Question about Epson OEM T008201 inkjet cartridge - T008, Sytlus Photo 870, 875, 780, 890 Printer
All lights came on
The indicator lights came ,one for ink replace, one for paper and I can't turn it off unless I pull the plug. I would like to see a diagram if possible.
Paul Pomaibo
U150 error on canon mx885
Solution 1:
  • Open the paper output tray.
  • Turn on the printer and open the scanning unit. The printer cartridge carriage will move to the center. Open the inner cover securing the cartridge in place by pulling it downward.
  • Press the tab on the problematic ink cartridge and lift it to remove it from the printer. You will be able to tell which ink cartridge is causing the problem because its indicator light will be off or flashing.
  • Open the replacement ink cartridge and pull the orange tape in the direction of the arrow to remove the protective film. Tear the orange tape off along the dotted line.
  • Place the ink cartridges into the printer and press where indicated on the cartridge until it clicks into place. Ensure that all ink cartridges have a red indicator light showing that they are properly installed.
  • Close the inner cover on the cartridge carriage and the scanning unit. The printer will automatically start a print head cleaning cycle. When the cleaning cycle is complete, the printer is ready to use.
Solution 2:
  • Put the little green circuit board from the old ink cartridge of the same color in the new cartridge.
Apr 17, 2012 | Canon Office Equipment & Supplies
Red light under ink cartridge
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
  1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
  2. Open the printer cover and remove both the cartridges.
  3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
  4. Close the printer cover.
  5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first.
  7. Close the printer cover and check the light status.
  8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
  9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
  10. Load some paper. Try to print a document again to verify that the problem is fixed.
Mar 19, 2012 | Lexmark X8350 All-In-One InkJet Printer
Orange light flashing printer not printing
On an HP the flashing orange indicates trouble, be it the printer has just plain gone bad to almost anything else, I would try re-seating the ink cartridges, check for paper jams, or any sounds out of the ordinary when you turn it on, as I need some clarification to give you a more specific answer.
Check the back of the printer for a reset button, most 5000 series have them, it will allow you to hard reset the printer which may just do the trick, if not, turn the printer on and pull the power while it is on, wait 60 seconds, plug it in and turn it back on.
There is a good chance that a critical component in the printer has given up its ghost, so be prepared for the worst but hope for the best, give some of those options a try and get back to me, at which point I can help you narrow down what is ailing your printer.
Mar 03, 2011 | HP DeskJet 5550 InkJet Printer
I replaced my black cartridge and now my ink/paper light remains lit and when i press it, after a few noises, the green power light begins to blink. i have recently replaced the color cartridge as well.
It is important for you to post the make of your printer. Anyway, it sounds like your new cartridge is faulty, which is not unusual. First of all, turn your machine off, unplug it, wait a minute, then plug it in and turn it on. If the problem is still there, try another new cartridge. If the problem goes away, get a refund for the one you just replaced.
Feb 17, 2011 | Office Equipment & Supplies
Colour ink cartridge empty but the on off light and red ink light flashes alternately and the carriage will not move to allow access to remove the empty cartridge.
hello, are you sure its not the error light that is blinking alternately with the power light, or is ink light indicator blinking , and just the power light blinking. i would first problably pull the power cord. then plug back in, and try again. the alternating error light and power light would be inkjet service, maint or waste pads are full, as far as the other error, i looked it up, and that error not coming up, unless there is something else going on. maybe cover for ink cartridge is caught, and not allowing printer to cycle.
Oct 05, 2010 | Epson Stylus Photo 1290 InkJet Printer
Doesn't want to print
Try unplugging from the wall for 5 minutes / plug in and retry, cancels / resets printer memory.
Feb 17, 2010 | Canon BJC 3000 InkJet Printer
Paper Jam
You need to try clearing the paper using a airblower if you do not have a air blower try with a vacuum cleaner, surely it cleans up. Unless until you remove the paper it shows the msg.
If you think you have no other option and you tried everything its better to call some service guy and get it done.
Regards
Oct 03, 2009 | Office Equipment & Supplies
My printer is saying unable to print
Try one or more of these solutions:
  • Press the fontp.gif power button to make sure that the printer is on.
  • Turn off the printer and make sure that the power cord is securely plugged in.
  • Make sure that your outlet works and is not controlled by a wall switch or timer
Lights came on and then went out
The printer's voltage may not match the outlet rating. Turn off the printer and unplug it immediately. Then, check the printer labels.
If the voltage does not match, DO NOT PLUG YOUR PRINTER BACK IN. Contact your dealer.
Only the power light is on
  • Turn off the printer and computer. Make sure that the printer's interface cable is securely plugged in.
  • Make sure that there is no packing material in the printer.
  • Turn off the printer and the computer and disconnect the printer's interface cable. Then, print an operation check page. See Running a printer operation check.
If the check page prints correctly, make sure that the printer software and your application are installed correctly.
  • If you are trying to print a large image, your computer may not have enough memory to print. Try printing a smaller image.
  • Windows Me and 98 users can clear any stalled print jobs from the Spool Manager. For instructions, see Using EPSON Spool Manager.
  • If the printer sounds like it is trying to print, but is unable to, run the Head Cleaning utility.
Paper out light is flashing or on Check EPSON Status Monitor 3 (for Windows) or EPSON StatusMonitor (for Macintosh) to find the cause of the error, then try one or more of these solutions:
  • If the fontm1.gif paper out light is on and there is no paper in the printer, load paper into the sheet feeder.
  • If the fonth.gif ink out light is flashing, a low supply of ink is indicated. Obtain a replacement cartridge of the appropriate type. To determine which cartridge requires replacement, see Replacing an Empty Ink Cartridge.
  • If the fonth.gif ink out light is on and the ink cartridge is empty, replace the appropriate ink cartridge. To determine which ink cartridge is empty, see Replacing an Empty Ink Cartridge.
Error light is on and power light is flashing
Follow the steps below.
r_1.gif Press the fontm1.gif paper button, then remove any paper from the printer. r_2.gif Turn the printer off. Check for and remove any foreign objects or pieces of paper from inside the printer. Also, make sure that there is sufficient space around the vent on the back of the printer to allow proper ventilation. Remove any objects blocking the vent. Then, turn the printer back on
May 27, 2009 | Brother MFC-210C All-In-One Printer
Printor indicator brinking and paper light is always on
Printor indicator light is brinking and Paper indicator light is always on and never disappear even if I feed the paper and push the paper button
Nov 16, 2008 | HP Business Inkjet 1000 - Printer - colour...
26 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
