dell Laptop AC power connector, broken, damaged, Loose, bad Motherboard ?
Having a Laptop problem? your computer does not boot-Up ?Laptop Clinic can repair a broken or damaged Power Connector. Give us a call at 098111 37536; it is possible to repair the connector assembly without replacing the motherboard.
  • Dell Laptop bad display, LCD Screen Broken or very dark display, No Display ?
If you have a broken laptop screen, You do not have to replace the expensive Laptop screen, it could be one component is bad or a loose cable. Let us check it out for you, before you replace the expensive Laptop screen or throw your laptop away.
  • Dell Laptop Bad Keyboard, or bad CD / DVD Optical drive, Hard drive and CPU Fan ?
We also repair Laptop Keyboard, CD / DVD optical drives, Hard drive CPU Fan and Housing repair.
Phone : 9811137536
Address : 2879 Sant Nagar Main Road Rani Bagh Near M2K Pitampura New Delhi
website : http://www.beyondlaptops.com
Feb 21, 2009 | HP Pavilion dv6000z Notebook
Nec laptop screen not displayin
What have you tried so far?
Connect your laptop to an external monitor to see if it is the adapter or the screen that is broken. Toggle on to the external monitor. If the external monitor works, you'll know it is the laptop screen(or a component of it) that needs repair
Check your laptop latch to see if it is broken.
Dec 15, 2008 | NEC MultiSync FE991SB 19" CRT Monitor
Is my screen broken?
Hello, I am really sorry about what happened to your laptop.
99% of those cases require a replacement of the screen.
I suggest you should visit a technician and check if there is a broken part of the screen where is leaking a liquid. Laptop screens have liquid crystals and probably that liquid is leaking inside.
For sure the laptop screen can be bought seperately and it can be replaced.
Jun 30, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
