Question about Averatec 6200 Notebook
System Restore I have a Averatec 6200 laptop and it will not let me do a system restore to the last good working configuration checkpoint, it will not go past the current month and date. It will also not let me do it in safe mode. I would like to do a restoration date or return it back to its original factory state. Please help.
  • Biju Thomas May 11, 2010
    Is there an error message or a note that comes up when you try to do a system restore? that can help identify the actual cause of it.
    President:
  • 8,637 Answers
Go to RUN and type in System Restore.
When it comes up you should be able to restore the computer to an earlier date.
Hope this helps. Bud
Posted on Jan 22, 2009
Shortcut keys
What have you tried ?
which operating system ?
You can use the System Configuration utility to perform a system restore.
There are three possible restore points: System checkpoints that Windows schedules
Manual restore points that you specify with the System Configuration utility
Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly.
This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points.
Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
Jul 22, 2013 | Acer Aspire Computers & Internet
Tip
How can I restore my PC?
<span><span> <p><span><span>If Windows is running (and you are logged in as administrator), choose <b>Start </b>&gt; <b>Programs</b> &gt; <b>Accessories</b> &gt;<b> System Tools</b> &gt; System Restore. Select "Restore my computer to an earlier time" and click click the Next.Now last checkpoint and click Next. <b>System Restore</b> message may appear - click OK. Now click Next on the confirmation page and the latest Windows XP configuration is restored. If you can not get Windows XP to start, press [F8] at boot and select "Last Known Good Configuration 'to load the latest <b>Windows XP</b> restore point loaded</SPAN><span></SPAN><span></SPAN><span><span></SPAN><span></SPAN>.</SPAN><span></SPAN><br> <P style="TEXT-ALIGN: left; TEXT-INDENT: 90pt; MARGIN: 0cm -16.7pt 0pt 0cm
on Feb 14, 2011 | Computers & Internet
Outtlook emails is blocked i cant get access to my emails
Step 1:
You might need to reinstall or do a system restore back to when it was working ?
You can use the System Configuration utility to perform a system restore. There are three possible restore points: System checkpoints that Windows schedules Manual restore points that you specify with the System Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Apr 11, 2013 | Acer Aspire Computers & Internet
When I Start My Acer Aspire 5336 Laptop, And Continue To My Password Screen, My Keyboard Will Not Work, Even The Mouse Pad. How Do I Fix It?
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
Feb 24, 2013 | Computers & Internet
Fatal system error 0x0000135
Step 1:
Feb 15, 2013 | Dell Computers & Internet
Turn on error 00173 ,00301,00163
Feb 13, 2013 | IBM ThinkPad 600X Notebook
0x00000ba how can solve this error
Feb 12, 2013 | Computers & Internet
Laptop not responsing
Step 1:
Feb 11, 2013 | Dell Computers & Internet
My dell laptop (latitude 2120) caps lock button keeps blinking and my laptop can't turn on?
Step 1:
Feb 07, 2013 | Dell Latitude 2120 Notebook
Toshiba satellit L875d-s7332 froze during factory recovery now says no bootable device
Step 1:
Feb 05, 2013 | Toshiba Satellite L875ds7332 Notebook...
Averatec 6200 Notebook Logo
96 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
