Question about Garden
Carb on srm400be want rev up
Rebuild carb.which is a wa 142 walbro adj. carbs. now it crank good but it want rev. up. i also r&r the coil?
  • 2,239 Answers
Check the spark arrester on the muffler outlet if fitted to see if it is carboned up, if not check the exhaust port has not blocked with carbon
Posted on Dec 08, 2012
evwood
  • 50 Answers
SOURCE: My ryobi trimmer keep flooding.It
The most likely possibility is that the carb needs rebuilding. Just cleaning may not help. Gasgets go bad over time if fuel is left in the trimmer.
Posted on Nov 16, 2008
  • 109 Answers
SOURCE: Snapper SS312 weed eater. Cranks when primed but won't run
I am sorry to say this, but the compression for that type of engine should be atleast 120 psi. Remove the muffler and look at the cylinder, it is scarred beyond repair.
Posted on Apr 22, 2009
#1 Taper
  • 1041 Answers
SOURCE: stihl fs110r wont idle, wont get on step.new coil, new carb., adj
You might want to check the fuel lines for crack/breaks.
(TIP: If the carburetor is a used one, you probably ought to clean the small portals in the carb. with a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152). They work great for this job!
Jim
Posted on Jun 12, 2009
SOURCE: I need the fuel line diagram for a Walbro carb. Wt 231 k1
need to know which feul and which is return
Posted on Jul 16, 2009
  • 41 Answers
SOURCE: Walbro WA219b carb
Go to www.searspartsdirect.com and with your model number you should be able to find explode parts views of that trimmer. Filtered line to primer, primer to straight inlet on carb, angled outlet on carb back to tank. That might work. Not sure without part number.
Posted on Aug 02, 2009
I have a 42' poulan riding mower w/ a 14.5 B&S engine, it has a Walbro carb...needing to replace the carb thats on it, I found that the Engine offered two different manufacturers of carbs?
i think walbro is a better carb. nikki is ok but just dont like them. it should be ok. why dont you just put a rebuild kit in the one you have? that is only $10.00 or $12.00
Jun 19, 2016 | Poulan Garden
I have a Husqvarna 150 BT X Torg. It is 2 yrs old & it starts but dies & I start it again but oes the same thing in just a few minutes. HELP
Hi and welcome to FixYa, I am Kelly.
The symptom your describing is most often caused by the primer bulb/pump getting a pin hole in it. See this link Item 17: (PN 544363901)
http://www.partstree.com/parts/?lc=husqvarna&mn=150+BT+(2008-10)&dn=89_55_0033
It can however be caused by diaphragms that have failed inside your WYA-79 carb. If you do not have a primer bulb problem the next step is to rebuild the WYA-79 carb with a diaphragm kit.
net IMAGE search using this: Walbro "WYA 79" "Carburetor Kit" They average $13.99
The carb Manual:
http://wem.walbro.com/distributors/servicemanuals/WYAseries.pdf
Dried and cracked fuel lines can cause the same symptom you describe also.
Thanks for choosing FixYa,
Kelly
Apr 10, 2011 | Husqvarna Garden
Pour gas in carb. will run few sec. replaced both gas lines and filter.
You will need to clean the carb or if this unit has a walbro carb buy a rebuild kit and it will work just fine.. Good Luck...
Mar 23, 2011 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Need A parts diagram for a Sthil G65 Blower carb.
Unfortunately, Stihl won't release any of their illustrated parts diagrams to anyone except Stihl dealers. The dealers won't release them either. It is possible that the manufacturer of the carb will have a breakdown listed on their site. Stihl primarily uses either zama carbs (www.zamacarb.com) or Walbro carbs (www.walbro.com). Look on the carb for engraved numbers and letters to let you know what series and model to search on. The manufacturer is usually listed either on the bottom diaphragm plate or up on top. Walbro series usually start with a WT, or WA. Zama will usually have a C series (ex. C1U)
Nov 02, 2010 | Garden
Parts number
You need to know if it is a walbro or a zama carb. to start with.
then look closely at the carb. and find #`s
very small
walbro will be wt or wa then some #`s
zama will be c1q or c1u and some #`s on the opposite side of carb.
Walbro will be on the same side
you need to know the carb. #`s so a kit can be found for that particular carb. IE: complete kit or diaphram kit
May 20, 2009 | Homelite Consumer Products MightyLite...
Mar 30, 2009 | Garden
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
