Denware mother board fan rotating fastly wat prblm will occur
  • 3,799 Answers
Nothing. As long as the housing isn't rotating as well.
Posted on Dec 06, 2012
I have a Konica Minolta C6500 and I have error code C4717 what can be done
Index sensor output does not
change by the execution of
APC. Index sensor cannot
detect the laser because the
polygon mirror does not rotate,
or because of the index sensor
out of position or defective index sensor
Basically the (Black print head/LASER UNIT/Write Unit) for Black drum is causing problems internally. Inside the unit the Index sensor output does not change by the execution of APC. Index sensor cannot detect the laser because the polygon mirror does not rotate, or because of the index sensor out of position or defective index sensor. Or one of the many control boards is causing issues with Black Laser Unit, such as:
Printer control board (PRCB)
Image processing board
(IPB)
I/F board (IFB)
Image memory control board
(IMCB)
Serious Cost for these boards, recommend a Konica Minolta Tech check this out. Sorry
Nov 03, 2015 | Konica Minolta Bizhub Pro C6500 Printer...
Crt mother board secondary voltage will come 200 wats prblm occur tell any one
The 200 volts is likely a screen voltage source---If the set uses a CRT it is older.
Aside from that voltage in a CRT type monitor no filaments lit in the neck of the CRT can also cause no light on the screen (I assume screen does not light up at all)
A CRT monitor also requires the High voltage to be there for brightness---
There are things you can look at but what is your skill level with this type of equipment?
Dec 20, 2012 | Computers & Internet
Booting up computer after a power outage
did you check the power supply if it is working?.look for the exhaust fan if it is rotating. then look at the mother board if the fan at the processor is also rotating if not check the supply first at the PSU if ok.
Jun 05, 2012 | Lenovo Computers & Internet
I cant remove my fan its an intel D34223-001
Intel D34223-001 is fan and Heatsink assembly for Intel Socket 775. Following are the videos about removing and installing this fan
REMOVING FANINSTALLING FAN
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 29, 2011 | Intel (D34223001) CPU Heatsink Fan
Cpu fan fast bios wont start
Run the Dell Diagnostics to test the Fan.
Check to make sure the fan power connector is connected to the mother board.
The fan could be defective.
Reset BIOS to factoiry default settings.
I hope this helps.
Good luck and have a pleasent day.
May 16, 2011 | Dell Dimension 8400 PC Desktop
My cooling fan on my mother board start making noise now as soon as you power up the pc it shuts down could it over heat that quickly or did it ruin mother board?
It is possible to burn out a processor in a matter of seconds without cooling. Please do not attempt to restart the unit, until you replace the colling fan on the processor. If it's not the processor fan/heatsink, you may have lucked out, but don't restart it till you replace the fans.The fan that sits on your cpu is the main concern, if it's one of the others the board should shut down automatically in order to stop this scenario from occuring.
Mar 09, 2009 | Computers & Internet
Motherboard not starting!
try to set the jumper setting of the cmos battery in *********** board.you set the jumper setting 1 and 2 with in 3 mins.then try to set back the original setting the jumper seting in 2 and 3.
kira_ryuk99@yahoo.com
Jan 11, 2009 | ASUS K8V-MX Motherboard
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
