Question about Ibase LGA775 Intel Core 2 Duo CPU Micro ATX Industrial Motherboard with Intel 945G chipset, Fast E and GbE, VGA, LPT/COM, IDE/SATA II, PCI/PCI-E slots, CF, HD Audio
How to overclock motherboard - Ibase LGA775 Intel Core 2 Duo CPU Micro ATX Industrial Motherboard with Intel 945G chipset, Fast E and GbE, VGA, LPT/COM, IDE/SATA II, PCI/PCI-E slots, CF, HD Audio
  • 3,799 Answers
Don't do it. I have just had to inform a customer that he has killed his hex core Bulldozer and it is going to cost him. Just upgrade your processor. Cheaper, easier and less likely to cost you more in the long run. They are available for not a lot of money on the second hand market.
Posted on Dec 06, 2012
Overclocking
There are many issues to consider when overclocking and the first is to be sure that you have extra cooling for your processor. On this motherboard I do not recommend overclocking but since ASUS says that it can be done I will try to give you some places to get information on your A7V880 system. If you do not have your user's manual, you can go to the link below and download one.
http://www.asus.com/Motherboards/AMD_Socket_A/A7V880/#download . Leave the OVER_VOLT1 jumper on the motherboard on the default of pins 1 & 2. Refer then to section 2.4.5 on pages 2-21,22 of the User's Manual for Jumper Free configuration overclocking settings. In BIOS Setup I suggest a CPU Multiple of 10 or less. If you choose to use the AI Overclock Tuner instead, a setting of [Overclock 20%] or less would be best. The VCORE Voltage setting will depend on the specs for the CPU that you are using. If you don't know leave it at Auto. As I said before, overheating of the CPU is a problem in overclocking and you can monitor the temperature via the Hardware Monitor. Refer to section 2.5.6 on page 2-26 of the manual. Modern cpu overclocking normally does not exceed 20% safely unless you are willing to spend a lot of money on liquid cooling and frequent replacement of damaged processors. I would be interested in hearing whether you decide to overclock or continuing with your present settings.
Nov 27, 2011 | ASUS A7V880 Motherboard
System failed due to cpu overclocking. Not setup for overclocking in the bios.
Reboot, and enter BIOS SETUP mode.
Choose "Load Default Settings".
This will "undo" any overclocking of your motherboard and of your CPU.
Sep 20, 2010 | ASUS P4P800-E Deluxe Motherboard
Overclocking with p5sd2-vm motherboard.
i have no install the sound driver please help to the install...............
Jul 27, 2010 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
I have a intel dg31pr motherboard with e7200 processor.i want to overclock it.plz help me............
Overclocking is something you should only do if you are fairly experienced with computers. Most motherboards that overclock are made for overclocking as are the processors used. Good overclocking requires a balance of increased FSB, multiplier, increased voltage to the ram and sometimes the processor as well, and excellent cooling. It is easy to burn out your system by overclocking. There are many things you should know first. For that reasion alone it is impossible for me to tell you how to overclock it.
But, go to www.extremeoverclocking.com. This is a site made for people who want to overclock. Read and browse through the forums. You will also find some excellent by the numbers guides there. Sigh up and jump in. When you perform your first overclock, come back and tell me. I've been overclocking since 2002.
Sirwriter
Nov 05, 2009 | Intel DG31PR Motherboard
How to overclock 945GCT-M2/1333 motherboard
Try getting an overclockers BIOS. ECS motherboards don't usually offer the best overclocking support.
Sep 30, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Overclocking
Overclocking is set from the BIOS configuration. Not all BIOS allows overclocking, it may need a BIOS upgrade.
Check the ASUS WEB site for your model motherboard.
Overclocking the CPU (ie running at a higher clock speed) and increasing Frontside bus speed will give better performance BUT there is a downside too, if you overclock too high you could overheat the CPU and it could fail.
Sep 01, 2009 | ASUS P5GC-MX/1333 Motherboard
Overclocking locked on 945gct-m2 mobo
There is no overclocking settings for this motherboard, the CPU speeds and core settings are automatically determined. You may be able to find a modified bios somewhere, but i would strongly suggest this not be done. A bad bios, or bad flash can essentially turn the motherboard into an expensive paperweight.
May 30, 2009 | Intel Computers & Internet
Does asus make a motherboard that u can overclock. have a asus p6t deluxe v2 motherboard...does the rampage 2 motherboard be overclocked without any problems?
Some motherboard manufacturers make there motherboards (MoBo) "Overclock-friendly", and yes Asus does make the motherboards that are in that category. If the one you currently have lack of that feature, you could get third party software but be carefull and read the instructions before you change anything. Besides, take into consideration that you have to have optimal cooling devices for your component such as air cooling or water cooling before you overclok anything in your computer, keep this in mind: overclocking=heat increase
Apr 26, 2009 | ASUS Computers & Internet
Overclock an Intel E6300 on a GA-8I945GZME-RH motherboard
You need to check your BIOS. If you can overclock you will see a selection for CPU and speed in BIOS. If not there then your motherboard does not allow you to overclock your CPU.
Rate this solution.
Jan 09, 2009 | Intel Core 2 Duo E6300 / 1.86 GHz...
Overclocking failed
Hi, If you have overclocked: 1. CPU or motherboard not up to it - run at default speed; or 2. Memory - try using other memory; or 3. Video Card - see if you can run the Video card at default speed and not with overclock speed; or 4. You may need to up the CPU B+ a bit. If not overclocked: a. Set BIOS/CMOS to default settings; or b. Disable any overclocking feature (even if not used); or c. Lower you CAS latency. Hope this be of some help/idea. ood luck and kind regards.
Sep 01, 2007 | ASUS P5RD1-VM Motherboard
Ibase LGA775 Intel Core 2 Duo CPU Micro ATX Industrial Motherboard with Intel 945G chipset, Fast E and GbE, VGA, LPT/COM, IDE/SATA II, PCI/PCI-E slots, CF, HD Audio Logo
35 people viewed this question
Top Ibase Computers & Internet Experts
David Payne
David Payne
Are you an Ibase Computer and Internet Expert? Answer questions, earn points and help others
