D-LINK DI-524 coverage Issue
I have wireless router DI-524. There is problem with my router that whenever I want to make use of WIFI for Mobile / Laptop, they will work on WIFI only when placed very close to the router and also not beyond 1 meter. Also signal strenth that shows on mobile / laptop is one small signal. Can somebody help me how to fix that problem. (I also replaced the wireless antenna of the router with new one but it didnt work for me as well). Thanks Aasif
  • 7,627 Answers
You can reboot ALL the devices . Unplug the Modem, remove battery, Unplug the D Link. Install battery in Modem, plug into AC, allow the device to selftest, plug in D Link allow it to self test. Reboot computer. Have you secured the wireless? Changed Channels for better signal? Take a look at this: http://www.microsoft.com/athome/setup/wirelesstips.aspx#fbid=nZTFiYrDLMg
Posted on Dec 05, 2012
  • Muhammad
    Muhammad Dec 09, 2012
    Well i did changed the channels , tried with new antenna, updated firmware but it didnt solve my problem. Should I abandone it or still I have got some chance? Thanks for the advise
  • max carson
    max carson Dec 09, 2012
    Sound like you have covered everything. Your ISP? have you contacted them? Have you verified ALL cables? From where in comes in all the way through to the wireless device? Is your ISP "Throttling" your service due to over use? See:http://www.pcworld.com/article/158552/ch...
3 Suggested Answers
  • 171 Answers
SOURCE: DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Posted on Jan 25, 2008
melnavz
  • 1226 Answers
SOURCE: Drivers for DI-524 Wireless Rourter D-Link
You can find donwload here:
http://support.dlink.com/products/revision.asp
follow the instruction.
me this help,
melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Posted on May 21, 2008
Need a wifi repeater
If you have a spare router you can set that up to expand your wifi coverage.
Here is a magazine article how to do it: How to set up spare router to expand your Wi Fi network coverage
Feb 10, 2014 | D-Link AirPlus DI-524 Wireless Router
No encuentro el rauter
Sir
I suggest You watch below you tube video for D-Link AirPlus DI-524 Wireless Router configuration to resolve your D-Link AirPlus DI-524 Wireless Router Issues,
Link AirPlus DI 614 Wireless router 100
Or
in case you still having D - link Router Problem Then follow Us On for Online D - Link Router Setup Support By Our online D -Link Router Technician on Below Mention Link URL website,
http://www.techsupportrouter.com/support-for-d-link-router.html
Feb 09, 2014 | D-Link AirPlus DI-524 Wireless Router
I reset my computer to original setting and forgot to write down my wifi password. How do i recover it?
You don't - you reset the router with the button at the rear and you login into it using the default one (admin) and do all the setting again as explained here
http://technicallyeasy.net/2008/02/how-to-reset-d-link-di-524-wireless/
Sep 19, 2011 | D-Link AirPlus DI-524 Wireless Router
I have a mac and am having trouble with the
Whenever I have problems like you describe, I try to simplify. Remove the encryption key & see if your mac will connect. If YES, then add a simple key. I go with all numbers. Add complexity as you succeed. At the end of this process, reconfig all the other devices.
Jun 04, 2010 | D-Link AirPlus DI-524 Wireless Router
Connect to wireless
here you get the manual sir:
ftp://ftp.dlink.se/Products/di-products/di-524/Documentation/DI-524_manual.pdf -
or
www.amazon.com/D-Link-DI-524-Wireless-Router-802-11g/dp/B0001PFQ08 - 256k -
or
reviews.cnet.com/routers/d-link-di-524/4505-3319_7-30839580.html - 79k -
thanking you
Jul 09, 2008 | D-Link AirPlus DI-524 Wireless Router
me this help,
melnavz
PS:
May 21, 2008 | D-Link AirPlus DI-524 Wireless Router
Compatability
It will, as long as your squeezebox wireless card has support 802.11g wifi standard .
May 15, 2008 | D-Link AirPlus DI-524 Wireless Router
Coverage and speed have reduced
You can find the complete solution on the web link given below.
Please click on the web link given below and check for the exact issue and solution to get the issue fixed.
http://support.dlink.com/supportfaq/
I hope this will help you further with the router information and maintainence.
Have a great day!
Feb 29, 2008 | D-Link AirPlus DI-524 Wireless Router
Connecting a DI-524 to a DI-604
This shouldn't really be any problem simply use a short "Uplink" ethernet cable to join the routers thru the uplink port, or any port really, and that way ya should be able to wifi and access the net, set ya router that connects to the net for DCHP and disable that setting in the Wifi router and ya should be good to go?
Jan 30, 2008 | D-Link AirPlus DI-524 Wireless Router
Jan 24, 2008 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
David Payne
David Payne
