LG LSZ 122VM-4 C6 ERROR CODE- how to fix the problem
When you turn on the air- con it switches itself off and display a C6 error code. I have had 2 electricans to have a look athe the unit and both could not identify the problem. Seeking help if anyone knows how to fix the problem.
SOURCE: ERROR CODE ON AIRCONDITIONER LG ART COOL INVERTER MODEL NUMBER LSZ244VM4
Error C6 on lg cool art is common. you guy need a new CAPACITOR. cost $7.05c aud. it's 6uF 450vac.
take about less than 10min to install.
my lg model is lsz244vm-4, it's run well now.
Posted on Mar 04, 2008
  • 86 Answers
SOURCE: through the wall HAIER air con
model no
capacity of a/c
need to solve yr problem
Posted on Mar 17, 2008
  • 3422 Answers
The first thing i'll say is you will need to get it repaired by a technician and i strongly recommend you not to do it by urself.
Remote control units have diagnostic program in the
control, after 3 to 5 minutes of operating if the diagnostic
tools detect abnormal operation, then its shutdown the unit
to protect from damage. Thermistor sensor is one of the
parts that detect the operation of the unit. Out of range
or defective thermistor can shut the operation of the unit.
If your indoor and outdoor is clean start the unit in cool mode and monitor the outdoor pipes. If your suction pipe is icing or dry then your unit is under charge, but if your suction is cold and sweating then the system is ok and sure that the thermistor sensor is defective.
- Out of range thermistor sensor in both return air and freeze up sensor can cause the tripping “off “ the unit.
Goodluck..
Posted on Mar 22, 2008
burzerko
  • 254 Answers
SOURCE: air-conditioning; error code: 425
Try Samsung.com
Posted on May 30, 2008
SOURCE: RADEL CR 208 PORTABLE AIR CON UNIT
DOES ANYONE ACTUALLY ANSWER ANY PROBLEMS ON THIS FORUM?????????????????
Posted on Sep 21, 2008
Error code "ch12 for LG PQRCUSA0
Connect the remote controller cable to
the wired remote controller installation board as shown in the right picture. 12V SIG GND Red wire Yellow wire Black wire 12V SIG GND 4. After fixing the
top part of the remote controller to the installation board as shown in beside picture, press the bottom part to assemble the controller to it's board. When
disassembling the remote controller from the installation board, use the driver as shown in the right picture and insert it into the hole with the arrow. And
when you pull the driver in the front direction, the remote controller will be separated. Wall Side Wall Side ENGLISH Red Yellow Black Remote Controller
Cable ?The remote controller cable is connected as factory default. Wall Side Wall Side 2. After fixing the cable to the guide slot, attach the wired remote
controller installation board at the desired location.
Mar 02, 2015 | LG Heating & Cooling
Hi. I have an LG Neo Plasma Air Conditioner. Some time ago it started cutting out (switching itself off) and giving a C6 error message. When this happens, the remote does not work and the unit needs to...
Looks like a possible communication error. If you're willing I got one idea for ya. Turn power off to unit. The indoor and outdoor unit are connected and "communicate " through 4 wires, these are labeled 1,2,3,4. They should be color coded inside and out. Meaning if the color black is on 1 outside it should be on 1 inside. But, regardless, at the outside unit swap 1 and 4...2 and 3. Do the EXACT same thing at the inside unit. Then turn the power back on. I have ran into communication errors on mini splits simply because the "data" wire had a little nick or some kind of extra resistance that would throw a communication error but will work just fine as a supply voltage wire. Hope it fixes the problem. Good Luck!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 06, 2017 | LG Heating & Cooling
My LG split system air conditioner shows C6 in the display of the unit. I can't do anything to get it to function now and even when I swicth the mains power off C6 is still shown. What do I need to do and...
C6-Indoor unit coil sensor fault. Disconnect from PCB measure resistance. 10 kOhm at 10C and 4 kOhm at 30C. if not replace sensor.Thanks, helpful?
Feb 04, 2011 | LG Heating & Cooling
Our airconditioner has the code C6 on it. It has cut out and displayed that code. We were instructed to turn it off at the power board and turn it back on, which we did. It went back on again and tried to...
I previously asked you, if the C6 appear on the unit or on the hand held remote. I contacted a friend of mine who is a service technician for the LG Split System units and he advised that it's an error code that can only be solved by a LG trained service tech or LG itself. It may have been caused by a power surge, which may have caused some damage to the circuit board.
Sorry I couldn't be of more help.
Feb 03, 2011 | LG LA185HV Split System Air Conditioner
The led panel on the indoor unit shows a C6 error code the air con is a split system plasma inverter
C6 - compressor run current high
- check [resistance of] compressor windings all equal 1 to 4 ohms
- check [resistance] to earth 50 Mohm minimum
- check run current
I'd also check the motor capacitor(s) , In maximum, it is due to weak capacitor. Replace and try.
Dec 16, 2010 | Heating & Cooling
Air con unit saying 'C6"
According to the service manuals:
6 is:
Excessive current at inverter
DC power circuit
so the unit shouldnt run?!?
The fault is also coming up as:
indoor unit coil sensor faulty
source:
http://www.mylg.co.uk/data%20for%20site/LG%20Fault%20Codes%20for%20SMS%20%2807%20Sept%29.pdf
all the best
Jul 05, 2010 | LG LSC183VMA Split System Air Conditioner
Hello have a inverter LG Airconditioner and it keeps turning itself off and showing the letters C6? Any ideas
Error Code: C6 Problem: Inverter compressor run current high
SOLUTIONS:
- check run current
Probably best to explain/print out and give to authorised serviceman
Mat
Jul 14, 2009 | LG Heating & Cooling
Lg invertor air con "neo plasma"
i have the same, only way to get goin is turn off at mains. ive now tried running on fan low .... got this tip from another problem and seems to work.
good luck
Nov 04, 2007 | Computers & Internet
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
