Question about Kenmore 96213 Electric Kitchen Range
Element on light stays on
Tried powering down and up - no luck
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
Your symptoms indicate that you have a stuck contact on one of the burner switches in the console. What is the model number?
Posted on Dec 05, 2012
My Samsung dryer DV218AEWXAA is not coming on. There are no lights on the dryer. We recently had the heating element replaced. What could be wrong with it?
Is ther power at the outlet? If yes, try unplugging dryer and plugging it back in. If that doesn't work, try unplugging and plugging back in while holding down power button. Good luck.
Mar 05, 2015 | Samsung Dryers
Element light stays on after all power control knobs are in off position?
Good Afternoon Cindy,
I see that you are having trouble with the element light staying on after all power control knobs have been put into the off position on your Frigidaire range, model# FEF366EC. The Element ON indicator lights will glow when one or more of the surface elements are turned ON. A quick glance at these indicator lights when cooking is finished is an easy check to be sure all control knobs are turned OFF. The Hot Surface indicator light will continue to glow AFTER the control knob is turned to the OFF position and will glow until the heating surface area has cooled sufficiently. I suggest resetting your appliance by shutting the power off at your home's circuit breaker for 2-3 minutes. Once power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "clock" button, and then you will press and hold down either the up or down arrows until the correct time appears. Try turning the burner on that the indicator light stays on the most. When you turn it off if you are still having trouble with the element light staying on, I suggest contacting a local authorized technician. Hope this helps.
-Best Regards-
WP
Apr 27, 2014 | Frigidaire FEF366EC 30" Freestanding...
Element flat screen tv screen appears off when power is on
At this stage, try replacing ps Caps. Old elements had cap problems in ps area.
Feb 11, 2014 | Element Electronics Televison & Video
Belling cookcenter oven over heats and light stays on
It sounds like the people who changed the elements did not connect them to the correct wires. The thermostat seems to have no effect on the elements, and the light switch seems to have no effect on the light, explain this to them and that you think they fitted the elements directly onto the power input to the device, instead of the correct connections.
Dec 14, 2013 | Ovens
Oven does not heat
This clicking sound.. If it is coming from the control panel area could be indicative of a relay that is malfunctioning.
For giggles try the oven on just broil. See if the upper element comes on and stays on, or if it too shuts down.
If it stays on then you most likely have a bad control board.
If it shuts off like the bake element and does not come back on, I would carefully inspect your power cord and cord connections as well as the range outlet.
Jun 16, 2010 | Kitchen Ranges
Kitchen aid dryer / heat flame not staying on after 20 secs
Sounds like your gas valve is fine, if it comes on at all, its good. A air flow restriction would cause a overheat condition and shut down the burner. Once it cools back down the burner would re-ignite and repeat the cycle. The sensor on the left of the burner is the flame sensor and the flame wouldn't come on at all if it was bad. You've already changed the coil kit so the valve is fine, disconnect the vent from the back of the dryer and see if the problem goes away. If the problem stays, I would suspect the thermostat. Good luck.
Mar 16, 2010 | KitchenAid Dryers
The toaster arms will not stay down on either side , have power to the toaster and can see the elements light when arm is held down but won't stay down.
First, turn it to the darkest setting. It may be set too light to stay down. Also, try cleaning it out. Take it outside and turn it upside down and shake it. Also, open the crumb door on the bottom. Hope this helps. Good Luck.
Feb 10, 2010 | Cuisinart CPT-180 Metal Classic 4-Slice...
Fridge works fine on shore power. When turn gas
What model fridge? Sound like you have a bad 12 volt heat element or there is a possibility the board is bad but the likely is the heat element.
You can remove the cover on the circuit board and unplug the 12 volt element. Do an Ohms reading on the element. Should be 35-35 Ohms. If that is ok Turn the fridge on and with a VOM check for 12 volt power on the terminals the heat element was plugged into. If there is no power the board is bad. There is also a possibility the upper board is bad. I would start with the lower circuit board. Check for power at the heat element terminals if you have power there then I would say you need to replace the heat element. The heat element is mounted in the boiler tube and just slides uo to remove it. Good luck
Thanks for using Fixya
Jerry
Mar 30, 2009 | Dometic Refrigerators
Indesit WI101 tripping Electric RCD
try running with the element disconnected and the wires taped up. usual cause is the element down to earth.
try same procedure with the motor disconnected
Nov 26, 2008 | Zanussi WJS1397W Front Load Washer / Dryer
Hot surface indicator
The component that controls the hot surface light is part of the element. If there is a light for each element you just replace that element. If there's one for the whole surface or each side you'll have to figure out which element is causing the problem.
Oct 27, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Kenmore 96213 Electric Kitchen Range Logo
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
