Question about Exercise & Fitness
My Proform 100 ZLX Exercycle is stuck in low/zero pedal resistance, and doesn't respond to console settings. Can this be economically fixed?
    Top Expert:
  • 12,223 Answers
Follow the steps, and fix it. God bless you
Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
Posted on Dec 05, 2012
4 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: My Pro-Form 330 elliptical has a resistance
Detachthe ends of the pedals from the crank axles. Spread a layer of machine greaseover the crank axles, then reattach the ends of the pedals.2
Removethe bolts connecting the pedals to the swing arms. Detach the pedals from thearms, then spread a layer of machine grease over the axles on the swing arms.On some models, the bolts may also serve as the axles. Reattach the pedals tothe arms.3
Removethe bolts connecting the swing arms to the elliptical's upright. Detach theswing arms from the upright, then spread a layer of machine grease over theaxles on the upright. Reattach the arms to the upright.
Posted on Nov 28, 2011
maxtreadmill
  • 832 Answers
SOURCE: Just bought my Proform 490 LE elliptical 1 day ago
If you purchase from a store I would take it back and exchange it, or if you purchased it on line then the manufaturer and have send somebody out to take care of this situation you have a warraty on the unit
Posted on Mar 13, 2010
maxtreadmill
  • 832 Answers
SOURCE: After replacing batteries on Proform PF800 console stays lit
Pull the batteries out let it reset itself while its doing that check all cable to make the connection are seated firmly then reinstall the batteries, unless the function pad is sending a phantom signal engaging the display to be on continuously,or by pure chance the upper electronics went hay wire
Posted on Apr 11, 2010
Testimonial: "Thank you very much for your advice! Very helpful!!"
THE CONSOLE ON MY PROFORM XP 185 U EXERCYCLE WILL NOT TURN OFF.
usually they will shut off after a few minutes. if not look in manual to see if it is in demo mode(stays on all the time)
Oct 06, 2014 | Exercise & Fitness
My 390 E is locked up and I can't move the pedals. I checked the belt, it's still on and it's tight.
follow this steps and fix it. God bless you
Electronics Problem You control the tension of the pedals using the buttons on the console. When you assemble the A.C.T. elliptical, you have to thread a group of wires from the console through the upright down to the electronics board. These wires communicate the resistance settings to the electronics board. If the wires twist, disconnect or break, the resistance will not work. You will need to reconnect or replace the wires.
Read more: http://www.livestrong.com/article/406522-tension-problems-with-the-nordictrack-a-c-t-elliptical/#ixzz2Z4kLeLBm
Jul 14, 2013 | Proform PFTL79807 - 850 W/ Gamefit...
Resistance on elliptical acting weird
1) tight the bolts tension for magnet and clean very well. and proof..if the fail
2) go to test the magnet, use again the magnet from your refrigerator magnet, for attraction and repulsion. If do not pass the TEST replace the magnet in any Hardware such home depot, etc.
God bless you
Aug 27, 2012 | Proform Nordic Track Elliptical Resistance...
Ignition system mondeo mk3
might try changing fuel filter first...this may fix it.....
Aug 16, 2012 | Ford Cars & Trucks
New console on proform 580 doesn't work right
Dear Sir:
Please 1)adjust the reed switch see the diagram below 2) Change the baterries by new ones 3) Tigh the flexible cable from keypad 4) Tigh the connector from display board vs lower board.
Run inmediately after you did the step before software calibration for easy diagnose and troubleshooting.
If you can nor RUN your software calibration please see my personal TIPS, for easy diagnose and Trouble.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Feb 29, 2012 | Proform XP 580 Trainer Treadmill
My Pro-Form 330 elliptical has a resistance problem--it won't adjust and it seems to be set on a difficult resistance, I can't really pedal it. how do I fix this? I tried switching the levels, but...
Oct 27, 2011 | Proform PFTL79807 - 850 W/ Gamefit...
How to use the Proform 515S EKG Elliptical?
To mount the elliptical trainer, firmly hold the handlebars or the T-handle and carefully step onto the pedal that is in the lowest position. Next, step onto the other pedal. Push the pedals until they begin to move with a continuous motion. Note: The pedal disks can turn in either direction. It is recommended that you turn the pedal disks in the direction shown below; however, to give variety to your exercise, you may choose to turn the pedal disks in the opposite direction.
To dismount the elliptical trainer, allow the pedals to come to a complete stop. CAUTION: The elliptical trainer does not have a free wheel; the pedals will continue to move until the flywheel stops. When the pedals are stationary, step off the highest pedal first. Then, step off the lowest pedal.
As you exercise, you can adjust the resistance of the pedals with the resistance knob on the console. To increase the resistance, turn the knob clockwise; to decrease the resistance, turn the knob counterclockwise.
Jun 02, 2010 | Proform Exercise & Fitness
Pedals/resistance locked
Was this at a retail store you should exchage it.
If not then you will have to take the side off need to inspect all mechanical attached to the rails. It will be apparent to see the flywheel their eddy current transformer on top of unit or the flywheel itself is one package their should be are wire comming out of trace it back to the circuit unplug the connectors the resistance should be gone now test the mechanical function of unit to see if the pedal are free from any binding then reverse connectors and see if you can adjust the resistance if not the board is defective.
Jan 04, 2010 | Exercise & Fitness
Exercise & Fitness Logo
270 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
