Question about Whirlpool LGR5636L Gas Dryer
Whirlpool dryer ignighter replaced still wont heat
  • Whirlpool Master
  • 8,220 Answers
The gas dryer assembly consists of a sensor, a ignitor, and a pair of solenoids. The flame sensor must have continuity when cold to fire up the ignitor. The ignitor must be hot and out of the circuit so that power can open them coils. So how do they do it? The control themostat is mounted very near the blower and filter housing. As the air passes by it on the way outside it judges air temp. When the temp drops below 105f the control powers up the gas assembly. The sensor, the ignitor, and the coils are all energized. The ignitor is wired cleverly so that while it is being powered by the flame sensor it takes up most of the energy required to open the coils. Once it gets heated up to ignition temp the bimetal inside the black box (sensor) shuts down power to the ignitor. It is so hot it is now a therm sensor itself. Full power goes to them coils and they can now open the valve. As the flame is ignited the 3rd wire on the holding coil is kept open by the heat from the ignitor which becomes a themo generator. Fascinating isn't it? My home movie:
More enlightenment
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 05, 2012
Master_Tech
  • 770 Answers
SOURCE: burner wont light
there is a heat sensor with a little window mounted on the side of the round tube it maybe bad it closes when the ignt glows red
Posted on Jan 26, 2008
  • 67 Answers
SOURCE: whirlpool gas dryer is not
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
if this helps please give me a fix ya vote
Posted on Jul 15, 2008
jtate9
  • 68 Answers
If you have replaced the igniter and the thermacouple. Your next item is the gas valve. This is not that hard to change out, but is probably the most expensive part on the dryer.
Please rate this solution
Posted on Aug 04, 2008
  • 13 Answers
SOURCE: dryer still wont heat
you could remove and bench test the theromostat. my kenmore would not complete the circut to heat at all with a faulty thermostat. Just use a jumper wire to bypass it and test it THERE WILL BE NO SHUT OFF COULD HEAT UP TOO MUCH IF LEFT RUNNING.
Posted on Dec 19, 2008
  • 512 Answers
SOURCE: whirlpool dryer wont heat>replace igniter >
Bad thermo switch located behind back cover in area of duct work. 1/4"x2" white in color, two wires connected to it. Stops ignition from firing.
Posted on Jun 07, 2010
Whirlpool Model LGN2000KQ0 ignighter glows, flame turns on for a few minutes then it goes out and the ignighter never glows again nor does the flame return
The problem is the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help troubleshooting a gas dryer
Sep 25, 2010 | Whirlpool GGQ8831L Gas Dryer
My gas dryer whirlpool lgn2000jq2 starts ignights the gas and then goes out no heat
my lgn2000jq2 gas dryer starts up, but no heat. i checked the element, its good. checked for 120 volts at element plug, no power there.
May 09, 2010 | Whirlpool LER8648P Electric Dryer
The heating element wont heat up. I've already checked the obvious solution, the dryer vent is clear of lent. Is there a fuse that I can replace?
yes there is need to check the thermal fuse first then the high limit thermostat. then the heating element
Nov 05, 2009 | Kenmore 63942 Dryer
Dryer won't heat up. Replaced ignighter, still
I would suspect faulty gas valve coils. These electrical coils are right above the gas valves and when energized these solenoids open the gas valves to permit gas flow to the burner. It's recommended that if any are suspected of being faulty that both (all) be replaced at the same time. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 11, 2009 | Kenmore Elite HE4 Electric Dryer
Whirlpool dryer ignighter not glowing
Hi!!! you might have a timer problem.Good luck..
Jan 04, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Burner wont light
Aug 02, 2008 | Whirlpool LGR7646E Dryer
Gas dryer tumbles no heat.
I would change out the igniter, When they start failing hey will glow but not draw enough amps to open the gas switch / valve.
May 02, 2008 | Dryers
Whirlpool ultimate care gas dryer
the glow bar on the gas ignighter
Mar 15, 2008 | Dryers
Burner wont light
Jan 01, 2008 | Whirlpool LGR8648 Gas Dryer
Whirlpool LGR5636L Gas Dryer Logo
79 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
