Tuning fault tuning stops at 63%
    Top Expert:
  • Televison & ... Master
  • 75,305 Answers
Check and replace the main system control memory IC.
Posted on Dec 05, 2012
Harley trouble codes
There are two types of diagnostic trouble codes (DTCs), current and historic. The Check Engine Lamp will not indicate the existence of historic trouble codes.
1 Current 53 ECM flash error
2 Historic 53 ECM flash error
3 Current 54 ECM EEPROM error
4 Historic 54 ECM EEPROM error
5 Current 63 ECM serial data low
6 Current 63 ECM serial data open/high
7 Current 63 TSSM serial data low
8 Current 63 TSSM serial data open/high
9 Current 61 Loss of TSM/TSSM serial data
10 Current 14 Loss of all ECM serial data (state of health)10 24 Loss of vehicle speed10 33 Loss of vehicle inhibit motion10 43 Loss of powertrain security status
11 Current 33 System relay contacts open
12 Current 33 System relay coil high/shorted
13 Current 33 System relay coil open/low
14 Current 33 System relay contacts closed
15 Current 99 Incorrect password
16 Current 99 Missing password
17 Current 41 CKP sensor intermittent
18 Current 41 CKP sensor synch error
19 Current 11 TP sensor open/low
20 Current 11 TP sensor high
21 Current 12 MAP sensor open/low
22 Current 12 MAP sensor high
23 Current 14 ET sensor voltage low
24 Current 14 ET sensor open/high
25 Current 15 IAT sensor voltage low
26 Current 15 IAT sensor open/high
27 Current 24 Front ignition coil open/low
28 Current 25 Rear ignition coil open/low
29 Current 24 Front ignition coil high/shorted
30 Current 25 Rear ignition coil high/shorted
31 Current 24 Front cylinder combustion intermittent
32 Current 25 Rear cylinder combustion intermittent
33 Current 23 Front injector open/low
34 Current 32 Rear injector open/low
35 Current 23 Front injector high
36 Current 32 Rear injector high
37 Current 16 Battery voltage low
38 Current 16 Battery voltage high
39 Current 43 VSS sensor low
40 Current 43 VSS sensor high
41 Current N/A (no speedo code for this) Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
42 Current N/A (no speedo code for this) Check engine light high NO CHECK ENGINE LAMP AT KEY ON
43 Current 35 Tachometer low
44 Current 35 Tachometer high
45 Current 25 Rear cylinder no combustion
46 Current 24 Front cylinder no combustion
47 Current 34 Loss of idle speed control IDLE AIR CONTROL
48 Current 35 Accelerometer fault
49 Current 34 Starter output high
50 Current 25 Ignition enable output high
51 Current 21 Left turn output fault
52 Current 22 Right turn output fault
53 Current 11 Battery voltage high
54 Current 31 Alarm output low
55 Current 32 Alarm output high
56 Current 41 Ignition switch open/low
57 Historic 63 ECM serial data low
58 Historic 63 ECM serial data open/high
59 Historic 63 TSSM serial data low
60 Historic 63 TSSM serial data open/high
61 Historic 61 Loss of TSM/TSSM serial data
62 Historic 14 Loss of all ECM serial data (state of health)
63 Historic 33 System relay contacts open
64 Historic 33 System relay coil high/shorted
65 Historic 33 System relay coil open/low
66 Historic 33 System relay contacts closed
67 Historic 99 Incorrect password
68 Historic 99 Missing password
69 Historic 41 CKP sensor intermittent
70 Historic 41 CKP sensor synch error
71 Historic 11 TP sensor open/low
72 Historic 11 TP sensor high
73 Historic 12 MAP sensor open/low
74 Historic 12 MAP sensor high
75 Historic 14 ET sensor voltage low
76 Historic 14 ET sensor open/high
77 Historic 15 IAT sensor voltage low
78 Historic 15 IAT sensor open/high
79 Historic 24 Front ignition coil open/low
80 Historic 25 Rear ignition coil open/low
81 Historic 24 Front ignition coil high/shorted
82 Historic 25 Rear ignition coil high/shorted
83 Historic 24 Front cylinder combustion intermittent
84 Historic 25 Rear cylinder combustion intermittent
85 Historic 23 Front injector open/low
86 Historic 32 Rear injector open/low
87 Historic 23 Front injector high
88 Historic 32 Rear injector high
89 Historic 16 Battery voltage low
90 Historic 16 Battery voltage high
91 Historic 43 VSS sensor low
92 Historic 43 VSS sensor high
93 Historic N/A Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
94 Historic N/A Check engine light high NO CHECK ENGINE LAMP AT KEY ON
95 Historic 35 Tachometer low
96 Historic 35 Tachometer high
97 Historic 25 Rear cylinder no combustion
98 Historic 24 Front cylinder no combustion
99 Historic 34 Loss of idle speed control
100 Historic 35 Accelerometer fault
101 Historic 34 Starter output high
102 Historic 25 Ignition enable output high
103 Historic 21 Left turn output fault
104 Historic 22 Right turn output fault
105 Historic 11 Battery voltage high
106 Historic 31 Alarm output low
107 Historic 32 Alarm output high
108 Historic 41 Ignition switch open/low
Aug 11, 2014 | 2000 Harley Davidson FLHRCI Road King...
I require a manual for a Wharfedale TV LCD1510A, I bought it 2nd hand and the manual was missing and I cant tune it in. HELP
Wharfedale stopped making TVs in 2008 after they were acquired by an international company IAG. It is unlikely you will find the manual easily except to contact IAG and ask for advise.
http://www.wharfedalepro.com/Contact/tabid/63/Default.aspx
Apr 27, 2014 | Televison & Video
Jvc tv channel search stuck on 63%
It sounds like a main system control memory IC fault. Contact any service technician, and make it confirm.
google.com/+GopakumarGopalan
Dec 01, 2013 | Televison & Video
I changed the new batteries but still digital display is not shown
if the batteries are new and the battery terminals are clean and not corroded or broken, and the battery polarity is correct when they were installed. There must be a fault in the internal circuits of the scale, and a technician with the right tools, training, and experience will be needed to repair it.
Maybe time for a new scale.
Oct 05, 2017 | Health-O-Meter Health o Meter BFM681DQ-63...
I have 2005 chrylsr 300 limited v6 engine and I noticed and now it is getting worse..that when I am at a stop and then I begin driving the car shakes and then it drives smoothly and then it shakes again...
IF YOU DONT SEE A CHECK ENGINE LIGHT.CAR SURGING AND JUMPING COULD BE FAULTY FUEL PUMP OR BAD TRANSMISSION TORQUE CONVERTER.CHECK FUEL PRESSURE SHOULD BE 53 - 63 PSI.IF SEE CHECK ENGINE ON.CODE SCAN FOR A FAULT CODE.
Jun 03, 2011 | 2005 Chrysler 300
'96 Nissan Altima runs great when cold, but once warm, rpms go haywire, sometimes it stalls
Stop by any good parts store (Autozone, Advance, etc..) and have them do a FREE OBII scan (fault scan) That will show what faults computer has been experiencing. Another question.. When was last "healthy" tune up? Plugs, wires and ALL filters especially FUEL filter? A good tune up usually cures a multitude of stalling and runability issues.
Mar 01, 2011 | 1996 Nissan Altima
1990 Voyager. Need code definitions from check engine light. Codes retrieved by turning key on 4 times and counting check engine light flashes. codes were: 12 41 25 55.
here you go hope it helps,dont forget to vote on answer thanks
88–95 3.0L (Except Monaco, Premier & Stealth),
3.3L, 3.5L & 3.8L Engines
11
Engine Has Not Been Cranked Since Battery Was Disconnected{4}
No Crank Sensor Signal During Engine Cranking{3}
12
Memory Standby Power Recently Lost
13
MAP Sensor Pneumatic Circuit
14
MAP Sensor Electrical Circuit
15
Vehicle/Distance Sensor Circuit
16
Loss Of Battery Voltage Sense
17
Engine Running Too Cool
21
Problem In Oxygen Feedback Circuit
22
Coolant Temperature Sensor Circuit
23
Charge Temperature Sensor Circuit
24
Throttle Position Sensor Circuit
25
AIS Motor Drive Circuit
26
Injector Current Limit Not Achieved
27
Injector Driver Interface Circuit{1}
Injector Control Circuit{2}
31
Purge Solenoid Circuit
32
EGR Diagnostics
33
A/C Cutout Relay Circuit Or A/C Clutch Relay Circuit
34
Fault In Speed Control Solenoid Driver Circuit
35
Fault In Fan Relay Circuit
37
Part Throttle Unlock Solenoid Driver Circuit
41
Fault In Charging System Or No Field Current
42
Fault In ASD Relay Driver Circuit
43
In Ignition Coil Control Circuits
44
Lose Of FJ2 To Logic Board
46
Battery Voltage Is Too High
47
Battery Voltage Is Too Low
51
Lean Condition Is Indicated
52
Rich Condition Is Indicated
53
Internal Problem In Module
54
Fault In Distributor High Data Rate Pickup Circuit{1}
No Sync Pickup Signal{2}
55
End Of Message
62
Unsuccessful Attempt To Update EMR Mileage
63
Fault Error{1}
Controller Failure EEPROM Write Denied{2}
65
Manifold Tuning Valve
66
CCD Bus System
77
Speed Control Relay Circuit
{1}—1988–91 models.
{2}—1992–95 models.
{3}—1990–95 models.
{4}—Neon.
If you need more just ask Thanks Db
Aug 18, 2010 | 1990 Plymouth Voyager
Error Code 63 on Phillips Plasma - what does it mean?
Error Description Error/Prot Detected by Device Defective module Result
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
14 Supply Class D amplifiers
14 Supply Audio part SSB
17 MPIF1 audio supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
43 Hi Rate Front End
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Mar 30, 2009 | Philips Televison & Video
No sound on 4 channels
i would say that it is the tuning try fine tuning it and see what that does
Apr 20, 2008 | Toshiba 20a43 20" TV
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
