Question about Canon PIXMA iP1600 Printer
Canon PIXMA MP140 can't recognize the cartridge even though the ink tank is full
    Problem Solver:
  • 4 Answers
Make sure the cartridge is seated properly. Clean printer heads when installing according to instructions. Don't cut corners and just try and print, so through all the steps. Sometimes just turning your printer off and then back on helps too. Sounds like it doesn't know it has a new cartridge.
Posted on Jan 17, 2009
Error 19
Hi there-
Below are a list of the error codes for this model.
E16-E19 = Failed to scan head alignment sheet.
You can find this information at http://www.usa.canon.com/cusa/home
CANON MP140, MP145, MP150, MP160 RESET ERROR CODES
[Info140] pixel_trans.gif RESET ERROR CODES CANON MP140, MP145, MP150, MP160
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge
is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera
Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Nov 29, 2013 | Canon PIXMA MP150 All-In-One InkJet...
Coloured ink not registering
You can only refill those cartridges if you do it before the ink is empty. After that you need a new cartridge or a chip resetter to reset the chip on the cartridge so it will work again.
Oct 12, 2009 | Canon PIXMA MP150 All-In-One InkJet...
MP610 does not recognize ink tank . This keeps happening even after restting the tank (tank is full). Initially, I could lift the tank up and reseat it and it would resolve the problem...not anymore. I...
Every now and then we get a defective cartridge, and Canon will replace it. If it's generic or refilled, you just need a new one. It's a cartridge problem, not a printer problem
Aug 11, 2009 | Canon PIXMA MP610 InkJet Printer
Not recognize ink cartrdige Canon 6700D
Best thing to do is just replace the the indicated ink cartridge. Reason being is that even though the cartridge still has ink in it, it is the metal contacts on the cartridge that have to communicate with the printers on-board memory. If the contacts on the cartridge are fouled and are not communicating with the printer, the cartridge is telling the printer that "I am empty and I need to be replaced", even if it is full of ink. This would apply to all six cartridges.
Mar 07, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Canon pixma MP600 wont recognize ink tank. Seldom used
Hello!
I have the same printer and the only ink cartridges I use are Canons own.
I've tried these cheaper replacement ones and zip nothing will not recognise them.
It is false economy as now I have a full bank of copy ink cartridges that charity will not even accept.
Hope this helps!
Paul 'W'
Onyer~EDson(:0) {#>< U.K.
Jan 14, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP140 error code E
Replace with genuine cartridges is the best policy.
Sep 21, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
CANON 1P4200 PRINTER
I would try a new ink tank. They do go bad even though they have ink in them.
Mar 21, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Won't recognize black ink tank - even when a new one used!!!
Are you using Canon brand ink?
Could be dirty contacts in the carrange behind the cartridge. Clean with the eraser on a pencil.
Jan 11, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
MP500 ink tank cannot be recognized error U043
Same problem - two solutions I found helped me work out mine. One said contacts needed to be cleaned and it worked to use a Q-tip and alcohol or just click it in position several times until it recognizes the cartridge - this may work. Another said that they got it to work by installing a brand new cartridge - cool, but I have one full of ink it won't recognize. So I pulled the little circuit board off a used cartridge (like you need to do with some refills) and put it on the cartridge that it wouldn't recogrnize - works great. Still haven't figured out how to get it to acknowledge ink levels though. Canon really should be more consumer friendly since these problems seem to be intended to compel the use of proprietary cartridges.
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA iP1600 Printer Logo
195 people viewed this question
old marine
old marine
