My front loader wont hold water, it fills and continually pumps out, I am not sure if the control board is the problem or something else.
Any help will be appreciated
Thanks
Ged
If the pump is on all the time, then you definately have a timer and or control board prob, the only other possibility is if the drain outlet hose is to low.
This will cause the water to syhon out , thereby giving the impression that it is pumping out all the time.
To check this, try lifting the drain hose higher, and see if that solves the prob.
Plz rate my solution.
thanks.
I am after a manual copy for a Bendix Duomatic WD 1054 B washing machine. I don't know how to work...
(More)
I am after a manual copy for a Bendix Duomatic WD 1054 B washing machine. I don't know how to work all of the contols in this machine, it is a second hand whitout the instructions. Please help!!!
machine goes through cycle but spends only 1 second on each process. then stops. overall programme...
(More)
machine goes through cycle but spends only 1 second on each process. then stops. overall programme time normal.
The error codes for 1,2 & 4 flashes are given in the operators manual but not 3. The drain...
(More)
The error codes for 1,2 & 4 flashes are given in the operators manual but not 3. The drain pump operates but goes into error when the water has been pumped out.
