Question about Hasbro I-DOG AMP'D
I dog behaving randomly
I bought an I dog about a week ago and it worked fine for awhile, now it's started operating erratically. It won't move for days then it will start to move for no reason then stop again. Also it seems to be stuck in listening mood as the lights come on by themselves even if no music or sounds are playing.
I've tried the reset button, changing the batteries, and it's not in try me mood, but nothing seems to help
  • 1 more comment
  • megax01
    megax01 Jan 13, 2009
    I tried that already and it didn't help, the volume control works fine and it plays music.
    Its just not moving and like i said the light flashes whether there's noise or its quiet.
  • megax01
    Can I have the I Dog Chip repaired at any electronics shop or do I have to send it back to Hasbro
  • megax01
    Nothing helped the dog is still behaving randomly, I suspect that it really is a chip problem though. So I guess it was kind of helpful
  • 19,396 Answers
If the toy is only one week old, call Hasbro and get the item replaced (Click).
Posted on Jan 13, 2009
  • 47 Answers
The best thing for You is, if the dog is under warranty, to have the customer service department of Hasbro take a look at the dog and, since this might be caused by an internal software error or by a microchip error, replace the dog's software or microchip.
    Sergeant:
  • 431 Answers
May be problem with the motor and the internal gears check it out it may help u out
    Sergeant:
  • 378 Answers
You will just have to get your chip repaired as its the chip problem but if the company is providing you the replacement first try that and see, thanks.
    Sergeant:
  • 221 Answers
As this electronics material  has to be used very carefully as if banged or fallen down somewhere creates this problem as there is a small chip in the unit called circuit that circuit is now getting cut in between so the idod is behaving like this that chip has to be repaired by a normal repair center .the cost should not exceed more then $5 as it is very minor reparing internally.just a soldering or a minir joint to be done. thanks.
    Sergeant:
    Novelist:
  • 326 Answers
Try holding down the nose until you hear whining and see a led light pattern.
  • Volume controlled by toggling the tail back and forth
  • as it should work
  • but if still does not work.hold the i-dog in your hand and shake it completely for half a minute.
  • then try.or its the time for its replacement as this does not has any garrantee.
    Brigadier General:
  • 5,158 Answers
Usual reset procedure... take the batteries out for about 15 minutes... put them back in and try it
    President:
  • 2,110 Answers
Turn on underside near front legs. TAIL CONTROLS VOLUME FRONT TO BACK. Push nose and rub face. Connect to MP3 or Ipod switch the short cord end to end and sometimes that makes a difference.
I have a 2001 Mazda MPV the problem is this it will start fine fir awhile and then I will go out and wont start. Yet if I try it again later it will start up no problem it has got a couple of mechanics...
If it is turning over when it does not start, may be a fuel pump going bad. Gets hot and stalls out and won\'t start till it cools
down. Must be replaced. Check fuel filter as well. Could also be something as simple as a bad battery, starter or alternator connection... Corrosion is a bummer!
Oct 21, 2013 | 2001 Mazda MPV
I have a 2000 vw jetta. It's a v6 and is
You got a lemon. Most likely one of the coils is giving out if your model has two or a connector may be loose somewhere. You'll have to get it checked out.
Sep 10, 2012 | Cars & Trucks
91 primera sr18 Di,have fixed vacume leak's in inletmainfold,replaced the airflow meter,have got it running excellently but after it has been running for awhile,it randomly dies and wont start again f
I had a similar problem. Nissan sr18di engine. car would run fine and randomly engine would cut off and only start after 20 minutes. Changed distributer
fine since
Nov 09, 2011 | Cars & Trucks
Can not move files to usb drive,use system information or system restore,when opening a program windows installer starts up?
Sounds like you have a corrupted registry. Programs and files are behaving erratically or as if they are not correctly or fully registered or installed. You may need to reinstall your operating system. Good luck.
Oct 01, 2009 | Acer Veriton M460 Micro Tower Core 2 DUO...
Cursor on my keypad jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
2. Adjust the sensitivity of the touch pad:.
a. Click the Start button and click Control Panel.
b. Click Printers and Other Hardware.
c. Click Mouse.
d. When the Mouse Properties window appears, click the Pointer Options tab.
e. Under Select a pointer speed:, click to move the slider bar closer to Slow.
f. Click OK.
g. Check to see if the touch pad still behaves erratically.
3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
4. After connecting an external mouse, uninstall the touchpad driver from the Device manager listed under the "mice and other pointing devices" category and restart the Computer.
5. Download the Touchpad driver compatible to the Operating System installed on the Computer from the manufacturer's site and install it after restarting the Computer.
Good luck!!!!!!!!!!
Sep 18, 2009 | Dell Inspiron 6000 Notebook
Ryobi SS30 Carburetor Problems
Replace thecarb screen, make sure you can see through the screen
Aug 18, 2009 | Ryobi Garden
1992 SUZUKI SIDEKICK AUTOMATIC HAS BRAKES LOCKING UP ON RANDOM WHEELS WHEN TURNED OFF AFTER SHORT DRIVE. REPLACED CALIPERS, MASTER CYLINDER, BRAKE LINES, FRONT PADS, BACK ONES FINE. PEDAL IS VERY HARD...
Try the following to confirm if is the servo unit .( engine off,pump few times the brake pedal to become stiff.Keeping pressed the pedal start the engine and if servo is working you will feel the pedal slightly goes down.If not will not move at all-remain stiff.) Also if you do have the check valve close to servo not working you can realize it by the engine idle ( erratic ) and the servo not working.The other possibility if the vehicle is fitted,the ABS unit itself.
Dec 27, 2017 | 1992 Suzuki Sidekick
I HAVE A LOGITECH CORDLESS MEDIA MOUSE BOUGHT ABOUT THREE MONTHS AGO AND IT WORKED VERY WELL UNTILL A FEW WEEKS AGO WHEN THE VOLUME BUTTON STARTED TO MALFUNCTION IT BEHAVES LIKE IF IT WERE BLOCKED ON THE...
1) Do not ask questions in CAPS. It's bad form and considered rude in some forums.
2) It's a failed mouse. Replace it or call the manufacturer for replacement.
Jul 17, 2008 | Computers & Internet
Marble mouse problems
I have a problem like this with the marble mouse ... relatively easy workaround for me is if I simply grab the trackball with my fingers, lift it slightly out of its cradle, and put it back down, it starts working again. It would be better if there were some way to prevent it from freezing in the first place.
I had another marble mouse a couple years ago that did not have this problem. Eventually one of its button switches went bad so I had to replace the mouse. This is the replacement.
Feb 05, 2007 | Logitech Marble Mouse PS2/USB MSLO904360
Hasbro I-DOG AMP'D Logo
Top Hasbro Toys Experts
Jesse Walters
Jesse Walters
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
