Question about Microwave Ovens
Sharp r395fs not working
No display, no light. Power point tested ok
Sharp R-9H84B-display black, cleared display shows "Conv Mix, 88:88 Auto". Short time all dark again. Hit clear happen 2 times then, all dark, no power, can't clear won't start, nothing works.
R-9H84B - May 29, 2017
I would suggest pulling the control board out and looking on the foil side (opposite the component side) for "ring cracks," most likely on the low voltage transformer's connections.
The board may have the screen-printed reference designator "T1" near the low voltage transformer.
Also be sure the fuse is not easy to turn with your fingertips when it is in the holder. If it is, the fuse holder is too loose and must be replaced (not just squeezed with pliers).
You can order a fuse holder, part number WB06X10034 for $6.49 (subject to change) from the Pros here.
If you have any keypad issues, please note that the membrane keypads for this model have long been discontinued.
FixYa does not directly notify us experts of responses, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 28, 2017 | Sharp Microwave Ovens
How do I replace the bulb for the display panel of a Sharp Microwave oven Model # R-314F ?
Normally switch power off and remove plug from wall socket, undo screws around side and back panel and remove outer cover, then the light socket will be visable so change light bulb and reassemble, CAUTION: high voltage may be present so best left to service person for safety
Jul 23, 2014 | Sharp Microwave Ovens
My R-4A58 unit only displays
The keypad control board will need to be replaced.
Apr 26, 2012 | Sharp Microwave Ovens
Re: Sharp carousel microwave oven minute display light out
Hello there
To replace the light you will first have to remove the outer shell.
To do this
(1). Remove all of the screws on the back of the microwave that hold on the shell
(2) Remove the screws that are on the bottom.
(3) now the shell should slide off towards the back of the microvave.
Note : this may take a little bit of pressure to get it off ok?
(4) Once the cover is off look towards the fromt of the microwave and
you will see the bulb. now just replace the bulb and reinsert the cover and the screws and you are all done ok? pretty easy ha/
best regards michael
Sep 28, 2009 | Sharp Microwave Ovens
The Display is Dim. Hard to read the numbers.
I have the same model and problem. The time display is totally unreadable. Looking for a solution as well. I suspect given the cost (I believe around $60), it's time for a new one. Anyone have any suggestions or easy repair ideas?
Mar 12, 2009 | Sharp R-314FS Microwave Oven
SHARP R 88BKM no microwave
David
This is a sure sign that the MAGNATRON unit has went out on your oven and will need replaced! (This is what cooks the food!)
Please take a second and rate my response!
Thank You!
Jan 15, 2009 | Sharp R-1481B Microwave Oven
SHARP R-316F
easy to fix you need to cut the tracks to the led lights then solder 2 wires to the leds next use a 1k resistor on one of the wires then conect it straight to the power surply just after the bridge rectifier noteing+ and -
Mar 06, 2008 | Sharp R-202EW Microwave Oven
Sharp microwave oven R345 M 900 watts
In most cases the displays are protected by a low value resistor which could have burned out. First someone needs to determine if the display is getting the proper voltage. If it is and still does not work you need a display. If it isn't getting any power follow the circuit back to the power supply and you'll probably find an open resistor or micro fuse (which looks like a resistor).
Jun 22, 2006 | Sharp R-354 Microwave Oven
Microwave Ovens Logo
47 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
