Question about Toshiba Computers & Internet
Need to reboot my toshiba satellite L750D laptop with Windows 7
Laptop will not boot. Message reads: No bootable device -- insert boot disk and press any key Why did it crash??? Thanks Lorraine
  • Toshiba Master
  • 32,281 Answers
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Posted on Dec 05, 2012
SmartFix
  • 89 Answers
SOURCE: When I Turn On My Aspire One mini Laptop, Windows
  • You have to boot with the operationg system cd.
  • If not Click here and follow to Create boot disk.
Please rate my response!!! Thanks, SF
Posted on Jan 28, 2010
  • 9 Answers
SOURCE: my laptop does not boot
it means you have no hard drive. check and see if it is loose and that might be it...if thats not it then check your boot order in your settings on the startup screen....let me know
Posted on Mar 11, 2009
SOURCE: Acer Aspire One Insert boot disk
well u really cant put in a disc, you said you have the aspire one that means it doesn,t have a disc drive . Thats the way it was made
Posted on Jul 10, 2009
  • 106 Answers
SOURCE: This message comes up after I turn on my laptop
Note: Before going through any options make sure you are not in warranty. Under warranty products are recommended to be given back to vendor for solution
There could be 2 reasons.
1. OS Corrupted / Not installed
2. Hard Disk loose connection
For first option you can try repairing your OS by loading the OS CD during repairing if it doesnt finds you hard disk then definately it would be related to loose connection of Hard disk.
For second you might need to unscrew few screws after going through your laptop manual.
Posted on May 17, 2010
paul7of9
  • 1189 Answers
SOURCE: I AM GETTING A
Hi, in BIOS; do the following: "restart the Computer, and just before the Computer start to load the OS. You must "Press the [F12] button when you here the "Fan" startup, you will also see for a brief moment in the {lower left corner of the screen}. *Press F12 Button to open the {BOOT Setup}. Once the "Boot Manager / Setup / Options" window open, go to the "Boot Device Option," next choose device by [Boot Priority] using the (arrows: Up, Down...) "choose the known booting device," ie: "SATA" Drive. After you have made all the changes; {Press F10 to Save and Exit}. To finalize the configuration change, the Computer will "Reboot." "I hope this information help, give a "Rating" if so, this is the way Fix' Ya work; I help, my reward is a rating on how helpful the "solution is / was," thanks!"
Posted on Jul 11, 2010
ERROR : F3-F100-0003 when running recovery disc for Toshiba Satillite L755-25217
Just format your Laptop because your operating system is damage.Install another Operating System that's all.
Mar 26, 2013 | Computers & Internet
How to change disk controller in bios on Toshiba Satellite A135-s2276?
Hello here is the homepage:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1596141&
You need this for the drivers.
And you can downlaod a manual
Press the "F2" key to access the Toshiba Satellite's BIOS menu. Use the right arrow key to navigate to the BIOS tab labeled "Boot."
Read more: How to Change the Boot Order for a Toshiba Satellite ' eHow.com http://www.ehow.com/how_6383103_change-boot-order-toshiba-satellite.html#ixzz2Cn6HdU2k
Turn on or restart your computer and watch for a message during the post about a particular key, usually Del or F2, that you'll need to press to ...enter SETUP. Press this key as soon as you see the message.
Go to boot and select the boot order.Use F4 or F5 to change.
First boot device: Cd/dvd drive
Second: the harddrive.
Leave the bios and save the settings.
Place your windows cd in the drive and reboot.
Now you can install windows again.
Good luck
Nov 20, 2012 | Toshiba Satellite A135-S2276 Notebook
I have a toshiba satellite l655d-s5093 with windows 7 and it shows pxe-mof exiting intel pxe rom... no bootable device -- insert boot disk and press any key. any help to restore my computer? Thanks
Try a "Cold-Start",Remove all media, DVD, CD, USB..etc., Remove AC plug, Remove Battery, Hold down on/off button for 10 seconds, Replace battery, Plug into AC outlet,Push on/off button and Start normally.
IF THAT FAILS, try F-8 during pre boot, try to get to safe mode, or F12 to enter restore /recovery. After each try cold start, remove battery during this process.
Nov 09, 2012 | Toshiba Satellite L655D-S5093 Laptop
It keeps tellin me no bootable device-- insert boot disk and press any key... i also dont have a disk drive all i have is a ubs flash drive spot
Oct 17, 2012 | Acer Aspire One D257 Netbook
My acer aspire one netbook AOD257 keeps telling me no bootable device insert boot disk
Oct 17, 2012 | Acer Aspire One Netbook 8.9" Notebook
My toshiba satellite l645d is giving me error message check connection cable no bootable device
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jul 01, 2012 | Toshiba Satellite L645D-S4036 Notebook
I Cant get my toshiba satellite L305D-S5974 to load. I get either a blank screen with curser arrow or message that says: no bootable device -- insert booth disk and press any key. Can't find any of my...
The laptop is not seeing any hard drive. remove the panel underneath (2 screws) and remove and refit the hard drive. If it still does not work then enter the bios by hitting the F2 key while booting and look at that page. under HDD model name and hdd serial number there should be information on the drive. If there is such info then the drive is being seen but cannot be accessed. Anyway it looks like the drive has had it. You will need to find your windows disk when you fit a new drive and reinstall windows.
Apr 27, 2011 | Toshiba Satellite L305D-S5974 Laptop
I AM GETTING A "NO BOOTABLE DEVICE - INSERT BOOT DISK AND PRESS ANY KEY' MESSAGE WHEN I TURN ON MY TOSHIBA SATELLITE LAPTOP. HOW DO I GET TO THE OPERATING SYSTEM?
Jul 11, 2010 | Toshiba Satellite Pro L300 Notebook
Computers & Internet Logo
350 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
