How do you install a VCR/DVD on this TV which uses a antenna
    Sergeant:
  • 233 Answers
You will have to get an "RF modulator" from radio shack- they will be able to help you!
Posted on Jan 12, 2009
2 Suggested Answers
SOURCE: I have just installed a
Go to http://vk3khb.gak.net.au/atv/chnlchrt.html#TV_Table
I went there and checked the details vs those appearing on my STB. Went through the manual channel search and changed the frequency to those on the above website. Now all channels work perfectly. I only bought this STB because my last one froze, it appears this one doesn't have the best auto search facility but with a bit of tinkering it will work for you!
Posted on Sep 25, 2008
Does the RCA model #F19207BC connect to a dvd/vcr player?
Nope. No external jacks for video and audio. You can use the antenna connection with the dvd /vcr player by connecting the antenna out on the player with a suitable length of coaxial cable with F connectors on both ends. Then you would locate the channel 3/4 switch on the player and choose either one. On the TV you would put the same channel on the TV tuner that matches the player channel and you will see the picture.
Aug 04, 2017 | RCA F19207BC TV
DVD video showing without DVD in
have you tried pressing the dvd button twice on the remote?
Apr 13, 2008 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
How to hookup vcr to TV to tape from satelitte
have a look at ur install bock it will tell u how to do it...connect antenna to ur vcr then use cable from ur vcr output to ur tv antenna ,,,,,after u have done this read instruction .....to connect ur dvd ....just plug ur cables from ur dvd to the back or ur tv....marked as dvd input....
cheers and good luck......very simple.....
Mar 06, 2009 | Panasonic TH-42PX500U 42 in. Plasma...
I have a vcr/dvd hooked up to my present tv with a antanna. How do i hook up the digital converter. so thatI still could use vcr. Thank You
It depends on brand of converter. In Radioshack they have one with AV-in ports (for $56 (-$40 coupon = $16). So TV signal going trough antenna and DVD/VCR going trough AV-in of converter to the same antenna of TV. Or you will have to hook up the CONVERTER - ANTENNA IN VCR/DVD - Antenna OUT VCR/DVD - ANTENNA IN TV. And you will use the remote of converter to switch the channels.
Good Luck
Jan 10, 2009 | Philips Magnavox DVD/VCR Dual Player
Sylvania vcr/dvd installation
!st) The antenna INPUT::RF (black wire usually from "cable TV", "Dish TV", even ANTENNA air wave reception,etc.) into INPUT of VCR\DVD, OUTPUT of VCR\DVD to TV RF input.
2nd) If you have INPUT\OUTPUT to what are called " RCA " jacks on your TV, on the front or on the back, then any & all output jacks from VCR\DVD goes to INPUT\OUTPUT of the TV.
In other words:: output of audio on VHS\DVD to input of audio on TV( RCA jacks). Output of video on VHS\DVD to input of video (RCA jacks)
Hope this helps
Aug 14, 2008 | Televison & Video
Using vcd/dvd combo with digital converter box
"Sounds" correct to me.  Are you going by the instructions that came with the converter box?  And, "ANT In" to the box from your antenna?
Apr 04, 2008 | Samsung DVD-V8600 DVD Player/VCR
Connecting VCR/DVD combo
If you are able to you can connect to the RF connector (F Type Conncetor) on the TV. This should work. The layout is from the VCR (RF to TV) to the TV antenna F type connector from your Cable box to the Antenna in of the VCR that way you have cable through the VCR, and access to you VCR and DVD all controlled by the Cable and VCR remotes (set TV to Channel 3, set VCR to Channel 3) and use the Cable box as the tuner, Use the TV remote to switch between Cable and VCR inputs then use the VCR remote to switch between the VCR and DVD input.
Sep 20, 2007 | GE 25GT516 TV
Hooking tv up to my vcr/dvd combo
hook the antenna to the VCR rf conecter IN. buy some RCA jacks and a three way deal and hook the red to sound red out ,white to sound output white, and yellow is always video hookit to yellow vido out on the vcr/dvd. The other ends go to the inputs on the TV....same color code. or you can just hook a cable to rf connector OUT on the vcr and other end to( it with problably just same antenna in) to TV.
Aug 29, 2007 | Sanyo DS31520 31" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
