Question about US Balance US-Stealth Digital Pocket Scale 500 x 0.1g
Us balance US-magnum-1000XR manual - US Balance US-Stealth Digital Pocket Scale 500 x 0.1g
  • Paul Campbell
    Paul Campbell Dec 05, 2012
    need owners manual
What does it mean when my us-magnum 1000xr pocket scale says rCAL and keeps flashing 500.0
You need to send it out to the manufacture and have it recalibrated. Hence the code RCAL.
Feb 24, 2017 | Pocket Health & Beauty
Where are the fuses on a 2001 Polaris 325 Magnum 4X4
Polaris 325 MAGNUM 4X4 HDS A00CD32FA Parts Manual
www.manualslib.com > ... > 325 MAGNUM 4X4 HDS A00CD32FA
View and Download Polaris 325 MAGNUM 4X4 HDS A00CD32FA parts manual online.Polaris Automobile Accessories Parts Manual. 325 MAGNUM 4X4 HDS ...
Aug 07, 2015 | Polaris ATV
How do I put a Harmonic Balancer back on my 3.5 Dodge Magnum engine?
might to go to local parts store and borrow a harmonic balancer installation tool
Jul 14, 2015 | 2005 Dodge Magnum SXT
How to put harmonic balancer back on 3.5 interference engine
Use balancer installation tool. Many parts stores will have this in loan-a-tool program.
Jul 14, 2015 | 2006 Dodge Magnum
I have a 88dodge ram 150 can I put a 318 out of a 98 dodge ram in my truck
It can be done but you have to be careful about a few things. From 1971 to 1992 was the original LA (small block) engine, 1993 and up are the Magnum engines. They are different in some ways but the most important in your situation is that although both are externally balanced, the two are balanced differently (the 360 Magnum uses lighter pistons) and each requires a uniquely balanced damper, flywheel, drive plate, or torque converter. It would be easier to stay with a Pre 1993 engine if possible. Otherwise make sure you get the convertor / flywheel with the engine.
Aug 28, 2014 | Dodge Ram Cars & Trucks
How to calibrate 1000xr us-magnum digital scale
magnum 1000xr pocket scales turns on calibrates goes to different modes but wont show the weight when object placed on the scale,a lock appears in top left of window, is scales broke or do i have to make lock symble dissappear?
May 28, 2011 | Kitchen Appliances - Others
2005 dodge magnum pulls to right just had it realigned 02/13/10 car was built on 09/04
sounds like the waight balance is off do you something heavy in a cetan spot in the car if not get the tires rotated and see if that helps if not i would say a profesional shop
Feb 14, 2010 | 2005 Dodge Magnum
Engine swap
I just put a 96 360 magnum in my 97 dodge 4x4 that had a 318 in it. Yes it does fit. I noticed that the flex plate on the 360 has balance weights on it and the 318 does not. Make sure the plate stays with the 360. The torque converter and exhaust manifolds bolted right up. The 96 360 engine had different connector plugs on the Map sensor, Crank Sensor and Tps. Get those off of your 318.
I did notice that with the 96 PCM for the 360 my fuel guage was off quite a bit. The 360 will run off of the 318 computer at least if your in a bind for Money.
Oct 04, 2008 | 1997 Dodge Ram
US Balance US-Stealth Digital Pocket Scale 500 x 0.1g Logo
62 people viewed this question
Top US Balance Computers & Internet Experts
David Payne
David Payne
Are you an US Balance Computer and Internet Expert? Answer questions, earn points and help others
