Question about Kenmore 24032\24036 Top Load Washer
Excessive vibration in spin cycle
Kenmore 80 Series Washer Top Load Vibration
  • Anonymous Feb 14, 2009
    Kenmore series 80 washer spin imbalance after changing motor coupling
  • 198 Answers
Be sure the washer is on a solid surface, no plywood or skid platforms. Then be sure to lock in the front levelling legs.
Posted on Jan 24, 2009
My Kenmore 80 Series top load washing machine started making a LOUD rhythmic banging noise during the rinse & spin cycle
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If you look at the section on "Machine Base Parts" you'll see a number of springs and vibration pads.
It's possible that one or more of the springs or pads has come loose or broken.
In order to get to them you have to remove the cabinet.
Here is a description of how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=90fdc122f6335c7c64f46f2ea1b1c887
Also see the Whirlpool Service Manual for top load washers. It has a troubleshooting section that describes the reasons for excessive walking or vibration.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
If it's not the springs or pads, you may consider that the "Agitator Cams" in the transmission are not raising the Agitator Gear high enough (about 1/16" ) when the washer goes into spin mode.
See the description of what the Cams do in the Service Manual.
We had the same problem, excessive vibration and noise during the spin cycle.
In order to solve that problem, :
Assuming that you know how to remove the cabinet, agitator (you don't need to remove the tub), pump, motor and transmission the agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
It sounds a bit complicated but it really isn't too bad and (For a $15 part, saved buying a $170 transmission.)
Following is the Whirlpool parts list for their commercial washers although the consumer models use the same part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Sep 30, 2010 | Kenmore 24032\24036 Top Load Washer
I have a kenmore heavy duty series 80 that vibrates excessively w/no no load in it. It does not hit the cabinet but shakes like crazy. It is level in all directions.
It's most likely that one or more of the springs or pads has come loose or broken.
Aug 04, 2010 | Kenmore 23822 Top Load Washer
I believe i overloaded my kenmore 80 series super capacity washer...it will spin but it is flopping around all over the place...like something broke loose that holds it in place......can you help me fix it
Mar 31, 2010 | Kenmore 24032\24036 Top Load Washer
Clothes washer vibration during spin cycles
the vibration and noise is most likely from the drum bearings wearing out to test the bearings try this out,,,
open the door, hold the top of the drum and lift it up, if it has any free lift in it the bearings are going, now spin the drum by hand and you should here the rumble off the bearings
Dec 29, 2009 | GE WPXH214A Front Load Washer
Excessive drum vibration
Yes, look into trading in the Kenmore for one of only two manufacturers that employ a dynamic balance system built into the washer drum. Samsung and LG both use this dynamic balance system that balances the load while it is in motion. They also use a vibration sensing system to modify the time and speed of the spin cycles to minimize any vibration that might still be present. LG has this available on only their upper level models while Samsung's VRT is available on most all models. I believe that both of these manufacturer's are available from Sears.
Oct 03, 2009 | Kenmore 43142 Front Load Washer
Washer has excessive vibration in spin cycle
A unstable floor will cause the problem, glad you figured it out.
Mar 27, 2009 | Admiral AW22 Top Load Washer
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series leaving soap behind
check for clogs in the output line (the drain hose)
Jun 15, 2008 | Kenmore 24032\24036 Top Load Washer
80 Series top loader excessive vibration and noise on spin
check the screw feet, on the front corners, one may be not screwed down far enough to be 'tight' to the floor allowing a small movement that makes a lot of noise, halting under pressure suggests this is the case
May 26, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22932 Top load washer has excessive vibration at end of spin cycle
IF THE FLOOR IS NOT ABSOLUTELY STABLE, IT WILL MAGNIFY A SMALL VIBRATION INTO A LARGE ONE. PUT SOMETHING ON THE DRYER IF IT SETS NEXT TO THE WASHER, AND TURN ON THE WASHER INTO SPIN. IF THE ITEM ON THE DRYER SHAKES, THE FLOOR IS MOVING.
IF THE WASHER IS ON CARPET, REMOVE THE CARPET OR CUT HOLES IN IT WHERE THE FEET ARE SO IT IS NOT SETTING ON THE CARPET. THE CARPET AND PAD WILL BE TOO SOFT FOR THE WASHER TO SET STABLE.
ALSO, PICK UP ON THE REAR OF THE WASHER TO RESET THE AUTO LEVELING REAR LEGS. YOU SHOULD HEAR THEM MOVE AND RESET WHEN YOU SET THE WASHER BACK DOWN.
Apr 03, 2008 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
278 people viewed this question
Sal De
fordexpert
Robert Rankin
