Question about Hotpoint HTS20GCNWW / HTS20GCNCC Top Freezer Refrigerator
The coils are frozen solid in freezer behind back wall
The fridge is room temp and coils in freezer are frozen solid, took back panel off and noticed the ice from top to bottom, the freezer fan is running and think the comp is ok also, did some ac work for 2 yrs and frozen coils most of time meant leak in freon. What is your opinion? thankyou for your help
mike
  • 82 Answers
Frozen coils not always means freon problem. low air flow across evaporator coils could cause freeze up. if door is opened and closed an abnormal amount could cause a freeze up or even something pushed up against the air intake in the refridgerator. i would thaw it out completely and restart it, theres a chance it was nothing major. good luck
Posted on Jan 12, 2009
Samsung fridge coils frozen over on refrigerator side.
Not sure what the ohms should be,but ckeck coils for damage you may have a leak
Dec 07, 2013 | Refrigerators
I have a Kenmore bottom fridge model #596.69274991. Although things are cold and frozen, the room temp is only 70 degree but it seem to run for well over an hour although there has not been much opening...
Tom, you pretty much have it all covered. Make sure both the freezer fan and the fan under the fridge are both running and keep your eye on the inside back wall of the freezer compartment fro any signs of frost build up (possible defrost problem).
Jun 12, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice on back wall of freezer, food not staying completely frozen
Do you have the complete model number from the tag on the freezer, it should be either on the bottom rail visible with the door open or on the side wall near the front. I am trying to look this up to see if it is an automatic defrost model, if so you may need to do more than just unthaw and adjust
Thanks
Apr 25, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
American fridge/freezer - fridge stopped cooling, freezer side ok
Have you pulled out the refrigerator and cleaned or used a vacum cleaner to get out the dirt and dust off the back of the coils, or if the coils are underneath, you need to get an inexpensive appliance brush for fridge, and clean the coils under the fridge, pull off the panel on the front bottom of the fridge, get a flash light and look to see if the coils are covered in dust....may just need to vacum and use appliance brush underneath...this should be done at least one a year, you will notice your fridge running much better and cooling back to normal.......hope this helps......
Jan 05, 2010 | Refrigerators
Admrial LTF2112AR fridge not cooling
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Sep 12, 2009 | Refrigerators
Amana BR18 Doesn't get cold
Mine is doing the same thing
Jul 05, 2009 | Amana Freezers
Freezer frozen solid freezer cool fridge not
HI look for this part in the freezer. its the most common one to fail.replace it
Oct 14, 2008 | GE GSS20IEP Side by Side Refrigerator
Freezer works great, as it should, but fridge is only keeping items room temp. I have the setting at the coldest setting: #7. What is wrong?
Here's what I did, I defrosted! I found out that the fridge temp is monitored and maintained by the freezer. Because we had a power outage one night, my freezer thawed while we all slept and then when power came back on, freezer re-froze but this cause an ice build up on the vent on the back wall of the freezer. Well, ice must have been in one (or more) vents, causing blocked air flow in my top half of the refrigerator. I turned the dial in the freezer to "off" which also shuts down power to the fridge half. I then unplugged the refrigerator, hauled all my food items into coolers, opened the freezer door and refrigerator doors and left them open for a little over six hours. I took advantage of this empty fridge and freezer and wiped everything down. After this time frame passed, I plugged the fridge back in, turned the freezer dial to my preferred freezer temp, and wah-lah! Within two hours I had a cold fridge and solid ice cubes in the freezer. I then put all my food items back into their appropriate compartments, and went to work. Bear in mind, a total 24-hour period is needed for the fridge to re-set itself, but still, after two hours the fridge was noticeably cold. Who knew, besides our parents' generation: DEFROST!
Sep 10, 2008 | Maytag MBB1954G Bottom Freezer...
GE PFS22MISBBB freezer not cold enough. Temp won't reset.
replace the fan as quickly as possible it may be shorting and causing damage to your control board,
Mar 30, 2008 | GE PFS22SBSSS Stainless Steel French Door...
High temp red light stays on...
You'll need to tear into it to answer these questions. I suspect the defrost cycle isn't working or the fan is broken. The best way to see what's going on is to take everything out the freezer drawer and remove it. Then take the back panel off the interior rear wall of the freezer section to expose the coils. The coils should have a very even white frost pattern on them (not frozen solid anywhere). If they are frozen up then the air can't flow around them to cool the fridge properly. If the coils seem "normal" with frost only then is the fan just above them working? That fan circulates cold air to both fridge and freezer sections. Let me know what you find out in order to lead you to a repair part.
Jan 12, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint HTS20GCNWW / HTS20GCNCC Top Freezer Refrigerator Logo
703 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
