Tight tub nut
Trying to loosen the tub nut but the tub spins
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the complete model number of the unit?
Posted on Dec 06, 2012
  • 262 Answers
SOURCE: maytag top loader not spinning in tub but sounds like spinning
I hope its under warranty the bearings have gone bad they are fun:( to replace you have to take washer TOTALLY apart to replace along with the center seal total $ around 150-175 time involved 2-3 hours headache priceless plus you need special tool to get center seal out and back in
Posted on Jan 01, 2008
burdfrenzy
  • 348 Answers
SOURCE: Model: WWSE5240G0WW Tub does not spin but can
Does it drain? If not your pump is bad. If it does drain you need a belt if it is a belt driven washer.
Posted on Oct 17, 2009
  • 151 Answers
SOURCE: I have a GE top load washing machine. During the
there are springs under the machine that attatch to the tub in 3 to 4 places if one of these springs break it will cause the tub to bang.
Posted on Dec 24, 2009
  • 1937 Answers
SOURCE: Trying to remove spin basket (inner tub) from Washing Machine
See the Sears parts site for washer 82372110.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.82372110
The following may also help.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=146
Posted on Jan 26, 2010
  • 160 Answers
SOURCE: trying to get off the
What brand washer do you have? Model number. I just ask because some washers you just lift hard and the agitator comes off others have the bolt under the softener. If you have the bolt than hold the agitator in place than turn counterclockwise fast and hard. Sometimes if you tighten it a hair it makes it easier to loosen. If you need any further assistance please comment.
Posted on Jul 30, 2011
Idler pulley nut comes off craftsman 42 inch lawn tractor
put two nuts on it and tighten together. or put lock tight on it
Nov 03, 2016 | Garden
How to repair a loose drum?
You need to remove the agitator, loosen the tub nut (May already be loose), align bowl & tighten tub nut.
Mar 16, 2015 | Maytag Washing Machines
I have a LG WT5001CW top load washer. Recently the agitator plate began to loosen and fall off during spin cycle. Now when spin cycle starts and the tub turns it squeaks and grinds then I get a UE alarm.
The agitator has a gear like attachment that meets the long shaft up the center of the tub. If the alignment is off and not exactly in place the agitator will move or the gear-like part will wear down, become rounded, or break. The agitator must fit perfectly and tight. A nut on top (under the cap) has to be turned down tight.
Feb 27, 2014 | LG WM0642H Front Load
My Whirlpool Ultimate Care II washer goes thru all cycles but will not spin, so clothes are wet. We replaced the motor coupler but will only spin without clothes. Once you put clothes in the tub does
sounds like direct drive gears are bad.. there is a slip coupling that goes over the shaft of the transmission adn assist turning the tub that could be worn or broken. you will have to remove the agitator and check the nut on top of the tub to see if it is tight or to remove the nut and check that coupling.
Dec 01, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
It's making a very loud banging noise in spin cycle
There can be any number of reasons for the tub slipping / jerking.
First, see the Sears parts site for your washer:
http://beta.searspartsdirect.com/partsdirect/getModel!retrieveModelDetails.pd?modelNumber=11092584100&productCategoryId=0153200&brandId=0582&brandDescription=KENMORE&modelName=WASHER&searchedModel=110.92584110
and you'll see a list of major sub-components with diagrams and parts.
It's possible that the drive block and / or tabs holding the tub to the block are worn / damaged.
Also see the Whirlpool / Kenmore Service Manuals for these washers:
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
I'd essentially pull the washer apart to check that everything is in place.
(IT'S NOT AS DIFFICULT AS IT MAY SOUND AND MOST FIXES ON THESE WASHERS AREN'T VERY EXPENSIVE)
See the following for a detailed description of how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=75a4070beeb01ac4cd6c732ff4f740fc
NOTE:
You don't have to buy a special spanner wrench ($20) to remove the spanner nut. I've used a short 10" pipe wrench (about $9.00 also good for cracking walnuts) hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
The problem does point to the drive block and/or the nut holding the tub to the block. The block is soft metal and easily damaged if the nut isn't tight. Also check the tabs on the tub to make sure that they fit into the notches in the block.
Jul 24, 2010 | Kenmore Washing Machines
The spinning part at the base of the lawnmower has stopped spinning, and i cant figure out why. i think it has something to do with connection issues in the nick and the connection to the lawn mower it...
Hello. Most likely the nut which holds the blade tight has loosened enough that the motor spins the shaft but the blade just sits there and doesn't spin. This is an easy repair. You will need a large crescent wrench, or the properly sized open end wrench and a 2 foot long piece of 2x4 lumber. Use the lumber to "lock" the blade against the frame once you have the nut fairly tight. Then give it one more turn to be sure the nut doesn't loosen up on you again. It is best to do this job without turning the mower upside down as doing that will cause the oil to go into the air filter and then it will not start. If this is all basically greek to you ask a neighbor or a friend for help. It is really only a two minute job. J.
May 30, 2010 | Garden
Jan 25, 2010 | Kenmore 22422 Top Load Washer
Dec 22, 2009 | GE WBSR3140DW Top Load Washer
How do you remove the jets on an american standard whirlpool tub they are leakin and i believe the seals are bad
The jets have a nut on the back of the jet. I hope you have access or else you will need to pull the tub for this job. Loosen the nut and squeeze aquarium grade silicone in between the tub wall and the nut, Tighten the nut, but not to tight. Let set over night fill and check for leaks the next day.
Sep 15, 2009 | Home
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
