Question about KitchenAid K5SS Heavy Duty Commercial Stand Mixer
My kitchen aid K5SS won't run
  • grace tan Dec 06, 2012
    This is a 20 year old unit that I use on and off. I was able to shred one batch of carrots with the shredder attachment. After turning it off and turning it on again to mix the batter, the unit won't run any more.
    New Friend:
First check the motor brush and replace them with a new pair. if you never do that check youtube and see a video how to do it.
Posted on Feb 01, 2013
ricardok45
  • 135 Answers
SOURCE: KA Mod K5SS: no longer have variable speed; only 3 of the lowest
Hi. Go to mendingshed.com. Look up Kitchenaid Mixer Parts. Near the top of the page locate their FREE Kitchenaid Service Manual in Adobe format. Download it. This valuable document will help you with your troubleshooting of the speed control and anything else that needs fixing. This manual supports your K5SS. Mending Shed also carries Kitchenaid parts.
If you order parts from Kitchenaid, be prepared to wait at least a month for them to arrive!
If this solution has assisted you, please rate it. Good luck! ricardok45
Posted on May 02, 2009
  • 4 Answers
SOURCE: I have disassembled my K5SS Kitchen Aid mixe with
If it is similar to my KSM 150 Mixer, then you just need to reset the stator winding. There is a black wire that attaches above the brush on one side just sitting on top of the brush slide that needs to be pushed back. Make sure it is not plugged in and push it back with a screw driver.
Posted on Nov 13, 2009
hslincoln
  • 235 Answers
SOURCE: So I shreded the nylon gear in my K5SS 325W. How
Hi DELUNAY. The only way to tell if your speed control assembly is bad it to remove it and test it a local repair shop, but I think from the symptoms you describe, you’ve already answered your own question and your speed control assembly is shot. The fact that your motor is not making any noise indicates to me that it’s not getting power. That can only be caused by two things; a bad speed control board or a burned out electric motor. When you shredded your nylon worm gear, did the motor exude a ‘bad/burnt’ smell (other than possibly ozone)? If not, then I would look at replacing your speed control board/assembly.
Since you know you’ve got to replace the worm gear, you might as well replace the speed control assembly. The inspection and troubleshooting of the mixer transmission is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the correct Part List manual around when you start to disassemble your mixer. If you're lacking one, you can download it from the KA website (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case use KSM50P and then select the first files under Parts List (definitely check to see if it matches your mixer. If it doesn’t, continue to look at other manuals until you find the correct manual that does match.)
Turn to pages titled ‘Case, Gearing & Planetary Unit, for the disassembly, troubleshooting, and reassembly of your mixer, along with all the parts. This is where you’ll find your
Besides your shredded worm gear, you can check for any other unseemly wear and tear on the other gears, etc. You may find more parts that need replacement than just a bad gear. You should also consider replacing the grease, particularly if there are gear particles suspended in it.
Besides needing a replacement gear and grease, you might consider replacing the gasket, too. I recommend using a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call).
As far as parts go, here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. You should search for ‘food grade grease’. Prices can vary widely between vendors, so do your comparison shopping.
It can be messy but quite gratifying to diagnose and repair your mixer yourself. Oh and don’t forget to replace the speed control board and associated components, tool
Here are some links to several excellent websites that detail the disassembling/greasing and reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer.
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it. hslincoln
Posted on Dec 11, 2009
Testimonial: "Thanks for the advice and sources. Much more helpful than calling Kitchen Aid."
hslincoln
  • 235 Answers
SOURCE: where does the speed control spring go on a kitchen aid k5ss
Hi NG345, Merry Christmas and Happy New Year! It sounds like you’ve got the right part to fix your mixer, now you just want to install it correctly. The good news is that your replacement spring can be installed quite easily (OK, maybe a little effort) by yourself, if you are a DITY type person and feel adventurous, and your mixer is not under warranty. Be sure you have the Parts List manual on hand, too. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model.
Turn to pages 6 & 7, titled “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. You’ll want to focus on Illus. Nos. 1, 2, 3, 4, & 5; Pivot screw, Spring washer, Speed control assembly lever, Control plate spring, and Speed Link & Cam, respectively. Your speed control assembly is attached to the bottom of the top part of the mixer’s head (or Illus. No 1, Gearcase Motor Housing, on pgs 4 & 5).
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links are different KA models, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer, should you decide to go that route.
If you feel this repair is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping.
Good Luck. I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Posted on Dec 31, 2009
hslincoln
  • 235 Answers
SOURCE: replacing the brush
Hi DENAULTR, this is a repeat of my previous answer to your problem. It would also be helpful to have the Parts List manual on hand. If you're lacking one, you can download a PDF version Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model. Turn to pages 6 & 7, titled ?Motor And Control Parts?, which provides an exploded view for the disassembly and reassembly of your mixer?s electrical components, along with all the part names and numbers. Locate Illus No 47, Brush holder assembly that includes Illus. Nos. #28, 32, 33, 34, & 46, and Illus. No. 29, Brush & Spring assembly respectively. Make sure you orient each bruch correctly following the illustration here: The Parts List diagrams along with the picture above regarding the orientation of the brushes should get your mixer powered back up and operational. Good luck! I hope this helps. Howard, Burke, VA If this solution has been helpful to you, please rate it, thanks! -hslincoln
Posted on Feb 26, 2010
Testimonial: "each side also have to be the reverse of each other and then it works"
How can I adjust beater to bowl clearance on my Kitchenaid mixer? I have a kitchen aid K5SS 300 w with NO beater to bowl adjustment screw. Is there anything else that can be done to adjust this?
There is an adjustment screw there. If you supply an email address I have the Kitchen Aid PDF on bowl adjustment for K5SS. My email address is screaming_skull@hotmail.com
May 02, 2014 | KitchenAid Food Mixers
Kitchen Aid Model K5SS.Ran only on higher speeds for a time,now wont run at all.Power supply and brushes ok.
Hello oldandnew2,
The problem is in the speed switch, the contacts are closed and not allowign power to go thru it is a common problem with all of the kitchen aid mixer over a period of time the contactors get carbon build up. Take the back off and look at the bottom inside and there should be two little contactors see if the are burnt and try and clean them. If this does not work you will need a new one, post back the the tread and I will locate you one.
Thank you for being a member of FIxYa.
Feb 27, 2011 | KitchenAid 32685 Mixer
KITCHEN AID MIXER K5SS has a banging noise when turned on how would I find out how to fix it ?
You will need to open it up and inspect the brushes carefully. Look for a little copper wire, this wire needs to be firmly attached to both the brush and the little disc at the other end of the spring. Clean the brush out with a can of electric cleaner to free any dirt that has built up around the gears.
Jan 04, 2011 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchen Aid Manual for RRK90 mixer I need one
http://forum.kitchenaid.com/forums/pdfs/u_c_classic4.5_5qtmodels.pdf
old model k5ss
http://downloads.mendingshed.com/KitchenAid_Service_Manual.pdf
Mar 16, 2010 | KitchenAid K5SS Heavy Duty Commercial...
Replacing the brush
Feb 26, 2010 | KitchenAid K5SS Heavy Duty Commercial...
Where does the speed control spring go on a kitchen aid k5ss
Dec 30, 2009 | KitchenAid K5SS Heavy Duty Commercial...
May 01, 2009 | KitchenAid K5SS Heavy Duty Commercial...
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
286 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
