Question about Compaq Evo D510 Minitower (Open Box) (OB4700432011) PC Desktop
Internal graphics work but adding an external graphics card fails....tried several.
Added several graphics cards boots with color bars displayed and then loses signal once the graphics drivers install. Tried ati and Nvidia cards, pci 2.0 cards.
  • 2,878 Answers
You may have to disable the on board in BIOS.
Posted on Dec 05, 2012
  • 12 Answers
SOURCE: compaq 510s sff. Graphics Card
Hi Mikey You need to go to your bios setting and change your graphic adaptor from PCI/.. to AGP 1- turn your computer off (Shut Down) 2- keep press and release "delete" key on your keyboard while turning your computer on untill you go to bios (normally blue screen) 3-find your desplay/graphic or anything that is related to graphic. 4- Change it to AGP Now it should work but if it didn't work: 1- Faulty Display (Monitor) 2- Not compatible graphic card(rearly) 3- loose or damaged cables 4- Damaged Motherboard please let me know of your progress Kind Regards
Posted on Oct 09, 2007
tinamarie49
  • 34 Answers
SOURCE: BAD DISPLAY
Try replacing your video card. That video card may not work with your motherboard.
Posted on Dec 05, 2007
bunnydawg
  • 5158 Answers
SOURCE: Won't pass startup bios / screen
tap the f8 key as you boot up... it should give you a few choices... boot to safe mode or remove the video card and boot up.... if it boots with no problem it is a compatability issue with the card
Posted on Jan 05, 2009
SOURCE: 4bit 8color of resolution screen;
Go to the Compaq website and download the video driver specifically for your PC.
Posted on May 30, 2009
YourZEN
  • 820 Answers
SOURCE: my compaq evo d150 pc doesnt have a sound...
Sound on Compaq evo d150. The next site says:
http://www.orixrentec.com.my/hp_4.htm
Audio: "Integrated Intel Audio with Premium Internal Speaker".
So there should be a:
* speaker inside
* working on an Intel driver.
The chipset of the motherboard is Intel 845G.
The AC 97 audio driver can be installed by online detection of
your hardware using the Intel driver update utility:
http://www.intel.com/support/motherboards/desktop/detect.htm
When using a PCI-slot for extra sound, the matching driver of the
PCI-audio-card should be installed. Of course external powered and wired speakers will be required as well.
Posted on Aug 19, 2009
Fitting an external PCI graphics card ... issues.
Go into the device manager find the card you do not want to use then disable it do not delete it. Restart the computer making sure that your display is plugged in you want to use and it should show up. The way your doing it is allowing both monitors to or both drivers are active. John
Apr 16, 2012 | Acer Veriton M420 PC Desktop
Black screen at startup
It sounds like the graphics card or on board graphics is causing the issue, as the external monitor is not working either. Hopefully its a graphics card which can be replaced easily, or there is an expansion slot for a graphics card to be added.
One thing you could try is resetting the CMOS by removing the battery from the motherboard and leaving for ten minutes. Replace the battery and try booting.
Mar 14, 2012 | ASUS Computers & Internet
It displays colorful lines on the monitor...cant see nothing
Test your laptop with an external monitor and find out if the external video goes bad too. If both, internal and external images go bad, you have a problem with the video card.
If external works fine and only internal goes bad, most likely it’s either bad video cable or LCD screen failure.
May 21, 2010 | Nvidia GeForce 7200 Graphic Card
I have windows 7 Operating system installed on Intel Original D865GBF motherboard. The processor is 3.2GHZ. Ram is 2 GB dual channel (!GB x 2). I have added a graphic card PNY Ge Force NVidia 6200 AGP. The...
sounds like yo had the same Probles that I had with my 5200 geforce The install did not go well. what was happening was the direct x was binding to the old mother board graphics system and not the new card . to make it rebind just change the refresh rate in the nvidia icon in your task bar . disable the display adapter from device manager for the motherboard graphics .put the card in the slot change the montior cord boot up check you direct x by typing in run dxdiag and test directx to be sure it is runing with your card you can also see that fron the about nvidia you must have the driver for the card installed to do all this.. hope I helped
Feb 27, 2010 | Nvidia GeForce 6200 AGP Graphic Card
Toshiba Satellite P200-156; Screen dead; external monitor 'funny'
Thanks for the awesome explaination
The answer is that there are several causes of a dim display or the failure of a backlight to illuminate the screen. As most people are aware, inverter and backlight failure are the most common. Other causes are:- a faulty or damaged LCD/Inverter cable, Faulty motherboard and a faulty screen.
Firstly try the obvious!
There is a little switch usually located near the hinge which switches the display off when the lid is closed. This can sometimes get jammed and is easily overlooked. It might simply be a question of unjammimg it or making some sort of repair to it.
Most laptops are able to toggle between an external display and the built in screen. Sometimes the laptop can get confused so it is worth toggling between external and built in screen. As most have several different settings it is worth doing this several times. If the laptop screen flashes when you do this it would indicate that the inverter is trying to start the backlight. This means that there is a good chance that either the backlight or inverter has failed but does not totally rule out the other components.
It may also be worth resetting the bios as these settings can sometimes be lost especially if the cmos battery is on its way out or has been disturbed.
Dec 22, 2009 | Computers & Internet
No display during boot
Try a different monitor. Could be burnt out.
May 10, 2009 | Intel DG31PR Motherboard
Screen does not work any more. Got a new LCD but still no picture.
you said that you want a display card. first no extra card can be added to the laptop. that is not possible. and second if your lcd is not working then the inverter card might be gone. it is a small card which converts dc to high voltage ac so that the screen can be back lit and run. if this has gone it can be replaced and you can again restore ur screen.
you can check the working of the graphic card of you laptop by connecting external monitor. if that also not working then you need to replace ur motherboard. these are the solutions.
so in order to make sure your motherboard is ok. just connect an external monitor. and you cannot upgrade your graphic card as it is final in laptop.no upgrades for that.
Apr 19, 2009 | Computers & Internet
Display driver problem
Hi there ;
hey can u boot into the safe mode and go to the system restore from there and restore it just before the time that it messed up if not please let me know there is still things that we can do
best regards mike
Mar 07, 2009 | ASUS Computers & Internet
Display Problem
First things is to see if the problem is
  1. memory related(these all in one units have a problem that way.)
  2. Run everesthome and update chipset<NORTHBRIDGE>Google the northbridge for updates.
  3. nVidia GeForce FX Go5700 problem.Make sure all updates for graphic drivers have been installed, then attach an external monitor, the unit should support svga/dvi/s-video. Your graphics card has 128MB dedicated so if the external display responds the same way as internal monitor it's the video card or chipset.
May 07, 2008 | Sony VAIO VGC-V517G PC Desktop
Boot up issue
Your monitor may not support the SATA drive or the graphics card you put in.
Dec 30, 2007 | Computers & Internet
Compaq Evo D510 Minitower (Open Box) (OB4700432011) PC Desktop Logo
77 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
